                Posts2,438
Everything posted by dvm27
	So how do you thin your shellac? with 95% alcohol and, if so, at what dilution?
	Good decision to raise it's location Chuck. I'm betting the Master carvers had the same reticence to pierce the original carving in that location as well!
- 1,784 replies
		- winchelsea
- Syren Ship Model Company
	Sweet work, Chuck. They're like the perfect carpet that ties the room together.
- 1,784 replies
		- winchelsea
	Glenn, your Winchelsea is coming along beautifully! Ship modelling excellence is not something I was born with. It has been a long and trying journey with many scrap pieces along the way. You just need to decide whether you wish to build many good models or a few amazing models in your lifetime. If you're satisfied with the former that it's much easier. If you're a perfectionist it's all about the journey and making sure every piece is a perfect fit. The first time you decide to install a piece that is not quite perfect you've crossed a threshold that could easily become the norm. So lot's of remakes and ungluing along this path but ultimately the one I find most satisfying.
	HH wrote "As a near-sighted person for most of my life, I am adjusting to the mid-life reality of constantly removing my glasses for close work, while simultaneously resisting the pressing need for bi-focals/transition lenses. This is the status of my mid-life crisis." Ha! I use bifocals and 5x Optivisors for my modeling. Wait till your midlife crisis advances to senior crisis...
- 2,673 replies
		- heller
- soleil royal
					(and 9 more)
	  Echo by tlevine - FINISHED - Cross-Sectiondvm27 replied to tlevine's topic in - Build logs for subjects built 1751 - 1800 Fantastic cross section Toni! Love the coppered bottom.
- 52 replies
	Nice job on those swivel mounts Chuck! I read somewhere (can't find the source) that ships only armed one side with swivels. They were easily transferred to the other side as needed.
- 1,784 replies
		- winchelsea
	The Winnie contemporary model steps only make sense if the molding sits proud of the planking enough to actually be a step.
- 1,784 replies
		- winchelsea
	With regards to what Druxey has said check out this link to the Royal George in their collection. If there's a finer example of the model makers art I have yet to see it. It's also at an unusual scale of 3/16. Check out the figurehead in the second photo on the site. They can also be downloaded in hi resolution. https://collections.mfa.org/objects/38550/100gun-ship-of-the-line
	But she is shown in her launching cradle so technically speaking, rigging would be inappropriate 😉
	The builder of the bottom ship model is much better than whoever built the top!
- 1,784 replies
		- winchelsea
	How about trying the Admiralty Models Echo cross section. The plans are free and a Power Point tutorial is also downloadable. There are several on this website (including the link under my name). http://admiraltymodels.homestead.com/Echo-X-section.html
	Cumulative error is always an issue Kevin. A glued joint does add perhaps 1/2" to the thickness vs two dry fitted pieces so perhaps deduct 1/2" per plank in the next run and seem if that lands you closer to your marks. Some builders also add a slight bevel to the inboard edge of the plank for a snugger fit but you have to be careful you don't expose gaps when final fairing. BTW nice fix on that bow anchor stock plank.
- 1,085 replies
	20 year Sherline mill user and agree with everything CPDDET says above. But there are several hobby options available so check out other suggestions that will be offered here as well. You'll need to do your research here and decide how into milling you want to get. For example Sherline has a new CNC comptroller that could produce incredible results if you understand programming but I just have the basic milling machine pre-CNC. Here's a link to Sherline https://www.sherline.com/
	  HMS Bounty by AdamA - 1:48dvm27 replied to AdamA's topic in - Build logs for subjects built 1751 - 1800 Exceptional joinery work Adam!
	Wow, Ben. Your deck paper pattern is an almost perfect fit to the as built model. Great work!
- 889 replies
	I think the way you've made them (off the ship) is much easier then trying to fit them successively inside the model. As you've undoubtably discovered these types of joints are relatively easy to make once you get the set-ups correct on the mill or the hand sequencing if using a chisel. Fantastic work, as always!
