dvm27
Everything posted by dvm27
  1. I think it's very hard to add convincing looking sails to a fully rigged model. But you certainly make it look easy Marsalv. they look just right with the back lighting.
  2. Looking good, Charlie. I suppose it's nice to have the increased surface area provided by a solid hull but I think a plank on frame hull is easier to do!
  3. Your dad still has mad skills, as shown by his work on the parrels Barbara. Are you a ship model maker also? If not, it's even more impressive that you are directing the construction of such a complicated model.
  4. If I had a ship that beautiful I would never let it leave the harbor. Imagine what one cannon ball could do to those delicate structures!
  5. Congratulations on completing a very difficult area, Toni. It looks wonderful!
  6. The cast frames look terrific, Chuck! Those wishing to add treenails to their cross section may find it easier to do before the frames are raised.
  7. Very well written and illustrated, Chuck! Your a la carte method of building provides plenty of choices for builders.
  8. Lovely work as ever, Amalio. I am very impressed that you've preplaced all those hanging knees prior to the deck beam installation and all appear to be at the proper height and angle.
  9. Very nice work Jason. I like the spirketting and coaming colors, I find that automotive black spray primer followed by sprayed black does a nice job of simulating iron. The key is to apply several light coats so no detail is obscured.
  10. I've recently switched to Birchwood Casey Brass Black as I find it easier and more consistent than the Jax blackener. I also use 320 grit sandpaper on the brass (or before I form rings and other small items). Soak the piece in alcohol first (or vinegar) to degrease. The B.C. solution is applied with a small brush and only takes 10-15 seconds to work. Rinse in water then see if you want the piece darker. If so just repeat the above process. I also do not solder my rings but do file the ends after forming the circle. This makes a neat joint. I can't imagine why you would need to solder the breeching rings unless your cannon was actually going to fire! And I now use only silver soldering paste. It is self fluxing and flows beautifully, Check out https://www.beaducation.com/pc/393-jewelry-making-tools-soldering-fusing-tools. Also, look at the videos on silver soldering and other jewelry work. they're terrific. And remember - you need a tight joint for silver solder to flow.
  11. Great start, Omega. Curious web site for this yacht. Only exterior photos. Usually, there are numerous photos of the staterooms and cabins with yachts such as these.
  12. Great photo, Ed! I'd never seen those fairleads before. I also appreciate the way the ratline ends were spliced. I don't recall how you handled these in your build but if you managed to splice them on your model I'd need to rate your model an 11 (ala Monty Python) instead of a perfect 10.
  13. It's been almost four years since Pete posted here. I miss your updates, Pete. You built some very fine models.
  14. Why am I not surprised that your sails are as perfect as the rest of your model? Lovely work.
  15. Wonderful work, Amalio. I love the way all the cannon tackle and ropes droop realistically over the wheels
  16. Congratulations on a lovely build and very interesting vessel Maury!
  17. Looking very good Mike. That slotted bulkhead (#29) shows this to be a very well thought out and designed kit! It address all the usual problems associated with raising the counter timbers.
  18. You might want to check with Alex M, Mark (https://modelshipworld.com/index.php?/topic/410-hms-sphynx-by-alex-m-scale-148-english-20-gun-frigate-as-build-1775/&). His wales are planked exactly like yours and he managed to blacken them perfectly after the hull was fully planked. I have blackened wood on my model by scoring the boundry line with a scalpel and applying blue painters tape. This was Druxey's suggestion and it worked well for me. But, as a rule, I try to keep Fiebings dye as far from my model as possible. One errant drop on the previosuly laid deck is irrepairable.
  19. Terrific posting, Ed! It's amazing how well the wipe on poly resists smudging from alcohol and blackening solution. Blackening in place certainly solves the problem of damaging the metal finish during installation. I note an additional iron band on the starboard yard plan that was not installed on the model (eighth from center). Illustration error?
  20. Your carvings make a very nice overall impression, Toni. Atalanta seems fully recovered from your broadside. I guess the prior damage to the counter timbers with your elbow was a warning shot!
  21. Looks great Mark! You know, looking at videos of real wooden ship building I believe planking is more difficult for us. We need to have precisely mated joints. The real builders left gaps which were later filled with caulking material.
  22. Thanks, everyone, for your terrific response. I was hoping for ten and there were thirty! I'll have to cap it here. Order takes about three weeks and I'll e-mail you for addresses and payment information. Greg amd David www.admiraltymodels.com
