Posts posted by wefalck
There used to be a guy in Germany, who made small batches of very solid and precise small table saws, but as always, he was a pensioner and at some stage had to give up this business. The market is small and the costs are high, so one can really do this only, when margins can be small because you have other income
There are umpteen different types of pin- and hand-vises from different professions ranging from watchmakers, toolmakers to biologists and the medical professions. Some of them are meant mainly for tool-holding, while other are primarily for work-holding.
A while ago, I put together a couple of pictures of the different types of work- and tool-holding devices that I have in my workshop (see also https://www.maritima-et-mechanika.org/tools/workholding/workholding.html). :
1 - Archimedes drill for watchmakers.
2 - Slender modern pin-vice with hollow fluted brass body.
3 - Slender antique pin-vice with hollow fluted brass body.
4 - Shop-made pin-vice with walnut body and head made from an insert drill-chuck; these drill-chucks are unfit for their intended purpose as they usually do not run true.
5 - Eclipse toolmaker's pin-vice with knurled steel body; these come in different sizes.
6 - French-style pin-vice; these are closed with the sliding ring and have usually brass inserts in the two jaws that can be adapted to special needs;
7 - Dito, here the jaws are replaced in hard-wood for delicate parts.
8 - Antique laboratory pin-vice with fluted wooden handle.
9 - Modern pin-vice with fluted wooden handle; these come in different sizes and capacities.
10 - Antique toolmaker's pin-vice for very delicate work in confined spaces.
1 - Toolmaker's hand-held vice that is closed with a sliding ring.
2 - Hand-vice with parallel serrated jaws moved by a screw.
3 - Antique american style hand-vice; the jaws are closed by screwing in the conical body; the handle and body have been replaced.
4 - Hand-held collet-holder; this uses horological lathe collets; the advantage is that work can be transferred between the holder and the lathe when it has the nominal collet diameter.
5 - Castrovejo surgical non-locking needle-holder; they come in various sizes, this has medium tips for eye-surgery.
6 - Antique surgical locking needle-holder; these come in a wide variety of sizes and shapes.
A selection of Castrovejo eye-surgery tools:
1 - fine-pointed non-locking needle-holder with straight smooth tips
2 - fine-pointed locking needle-holder with smooth tips
3 - fine-pointed blade-breaker - this are used to break off pieces from razor-blades to be used a very sharp scalpels
4 - very fine-pointed tweezers - they are stiffer and less springy than the typical watchmakers or biological tweezers
5 - medium-pointed non-locking needle-holder with curved smooth tips
And finally a small precision bench-vise with 30 mm jaws that I mounted on a wooden stand so that it can be shovelled around the workbench. There used to cast-iron bases for these, but they are extremely rare:
Most of these tools are 'antiques', but some are still available new. Interestingly, different countries seem to prefer different types of tools. For instance nos. 6 and 7 in the first picture I have only seen in France, while no. 3 in the second picture is an US American tool type.
- Roger Pellett, JpR62, Rik Thistle and 3 others
6
Well, unfortunately, the EU has clamped down on such things more strictly over the past few years. I did carry Sherline equipment from the US in my checked-in luggage, but at that time I was travelling on a UN Laissez Passer 😁. Also, there were special exemptions from import duties, when we could assure that these were 'attachments' that belonged to or complemented existing equipment you already had. The latter would also apply, when you had things imported by mail. My status has changed since and all the import duties would hit me hard ... There is also a maximum value of goods you can bring with you from outside the EU duty-free. I think it is around 300€. Above that you have to declare the items to customs and if they catch you, when you don't, the fines are hefty. Not worth the risk.
The two types of honing guides are available from watchmaker supply houses.
The two-wheeled one is a standard tool for honing gravers. It is supposed to be used together with an Arkansas stone set between two wooden rails on which the wheels run.
The other type was originally manufactured by a company called Barkus, I believe, to be used together with diamond wheels on watchmaker lathes. There seem to be now Chines clones available on ebay (check the area for watchmaking tools).
- Canute, mtaylor and EricWilliamMarshall
2
1
... or a close shave 😆
- Keith Black and mtaylor
2
I think your rope is untreated hemp for one.
Another point is the quality of the hemp as such. I gather today they have to take what they get, while in the old days certain regions specialised in the production of particularly long-fibred and smooth hemp, for instance certain provinces of Russia I believe and also in Germany.
The second point is the preparation of the hemp, which is quite elaborate to obtain only the long fibres, while the rest goes to waste.
The third point would be how careful and tight the initial spinning was performed. Your example doesn't seem to be particularly tight.
The rope-maker also goes along the rope in making with a rough cloth to rub off loose fibres.
I seem to have seen rather smooth, tighly twisted ropes.
So in essence, at any of our model scales one should really see any fibres sticking out. Many people now use synthetic fibres that are essentially endless and where the problem of 'hairs' sticking out does not really occur.
- jud, Keith Black, Bob Cleek and 5 others
8
Others used wet&dry sanding paper. In ship-modelling it is frowned upon, because it is not acid-free.
- mtaylor, Egilman, thibaultron and 4 others
7
I found the price for two pieces of CNC-milled aluminium and a thumbscrew quite steep, to which one has to add postage.
Plexiglas in thin sections is quite brittle, so the edges may break out, when abused. It also depends on how often you use the tool. If I was a kit-builder and working on one kit after another with lots of PE, I might have opted for aluminium or steel. It also depends on the thickness of the sheet-metal you want to work with.
The folding edges on PE are usually half-etched through lines, which are quite easy to place into these gadgets. I am working with the laser-cut paper parts, where I may score the folding line or not. Being able to see through the holding-down clamp helps in positioning the part.
Another consideration for opting for a shop-made solution was, that I turned the base of my miniature edge-sander into a multi-functional tool. OK, I have now various loose pieces to take care of, but only one little box to store it.
- Glen McGuire, mtaylor and Keith Black
3
There are PE folding gadgets on the market (quite pricey actually). They basically consist of a slab of aluminium and a kind of straight-edge that can be clamped down on it. The straight-edge does not have vertical edges, but a slightly more acute angle that allows you to overbend to account for the springiness of the brass.
Picture source: https://thesmallshop.com/collections/photo-etch-bending-tools/products/sms002-the-bug-hold-fold
I made one myself, but as it was mainly meant for folding my laser-cut paper parts, I made the straight-edge from Plexiglas, so that I can better see where I place the tiny parts. Unfortunately, I don't have a picture at hand.
Concerning the holes: can't you just drill at 0.5 mm or even 0.4 mm ? It is too late now, but I would have foreseen at least a dimple half-etched through or a pilot hole that could be reamed to size (using one of those five-sided reamers the watchmakers use to ream out holes in their tiny watch-hands).
When one looks closely at the above photograph, it is a bit strange, as it seems to show only one block on the starbord-side. The end the guy holds in his hands is loaded and runs down to the block, thence (presumably to the rail and another block(?) and from there back to the tiller. The second, loose, end the guy holds runs to a block on the rail and then to the tiller, where it is made fast with a knot, it seems. Strange assymetric rigging.
Steering with ropes running to a tiller (usually facing back out from the rudder!) or a yoke was very common on Arab vessels around the Indian ocean and also seem to have entered through them into some traditional Spanish boats.
- mtaylor, Roger Pellett and thibaultron
3
Yep, nice metal work!
- Keith Black, BANYAN, Glen McGuire and 1 other
4
Coming on nicely!
Didn't we have discussion of the flooring already? I think panels made from individual lengths of planks, tied together with cross-pieces would be an option. These panels should be short enough to be taken out between any eventual benches etc. to allow bailing out the boat.
- mtaylor and JacquesCousteau
1
1
Thanks, Bob, that looks promising. I will have to look into getting one of those ...
Regards from the Spanish Mainland.
- thibaultron, DocRob, mtaylor and 1 other
4
Not sure what you try to do, to put some sort of thick coating onto the copper that kind of covers the edges? Not sure I would want to do that, because it would change the appearance of the crispiness of the edges - otherwise the effect would be neglible.
Otherwise, there several threads here that discuss the merits of preventing the copper from oxidising or otherwise.
- thibaultron and mtaylor
2
The original poster did not mention, what he wanted to use the tweezers for. Some additional information in this respect could lead to more specific answers.
There are hundreds of different types of tweezers for different purposes, of different quality and, therefore, price. The watchmaker fraternity, in particular, uses a wide variety of tweezers for specific purposes. As they work with metal, they tend to be harder than the biological/surgical ones. Also dentists' tend to be harder.
Another factor is the overall stiffness, which depends on the steel and the thickness of the material.
Many reputed manufacturers now seem to sell their 'seconds' (which usually are still good enough for our purposes) through traders to the public. There are specialist traders e.g. on ebay that trade in such medical and biological tools. It may also be useful to check the on-line catalogues of medical and watchmaking supply houses to get an idea of the models available and their specific designations. Use these then to search on ebay etc.
Buying tweezer online can be a bit of a hit and miss. Particularly very fine pointed tweezers I would not buy on-line, but would want to check in person their tips and how precisely they close. I bought my main 'working' tweezers in person at a watchmaking supply store some 30+ years ago.
At model fairs, flea-markets and such events there are often trade stands that specialise in such 'seconds' medical etc. tools. This gives you an opportunity to check the quality. Keep on the look-out for antique equipment, the steel in them is often much better than in what is flooged new to us modellers.
Having said that, those Tamiya bending tweezers I didn't know and they look quite interesting. Do they properly close along the full length of the narrow tips?
Finally, if you get one of the cheaper ones for a few €/$/£ you can also grind the tips to your needs. Wouldn't do this with an expensive Dumont one, of course ...
- mtaylor, thibaultron, Bob Cleek and 2 others
5
I am not an expert on these, but looking at the arrangement and reading the explanatory text, it appears that the idea was to lead each of the halliards to different sides of the boat. In practice only one would be worked, persumably the windward one, as the leeward belaying point might be awash when racing. I think that is the idea, as otherwise there is no mechanical advantage over a single halliard.
Well, a grand re-opening of the Museum is scheduled for 17 November this year: https://www.musee-marine.fr/nos-musees/paris/expositions-et-evenements/les-evenements/le-vendredi-17-novembre-2023-le-musee-national-de-la-marine-rouvre-ses-portes.html
I have seen various projects and sat through various enthusiastic presentations by the director of the museum, but as various museology consultants got their fingers into that pie, it will not be the same as before. First of all, it seems to have mutated from a naval museum to a sort of ocean museum with the usual didactic raised finger. Second, the navy (who is the owner) seems to have succumbed to idea of a visual show, rather than to make the most of their material heritage. It seems that it will not be quite as bad as the NMM in Greenwich, but it will have far less the character of a study collection than it used to have. We'll have to see.
Talking about the size of models owned by the Musée de la Marine: the biggest is a fully operational demonstration model of an 18th warship that will be once again shown in the entrance hall. If I am not mistaken, it is around 4 m heigh and 6 m long ...
Their ropewalk is actually of an ordinary design, that can do 3 ply and 4 ply ropes of a fixed length. The size of ropes one can do with a machine depends, of course, on the physical strength of it and the maximum weight one can put onto moving end. Conversely, it may be difficult to make very fine, say sub-mm rope with such big ropewalk.
The good thing about working on niche subjects is, that forgeries are less likely to occur.
- FriedClams, Canute, bruce d and 2 others
5
I have seen the Museum's rope-walk in their workshops in Dugny (next to the old airport Le Bourget).
It is just an ordinary machine, except that they apply the weight to the moving end by a set of multiple pulleys. I gather by chosing how many sheaves they use, they can vary the pulling force.
Well, weren't midshipmen not put through almost all mundane shipboard tasks as well so that that they better understand what they will be commanding later?
- Keith Black, FriedClams, Canute and 1 other
4
The last photograph seems to show an officer painting a funnel !?
- bruce d, FriedClams, Canute and 3 others
6
mini table saw
in Modeling tools and Workshop Equipment
Posted · Edited by wefalck
No, the saw were only sold through 'connections' it seems. I forgot the name of the guy.
