MAN>>>>>>>>>I love how you do that....never get tired of seeing it!
- 222 replies
- gorch fock
- barque
Cutty Sark by NenadM
popeye the sailor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
looks really sweet Nenad.........stanchioning is a very nice bit of detail......- 4,152 replies
- cutty sark
- tehnodidakta
I'm not so bad........I love a good roller coaster. when I get up on a roof, I need to walk around a bit to get my 'legs'.......after that I'm fine. I haven't had to do stuff like that for quite a while now.......I might be a bit daunted. we went to a concert a few years ago.......our seats were wayyyyyyyyyyyyy up in the 'nosebleed' section. cripes......felt like I was going to slide off the edge! don't lean over the railing..........I joked around about it for a bit. don't think anyone was amused when I hollered out 'Avalanche'!- 4,152 replies
- cutty sark
- tehnodidakta
great progress Michael....such a nice scale for tying knots! super workmanship and added detail gee, the ninth is only a few days away........I'll be sure to wish 'er a happy birthday then........I hope your not in for the 'terrible twos'
- 2,215 replies
very nice and great planking too! very well done! thanks for the link.......I have it bookmarked
- 222 replies
- gorch fock
- barque
I showed it to the admiral.......her observation made me laugh........."it's as long, as I am tall!" :D she likes your desk
- 382 replies
- stadacona
- sylvan scale models
you came through your problem quite well! the structure looks awesome if you have any floppy discs lying around, the disc filament would be perfect...........look at Peter Visser's build of the Zeechouw. it works quite well
the only time I've run into a problem, is when I put in a new cartridge. usually I run a picture or two through it, use up some of the ink, and then once when I go to use it, to get the ink moving. I tried the idea of diluted white glue, and found out what it does......that's why i use the decal bonder. I let it sit for a bit to dry, and then I spray it with the bonder........it dries very quickly, and doesn't give the ink time to become solvent and bleed. a light coat to lock it in........another coat to seal it. when the flag is cut out, it helps quite a bit with the fraying issues that can happen. the flag will be two sided, so it is folded over the thread and white glue can be used to do this. it can be stitched as well at this point.
- 299 replies
- niagara
- model shipways
I'm not talking about decals......I'm talking about printing right on the sail cloth. let it set a while for the ink to dry, and then hit it with the bonder......I notice that this product can be purchased separately now. Testors this is the basic decal maker......if you read the description, it will tell you how to get the standard edition {which is what I have} the basic will not allow you to import images and designs, but the standard one will. from there you can alter it and change it to whatever you want, and it even comes with some common decal designs and insignias
- 299 replies
- niagara
- model shipways
your getting there Nenad.......little by little. can you get a flat lacquer where you live? it will dry flat and bring out the grain all at the same time. where I live, I can get a white primer....it would make it easier to repaint that aft bulkhead. lite colored primer.....is the key- 4,152 replies
- cutty sark
- tehnodidakta
neat way of replicating decorative knees........very nice & great progress!
- 2,215 replies
no Nils.......it's my abbreviation for photo etch where do you get it from.......looks very good enjoying your progress so far! that is a really neat way of doing railings........I'll have to remember that!
- 222 replies
- gorch fock
- barque
so, you need to remove that one as well. would it help you, {repaint and make your marks} if you were to make a jig for the height that the windows should be at. just a small piece of flat stock cut to the height that the frame should be. make the marks for the centering and with the structure flat on the table, lay the jig against the front of it. locate the part using the centering marks and the jig. there is also slow setting CA out there on the market. what were you going to put in the frames? darkened cello? you could also use the same jig on all the windows, so they will all be at the same height.
so....the plot thickens.......I'm thinking that it did a bit more than remove paint.......am I right?
keep up work like this Augie......and your house WILL be a museum! looking very nice......love it!
- 2,191 replies
- confederacy
- Model Shipways
exactly Tim..........everything has it's moment. never heard of un-cure, but if you just stripped the paint.......then that's no big deal. just paint her back up and you'll be back to square one in no time
looks awesome Andy :) it's a good thing you know your way around this ship........you won't lose track of where you worked on her last ! nice progress thus far!
- 382 replies
- stadacona
I've run sail cloth through the printer...........I have the the Testor's decal maker. I import the flag design, size it with the program, and then print. then I spray it with the decal bonder to prevent the ink from running. it's easy to shape after it is assembled on the rigging.
- 299 replies
- niagara
- model shipways
looks very nice Vivian.......most of the time, you can stretch the scale a little, and you can get away with it. you just have to be careful on how much you do it. you did well here though.......and you can build in a little extra detail to compliment it. very nice deck work hope you didn't hurt yourself too badly
it looks great Tim..........if your only sin was staying away from the bench, then your forgiven. there's no time limit an easy way to repent, is to get that detail on there! looking forward in seeing what it will look like!
