druxey
Everything posted by druxey
  1. Bonnets were used instead of reef points, Claire. Neat work on those sails. I'm so sorry about the loss of your friend Ken.
  2. It's nice when earlier attention pays off later in the build, as has happened here. Looking good! Enjoy Crete with your bride!
  3. Thanks for your opinion on the hornbeam, Chris! Sorry about the milling 'oopsie'.
  4. I've not come across black hornbeam for model-making. How fine is the grain and how well does it cut? And will it bend easily with heat? Certainly the photo makes it look really good. I bet it glues better than ebony!
  5. To begin with, read one (or more) of the pinned planking tutorials on this site. We've all been there! http://modelshipworldforum.com/resources/Framing_and_Planking/Planking primer.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/Lining Off your hull for planking.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/NailPatternJig.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/plankingfan.pdf
  6. Thank you for making me smile this morning, Ab! Love the figures animating your model as well.
  7. Thanks for keeping us up to date, Keith. Glad the end of reconstruction is in sight.
  8. While the jig solves one problem, it creates another - that of making the throat and end seizings 'in the air'. I use a jig simply to mark the underside of the line where it wraps around the deadeye. After removing the shroud or shroud pair, I can hold things using third hands while applying the seizings. Then I pop a deadeye into the bight (the line has sufficient stretch to do this) and reinstall the shroud over the masthead.
  9. As a footnote to Trevor's contributions, Humphries took off the lines of South Carolina, ex L'Indien in 1782. She had been a French design built in Amsterdam. She was heavily armed with 28 39-pounders (continental guns) on a single gun deck. She was extermely fine below water, fore and aft - more clipper-like than a heavily armed warship. As a result, by the time she reached Philadelphia, she had hogged 'amaisingly' (Humphrey's own note). However, she was the prototype for Humphrey's heavy frigates and, noting this deficiency, as well as the extreme sheer of her decks, he built in preventative measures including early diagonal riders.
  10. Congrats on your early ambulation as well as the success of the surgery, Bruce. Also on your progress with the model.
  11. Interesting bio. It ticks off many of my boxes - Dickens, Babbage and Lovelace, Shute, set design (may harpsichords substitute for organs?), steampunk, and, of course, ship models. You've come to the right place, apparently! Welcome indeed, sheepsail!
  12. Well done, Giampiero. It's a tricky one to do, fitting it around the headwork and under the bowsprit. I wonder how long the original figure lasted at sea without damage!
  13. With all due respect, I would use epoxy for metal/wood or metal/metal joints (if not soldering), rather than CA.
