Everything posted by druxey
Good question, Dirk. The English also made repairs and replacements easier by through-bolts that were forelocked. How early this practice began, I'm not sure.
- 1,035 replies
- royal katherine
- ship of the line
I use the MicroMark lead-free pewter. As for all casting metals, you ned to skim off the dross before pouring. I can see that the urn-shaped opening might create a bottleneck/backup, allowing cooling to occur before complete filling of your mold. If low melting point is an issue, there is always Wood's Metal - it flows at below the boiling point of water! I've no idea what blackening agent might work on it, though. Cerrosafe is a non-toxic alternative.
Congratulations on a fine result, Thunder. I remember seeing advertisements in Model Shipwright back in the '80s and wondered if the kit was as good as the photo in their ad. It is.
- 102 replies
- speedy
- model shipwright
Depending on how nicely the RTV mold is 'clamped' by the outer plaster one, the seam should be minimal. The slight seam, if there is one, is easily filed off. The finish used was a chemical one: Jax Pewter Black. Incidentally, the carronade pattern shown was the earliest one of 1782 that lacked the muzzle cup or extension seen on later ones. Another consideration is providing air vent passages in the mold to allow a complete 'fill'. Did you have such channels when you attempted to cast?
I used to pattern/duplicator turn my guns on a Unimat. The taper angle had to be a trial and error offset of the headstock. I found I needed a very fine-tip cutting bit for the reinforcing rings. Eventually I realized that it was not the best method of producing multiples, so made masters in wood. (By this time I also had a watchmaker's lathe, whose cross-slide could adjust for taper turning.) These masters were cast in clam-shell RTV molds supported by an outer dental plaster shells, then cast my cannon and carronades in lead-free pewter.
...and, order begins to emerge from chaos!
- 1,208 replies
- great republic
- clipper
Glad you didn't just take my word for it, Alan: verify, verify, verify!
- 125 replies
- 9 pound naval cannon
- 3d cannon barrel
What an intense collection of belayed lines! And trying to rattle down those shrouds at this stage of rigging must be a real endurance test. You continue to amaze us, Ed.
- 3,618 replies
- young america
- clipper
Michael! That isn't 0-gauge live steam, is it? It reminds me of Emett's Far Tottering and Oyster Creek Branch railway.
- 2,215 replies
That's a lot of machining for a single piece! Looks beautiful.
- 589 replies
- le gros ventre
- cargo
Happy travels, Cathead! We look forward to your return.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Um, you could try to get another $10 off, Alan: decks had wood plugs over nails, not treenails!
- 125 replies
- 3d cannon barrel
Miniature wood plane
druxey replied to michael mott's topic in Modeling tools and Workshop Equipment
Plane sailing, perhaps? (Sorry, couldn't resist that.) -
Nice. I approve of your lining up the screw slots so nicely!
- 2,215 replies
