Everything posted by druxey
An alternative to gluing up separate strips is to paint the overlaps of the cloths using acrylic paint and a ruling pen.
May I suggest not using tea? It is acidic and will eventually make the material brittle and crumble. A wash of either watercolor or acrylic paint is a much better choice. Andrew's sail ( Post #9) looks terrific!
Halò from the Highlands of Scotland.
druxey replied to Highlander's topic in New member Introductions
Dear Highlander, Forgive the pun? You obviously haven't read many posts here yet! Welcome aboard. -
I'm late to the scene: very nice neat work and bending job!
- 201 replies
- Oyster Sharpie
- first scratch build
Research in the HMS Ulysses 1797, a Roebuck class ship
druxey replied to Kevin Kenny's topic in Nautical/Naval History
Interesting. However the frame looks far too 'fat'. Do you have scantlings for a 44-gun ship? -
As you've figured out, cutting tools have to be really sharp and don't try to cut off too much or deeply at a pass. Slow and steady does it. It helps to have a template of the rabbet profile aft at each station so you can see the changing turn of the rabbet. Hope Take Two goes better!
- 92 replies
I've used Titebond II successfully many times for veneering. The advantage is that the glue can be reactivated more than once by heat. Regular white glues can only be reactivated successfully once. That said, a properly spiled and pre-bent plank will stay in place with only about 30 seconds of finger pressure.
