druxey
Everything posted by druxey
  1. re: Post #35: The fact that waterlines fall exactly 8' 0" apart is a nice confirmation of correct plan scale.
  2. I'd be terrified to use a rotary tool to cut the limber passage!
  3. Looking good so far. The scores for the sills are nicely positioned. You may wish to clean out the inner corners with a very sharp blade, or the sills may not seat properly later on.
  4. While Chapelle's draftsmanship is excellent, unfortunately he is not always reliable. Cum grano salis...
  5. Unglaublich, Eberhard! Congratulations on miniature masterpiece. An amazing accomplishment.
  6. It would take a chapter to describe the manufacture of cannon, but the bands you are asking about, named reinforces, were all cast into the cannon. Only very early wrought iron ordnance had separate bands applied (shrunk) over a barrel made up of longitudinal iron bars. There is a lot of information on the internet you could access on the subject.
  7. I've just discovered your log, Gregor. What a beautiful job you are doing at this scale! A gem of a model.
  8. Agreed: both beautifully done and the construction well demonstrated.
  9. Looks good to my eye, S.J. When building these tricky structures, I often wonder who was cunning enough to invent them?
  10. Nice 'revision' at the bulwark, Keith! Can't wait to see the finished sanding result.
  11. My method of cleaning brass or copper for chemical darkening is to put the pieces in a hot solution of Griffith/Grobet pickle for a few minutes, then rinse. Use tweezers to handle small parts so you don't contaminate them. Use safety precautions when handling pickle, please. I use a small glass jar to hold the solution and place it on a small heating pad that was actually intended to keep a mug of coffee hot!
  12. Welcome aboard, John. A nice family heirloom like that should be protected in a case after you (hopefully) have it restored.
  13. A nice, methodical approach! Great result.
  14. If using tweezers, perhaps a narrow groove filed into each side of the business end will prevent the ring from popping out as you close it?
  15. That broadside view is now particularly impressive, Marc! That is a lot of breeching rings to close up. I hope you have a pair of very small-nosed parallel pliers for the job....
  16. I was amused by the sailor climbing by every other invisible ratline. That's picky, Steven! Nicely done, though.
