druxey
Posts posted by druxey
  1. Correct on your assumption, Ed. I've a number of sizes made for different diameters. To prevent damage to the holder, a small hole is bored all the way through first. This allows a wire to be poked through, should the deadeye be unwilling to drop out after processing. Next the bore is drilled slightly smaller than the deadeye for about twice its thickness, then the hole opened out to the diameter of the deadeye for its depth. The deadeye then sits on a slight step and the drill bit doesn't chew up the holder.
  2. Ed: no special paper was used, just regular bond. As it's sealed on both sides, (paint on one, white glue on the other) deterioration is unlikely.
    Thanks to everyone for looking in and for all the 'likes'. It's very encouraging!
    Today I installed the aft thwart and mooring timber heads, as well as the tiller. There was no indication of a tiller on the draught, so this is my own invention. I may paint the hand-hold in crimson. The tiller was carved and sanded to shape by hand, not turned.
    At this point in the build, it is time to make a list of what remains to be done. There are ornamental carved brackets at each corner of the coach, two ensign staffs and their flags. Also, there are twelve oars to make. Stay tuned!
  3. Cog: No, I use acrylic paint, so there are no issues. I still stretch the paper as if doing watercolour, though!
    Alan: Whatever gives you the impression that I make no misteaks?
    I repainted the decorative work to the correct length, cut the pieces out and glued them to the model. The cut edges are not an issue here, as they are hidden by mouldings top and bottom, and also overlapped at the ends.
    The friezes installed, I then cut, shaped and painted the planksheer rails above the decorative work and glued these to the model. The coach is still removable at this point, so giving a clear field of operation.
    Aft of the coach is another thwart with what appear to be mooring posts attached. These are next on the list.
