druxey
Posts posted by druxey
  1. Another minor update:
    The underwater hull has been refined and the gudgeons added. The lower gudgeon is conventional, but the upper one on the transom is a small eyebolt. This was often the case with open boats. I looked at photographs of extant ceremonial barges and noticed that the transoms were invariably painted. It was an awkward job to do at this stage of the build, but I was successful using a 00 sable brush.
    The mounting of the model now needed to be considered. I decided to make a simple pair of pedestals in clear acrylic. These were turned, then polished. I was filing the keel slot in the second of these when one side cracked off. I had to repeat the set-up to produce a duplicate piece. Grrr!
  2. Thank you again, all, for visiting this log and for your comments.
    A small update. The corner seats forward of the coach have been made and installed. These were some trouble, and I made three sets before I was satisfied. Running the moulding along the edges where the grain direction changed was difficult, as there was a tendency for tear-out.
    Instead of wooden standards uniting the thwarts and sides, there are iron straps. On Prince Frederick's barge, the arm of the strap that runs across the thwart is inset flush to the thwart's surface. The side arm is bent as appropriate over the inner sides of the planking. This detail completes the structures in the rowing section.
    While the model is invertible without risk, I shall be cleaning up the outer sides of the planking and softening the edges of the laps. It is also time to make and fit the gudgeons.
