Everything posted by druxey
Patience, gentlemen, and all will be revealed in time!
- 641 replies
- greenwich hospital
- barge
Thanks again for your encouragement, folks. All the thwarts are now in, along with their longitudinal pieces. Once I figured out my strategy, this was easier to accomplish than I thought. After marking out and cutting recesses in the thwart, a small tongue was glued underneath. This prevents the longitudinal strip from falling through and allows it to sit flush to the thwart. The recesses are carefully marked and cut using a scalpel. The longitudinal is cut to length and the corners bevelled to 45 degrees using a fine sanding stick. I found that using a chisel here was difficult, as I could not cut the corners consistently. Next are the two small platforms or decks forward of the first thwart. That will complete internal work at the fore end of the model.
- 641 replies
- barge
It is possible to rig to those bolts in place but, having been caught in that trap once, I wouldn't recommend it! Your work is lovely and clean. That is a first-class model on the way.
- 452 replies
- cheerful
- Syren Ship Model Company
Turned some pillars for under the thwarts freehand with files. As there are only five to make, it was not worth the effort to make a contour pattern. The pillars will be almost invisible in the finished model anyway! The stock was 2" square. Started cutting and fitting thwarts. The ensign staff step was also added under the wider thwart before the area became inaccessible. The thwart itself has now been drilled for the staff and installed (third photo).
- 641 replies
- barge
Kind of rough and ready! Thanks for these informative photos, Glenn. The 'aft part of the wreck' model is superb.
I don't disagree with your posts, Rob. The 3 bolts per that you indicate in Steel are certainly there! However, what bothers me is the wording, "in each scarph". This implies a further three bolts through each scarph rather than between the floors and futtocks of the frame pairs. Now, to confuse you further, I looked things up in Steel's Naval Architecture. The three bolts you indicate (square in section, BTW) are specified as having the same dimensions as the keel bolts. BUT, (page 378) Steel mentions treenails, not bolts, through each part of the chocks! "The frames, when bolted together, have chocks fayed in the seats at the heads and the heels, and fastened with treenails..." I rest the case, m'lud.
Very nice, Mark. Just catching up with your log. I didn't know about 'rudder retrievers'. Must be a new breed?
Effie M Morrissey by allanyed
druxey replied to allanyed's topic in - Build logs for subjects built 1851 - 1900
Very neat, Allan! That row of stanchions must be very satisfying to look at now. Of course, there's the other side of the ship to do yet....- 15 replies
Thanks for the information, Steven. I'm sure that the actual oars varied slightly from each other and were not the result of mass-produced casting (although it's a tempting thought)! I applaud your wanting to keep the model of wood.
Thank you for your positive comments and encouragement, everyone. Test made the joint required for the thwarts. A little tricky, but not impossible. The critical thing will be to have all the longitudinal pieces line up nicely!
- 641 replies
- barge
Nice subject, Maury. Looking forward to your posts!
- 525 replies
- anchor hoy
- hoy
Cutter Cheerful 1806 by rafine - FINISHED
druxey replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Lovely and very neatly done, Bob. And, as you say, sooo much less work than a three-masted vessel!- 525 replies
- cheerful
Well, the 48 batten pieces have been cut, shaped and installed, along with the six footboards. Next will be the thwarts. They should be a simple job, but are complicated by the fact that the edges are moulded and need to be mitred to the longitudinal strip running down the mid-line of the boat. Also, six turned supporting pillars are needed to support the thwarts. Stay tuned.
- 641 replies
- barge
filling pieces between frames
druxey replied to AON's topic in Building, Framing, Planking and plating a ships hull and deck
Presumably this was carried out as frames were erected - not after the fact. -
That's dedication: making the complete set of oars, Steven! Good for you. The completed ones look very good. How long would the full-sized ones have been?
ancre La Salamandre by tadheus - 1:24
druxey replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Those mortar beds are very substantial! Nice work, Paul.
