Everything posted by druxey
Endless: some contemporary models and plans do show the discharge tube exiting the counter. Looking great, Chuck!
- 1,051 replies
- cheerful
- Syren Ship Model Company
ancre le rochefort by cabrapente
druxey replied to cabrapente's topic in - Build logs for subjects built 1751 - 1800
That's a flying start! You've a lot of pieces cut already. -
Looking lovely, Mike. Are you planning to pin the windlass to the deck as well?
- 452 replies
- cheerful
Steven: I've finally had time to look at and absorb your preface to the build. Fascinating reading! Nice to see you actually get started in earnest.
Frégate d'18 par Sané , la Cornélie
druxey replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
I'll send again, John. -
It also assists respiratory health in wintertime!
- 889 replies
Thanks so much, everyone. A footnote: I fully expected the shell and frames to have spread until the internal members such as thwarts are fitted. This has proved not to be the case so far: the hull is 'on spec', with an overall beam of 6' 1½" (6' 0" moulded, plus 1½" for the planking). We'll see if this is stable when I come back to the model.
- 641 replies
- greenwich hospital
- barge
Even a shallow bowl of water in the shop might help things, Ben. Ideally a humidifier is best, but it's better than nothing. Varying humidity due to seasonal change is the enemy of wooden models. Try to keep things relatively stable year round.
- 889 replies
This will be the last update for a few days: the frames have now all been bent in. I'll be back in a week or so. Thank you all for following and liking this log.
- 641 replies
- barge
Remo: I've seen your beautiful work and you are under-selling yourself. I'm trying to be in your league!
- 641 replies
- barge
Cutter Cheerful 1806 by rafine - FINISHED
druxey replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Looking good, Bob!- 525 replies
- cheerful
That sounds very convincing, Glenn. The discussion and process of arriving at this conclusion I found most interesting.
I have no idea, as it will depend on the specie of wood you will be using, Steven. You will need to experiment with both moisture and heat.
- 641 replies
- barge
John: did you receive my PM from the other day? -
Beautiful work, as ever. Thanks for the early treat on Friday instead of Saturday! Enjoy your family weekend. Still working on the assumption of quadruple boilers?
Excellent method and result, Mike. Well done!
- 452 replies
- cheerful
Aft frames are now in, with some fine adjustment still required. A ruler is included in the photos as requested.
- 641 replies
- barge
Glue 'em damp, and clean up any excess glue with a damp brush, Ed.
- 641 replies
- barge
Ed, have you tried bending frames using moisture and a thermostatically controlled iron?
- 3,618 replies
- young america
- clipper
Ed: The frames are bent in wet, without any heat necessary. They are of such small dimension that this is easily accomplished under slight compression to 'spring' them into place.
- 641 replies
- barge
