druxey
Everything posted by druxey
  1. Tung oil does tend to polymerize in the container once it has been opened. To store it, pour it into a smaller container to avoid an air space or use a small gas canister (designed for this purpose!) to 'fill' the air space above the oil. As for your humidity issue and wood expansion/shrinkage, this is a perpetual problem with wood. One can minimize this by building the hull in low humidity times of year. When humidity rises, things will tend to swell together rather than shrink apart. A finish on the wood will also slow down changes due to humidity. It is no accident that museums and art galleries control both temperature and humidity. I also use a humidifier at home during winter months in Canada.
  2. Lovely work as ever, Ed. The enclosures look quite low; what height were they?
  3. Ai! That's a lot of things to consider. Thanks for walking us through this stage of creating a 3D file that is printable. Except that, if I were to try it, I'd be saying things that were unprintable!
  4. Well done, Maury! My only comment would be that the berthing up on the quarter deck and the rail above it look rather wide: I think it is due to the fact that the moulded way of the top timbers are too wide. However, you've a major achievement by completing this fully framed cross-section. Take a bow!
  5. Nice going, Dan. Small point: top and butt is not quite the same thing as anchor stock. In the former the 'arms' of the pieces are of unequal length, usually 2:1 ratio, whereas the latter has equally tapered 'arms'.
  6. Congratulations on completion of a years' work, Dan. Andrea looks great. I hope that your client is very happy with the end result.
  7. Daniel: I'm sure Livesay means towed, but the term lowered from made me think about how the boats got into the water.
  8. Interesting kludge on the cam frame! Your note about available widths of deck planking is interesting as well, Glenn. And your work is impeccable, as usual.
  9. Davits aside, look at the Turner sketch of December 1805. In the foreground is an anchor and capstan. Are these at the end of a dock that Turner is standing on to make his sketch? And what is the spar above them? Livesay's note reads: "Victory Decr 1806 had two boats lowered from astern during the whole Action" (my italics). Question: how were they lowered, or did he simply mean that they were towed astern?
  10. Good to see you back at the workbench, Robert. Lovely work, as ever.
  11. Le sabord flottant has vanished! Where will it reappear? Coming along nicely, John. Bon appetit.
  12. Check out watchmakers' tweezers on eBay. I've collected a variety of shapes that can do things that would be impossible with fingers alone.
  13. Ah! Now I understand why the companion ladders are the S-shape they take. It now makes sense. Lovely progress. What is the box that looks like a ticket booth?
  14. Many of us know all about age and arthritis. I find a selection of watchmakers' tweezers invaluable. Regardless, your work is terrific!
  15. I agree that properly proportioned belaying pins on models are the exception rather than the rule! My own workaround was to make the pin in two parts: the straight shank and the contoured handle. The handles have short pins for insertion into the rack. Of course Remco's and your own solution to turning small diameter parts is far more elegant!
  16. I would defer to an expert such as John Harland. I retract my statement of 'bogus'! Thanks also to Robin for his observations on French contemporary models. I'll go back to my corner now.
  17. This painting in the RMG (misidentified on their web site!) shows ensign and jack clearly. The correct description is given below: An 18th-century Royal Naval brigantine, flying the red ensign, a Union jack at the bow and the pendant of a ship on independent command. It is off the coast, which can be seen on the far left. The ship is a two-masted, square-rigged 10-gun sloop of war in port-broadside view, with a figurehead at the bow. The mainmast carries a lateen driver, furled to the lowered lateen yard. To the left, three officials are being rowed out to the ship, where men on deck prepare to meet them. Two other vessels in full sail can be seen in the distance to the left. The painting has been signed and dated 1752. Cleveley was a professional shipwright, who worked in Deptford Dockyard, as well as a painter. He was an early exhibitor at the Free Society of Artists in London and two of his three sons, John Cleveley the Younger and his twin brother Robert Cleveley, also became painters.
  18. Quarter davits are, I believe, an early 19th century development, so I agree with Dan's comments. I am completely puzzled as to why a kedge anchor would be stowed in the mizzen chains (awkward!), far from the apparatus for raising or lowering anchors, never mind the stowage of their cables. My feeling is that this is bogus.
  19. Yup, exactly. The link is a long tapered triangle with an almost closed circle around the bolt. Incidentally, your bolt heads look a little large. Take a view of, say, photos of Victory in Portsmouth to see the proportions of links to bolts.
  20. Nice going, but check the shapes of the toe links.
  21. Is there no end to your talents, Michael? Nice watercolour sketches! And you have 'spare time'?
