druxey
Everything posted by druxey
  1. You might have better success in the smallest sizes to use a much more fine-grained wood.
  2. There were often variances between different ships of ehe same class, so your finding is not unusual. What program are you using, BTW?
  3. Further to Keith; no metal on gunpowder barrels! They were bound using withy, a kind of flexible willow cane.
  4. A very nice offer, Allan.
  5. Just catching up on your work, Peter. Nice and crisp!
  6. There is a slight narrowing in the aft body along this section so, if the second photo shows the aft end to the left, this would account for things. However, if the aft end is to the right.... In any case, the angle would be slightly less than your trial set-up, I think.
  7. Is the blade jamming as it has insufficient 'set' or is too fine-toothed and heating up?
  8. You are a braver man than I with those catchy things whirling around! Two points: one, hard to see, but the lay seems too loose and two, if properly laid and hardened, the rope should not unravel when cut.
  9. I find getting these 'just right' the hardest challenge in a model, as they curve in all planes. Looks lke you've conquered the problem beautifully, Siggi.
  10. While the base and stand is another masterpiece, I find that my eye is drawn to the shiny and away from the model. This may be heresy, but would chemically darkening the metal be something that you might consider?
  11. Looks a bit Rube Goldberg (Heath Robinson for the British reader!) to me, and a bit scary. My reaction is similar to Bob's....
  12. I'm sorry to read that your brother has to retire from the hobby, but appreciate his equipment being offered to continue the tradition elsewhere.
  13. As Greg suggested. Sometime I use rubber cement to 'glue' down pieces. The only drawback is that it does not hold well in shear, so if you are planning on heavy cuts...
  14. I had a second hand Dumore (not Cameron) for some years that I bought on eBay. I had to re-wire the very aged cord and I stripped down and re-sprayed the casing. It worked very well, but I used it so little that I sold it again.
  15. Yes, some adjustment is needed for this to articulate properly. Does the port side seat back sit as it should? Certainly you are taking care: the use of shims nicely demonstrated!
  16. But you must be so practiced with chocks by now....
  17. If you aren't happy and have used white glue, an application of rubbing alcohol will debond the joint and you can re-do it. How do I know this?
  18. You might try a hot iron, pressure and moisture to bed that garboard down more. Make sure the iron is not too hot, though!
