Bedford
Posts posted by Bedford
  1. More nice progress!
    As for filling/sealing, I reckon you can't go past epoxy. You don't want to be paying a fortune for it but you should be able to get small trial packs. You can get really thin epoxy like everdure which goes on thinner than varnish and is easy to sand the furry first coat before doing a few more. If you get some normal epoxy you can thicken it with "Q cells" or similar. This makes an excellent easy sanding filler.
    I know Boatcraft in Aus do trial packs of the above with their Bote Cote epoxy system.
  2. 3 hours ago, Ian_Grant said:
     "Yes, everyone that works with saws has had stitches"  Haha.
    Now you've got me worried, band saw, chain saw, circ saw, jig saw, scroll saw, super sharp model making saws and various hand saws and to date, no stitches in 61 years. What's around the corner!!! Mind you I have left a few drops claret in most jobs in one way or another.
    Glad your injury wasn't too serious though!
  3. 4 hours ago, KeithAug said:
    I am aware from photographs that the original riveted hull was replaced with a welded hull
    I think that's somewhat a shame, modern bureaucrats killing off old skills. Here in Aus the Sydney Heritage Fleet recently relaunched the steam ship John Oxley after 30 years on the hard. All hull plates have been replaced and RIVETED as per original, they did the same on the James Craig and S.T. Waratah has a riveted hull too. The governing bodies really should recognise and allow historically correct work on these vessels.
  4. Interestingly, in the book Hand, Reef and Steer by Tom Cunliffe he states that the jackyard topsail should be raised on the port side only. Although it will not be as efficient on the port tack it still works and the reasoning is simple bearing in mind he would be referring to English vessels with a job to do, short voyages and not many hands. The sail has to be raised and lowered on the lee side of the rig for obvious reasons and since doing so is a busy affair you don't want to have to leave it to tack away to avoid another vessel. Having it on the port side means you raise or lower it when on a starboard tack and therefore have right of way over other vessels.
  5. I'm nobodys hydrological engineer (don't even think that's the right term) but I'd imagine that the oars sweeping in a fixed test like that will mostly stir the water into eddy currents and not result in much in the way of thrust but when on a floating boat they will work more as they're designed to which involves moving the boat rather than moving much water. I think it may surprise you.
