md1400cs
Posts posted by md1400cs
  1. Patrick.
    As always so excellent - my desire is to understand, learn and be able to actually detail in scale as you have - In my next life 🙂.
    PS: Have not posted at MSW in over a year -for my log -  but need to - not much but 🤔 on my list.
    I (we) have so appreciated you logs over the years - I've  learned so much from your skill set....thanks!
    MJD
  2. On 8/1/2025 at 11:30 PM, Kevin said:
    The shaped inserts come with the kit, the handles per the instructions are shaped dowel, but i used some out of scale belaying pins
    Excellent - your log will be a "must go to" when the 1/35th is ordered and received. Very nice work!!
    Regards,
  3. Kevin,
    Great work !!! - I saw your image on "at a glance" -- Did you add the oar hole covers, or did those also come with the kit? Nice detail.....
    I'm waiting for the 1/35th to be available in the US - shipping directly from the Ukraine is very "OUCH".
    Again great work - looks awesome indeed.
    Need to get back into this hobby - been MIA for too long......
    Cheers,
  4. Evan,
    I am very much enjoying following your build You’re also doing some great extra detail work as well.
    As a kid, and as a teenager I grew up, of course, with plastic cars and airplanes. Looking at your work in this medium is inspiring, and adding great personal memories.
    Excellent work and log. Your Titanic will be awesome indeed.
    PS in my opinion this ship does need to be built from plastic — PS 2 are you going to install real wood decks that are available for this kit?
    Cheers
  5. On 10/12/2024 at 6:28 AM, Ronald-V said:
    Small update:
    I have the main gun deck finished as far as planking is concerned. I am now busy sanding it...first with grid 180 and then with something finer to finish it off. I will be busy with this for a while. It does feel like a bit of a milestone again, that I have completed the two largest planking jobs of this ship.
    With the sanding it seems like you are losing the caulking between the planks a bit. I know that this is temporary and will come back later with the WOP (just like with the hull). But I couldn't resist taking a peek at what is under all that sanding dust by wetting the planks a bit (the same effect as the WOP will have).
    I have to say that I am certainly pleased with what I see! It is a pity that it will take a while before I put the deck in the WOP. After I have finished sanding I will place the spirketting (and maybe the waterways) and follow the manual from there. That means continuing with the outside (quarter galleries etc.).
    Placing the deck in the WOP is only done after I have placed the coamings etc (at least...this seems to me the correct order? If anyone has a better idea, please let me know)
    And I bought some new toys. I'm happy with them! I'm aware of the limitations of the table saw compared to its bigger brother. I've done some research in the past few days to find out what suits me and my budget at the moment. This saw perfectly meets my requirements for now. I've played with the saw this morning and it's more accurate than I thought! I could saw 1x1mm strips from a large board without any problems. And it stayed true to size :)
    These tools will make some things easier for me.
    I've had both of these for years - always perfect - I also, more recently, bought the large Proxxon Fet saw - probably "overkill" for my needs. Still mostly use the KS 115. But the larger saw is fabulous for angle cutting as the table swivels as well!
    Your work is so excellent you might also want to consider the Proxxon MF 70?? a very excellent addition.
    Regards,
  6. Hi,
    It’s been a while since I’ve checked-in as well as posting any updates. Been busy with other bits of my life. But, very lately, having found some disposable time I have done further work on this so far “lifelong” build.
    Some thoughts - 🙂
    1)   I know hinges should be black along with other bits as well. I chose leaving the hinges brass purely for their looks – given this ship’s hundreds of other bronze parts, and that this project bears very little relationship to any historical accuracy. as I’ve mentioned before…….
    2)   But, I am regretful that the gun ports (doors) appear a bit too thick. I had overlaid thin strips above some other matching wood strips that I had available, and cut to size. No other (to me available) wood matched the very light outer hull planks that run the lengths of the lower, and upper-gun decks. And I don’t have a wood strip sanding drum. So be it….
    Thanks for your continued interest.
    Regards,
    1.thumb.jpeg.833d402eb51fc6f400fffcd6e2587edf.jpeg2.thumb.jpeg.04caedb00530ac3419bc431b0d12c547.jpeg3.thumb.jpeg.8b7d85855ecfb3c6241bfc7647b7280e.jpeg4.thumb.jpeg.50b8eadf90924a871d5147629aa395e2.jpeg5.thumb.jpeg.48f85c6596b3dc8bd6a39187d255460d.jpeg6.thumb.jpeg.91ef4494a6d0272d3343a4f07740a091.jpeg7.thumb.jpeg.454fe224d652abc7b01f4b9fb77d5902.jpeg8.thumb.JPG.6e448d8aee78384f2d0cc6b623121d59.JPG9.thumb.JPG.828f5add94a62a698247aa88d57be5aa.JPG10.JPG.693fc4eb6822ccfc82c81e72c598ff45.JPG11.thumb.JPG.3995e330e1cefd43829f6a8b9f85f024.JPG12.thumb.JPG.5c45a0f52cb06cfd5583c34e15d799fa.JPG13.thumb.JPG.b5504fa64eab7cf10cfd3834e0bcbf87.JPG14.thumb.JPG.d7c6acceb7915130f1ff3c30d3b9e1b7.JPG15.thumb.JPG.a86f9bb7bdc96546ce6ab6abf7f554b5.JPG
  7.  Such beautiful work - builders such as you rise to the occasion of such a complicated build given that 1000s of images of this ship that are available (helpful indeed - but those details are beyond my skill set)  that said, errors then could become issues 😬 Not for you - perfect - my skill set will never  rise to your great build — Big cheers to you 😊
    We all have our comfort levels. Your work in this log has been SO appreciated - enjoyed following 👍  PS: when I was working I had a few days layover KLHR that - of course - put me on a train to Portsmouth - and Mary Rose before the museum was rebuilt to its current great rebuild..
    Cheers
    MJD
  8. Hi all,
    It's been a while since I've had an update to post. Finally completed the installation of the guns to their four upper weather decks.  added quoins as well
    Here are a few images.
    Thanks, as always, for dropping buy for a look - always so appreciated.
    Cheers,
    1.thumb.jpeg.7149965fd094878519b306c5a3955238.jpeg2.thumb.jpeg.afecd38a894e256d2131f965d114eace.jpeg3.thumb.jpeg.7bec4c3eade909adce6c8c6ac31e7468.jpeg4.thumb.jpeg.66ca69c7b33054b593e3b48fd7861fa9.jpeg5.thumb.JPG.725e2381e332c4acd35acbd4c9e5a275.JPG6.thumb.JPG.a6fc4d232deb55d335449cfdfb631830.JPG7.thumb.jpeg.1132cfade3a0549bfce19e25c573827b.jpeg8.thumb.JPG.e7f8e55fa782a3bb8c8c92b019f50aa7.JPG22.thumb.jpeg.2d67eb67874f2016112a4ab67ec5683e.jpeg
  9. Peter,
    Went back and stared in wonder at all the incredibly well done image details. Close-ups occasionally enhance mistakes  (well in my case 🤔) - In your build they absolutely capture the obsessive (a Huge compliment)  attention to scaling absolutely every bit of this projects to perfection - Big Cheers,
    And as Julian just posted - yes museum quality - possibly beyond actually......
    Regards,
  10. OC. thanks as always - happy that you dropped by as well.
    -- Been much away from the shipyard as well as from home base for a while;
    I did finally, however, finish stropping the many lines for the gun carriages. My recent focus was for the ten main deck larger carriages. Here are a few images - Next up is securely positioning the carriages then attaching all lines. Then onto the hull gun doors - I think??
    Again thanks for your visit - this log is a real slow one indeed.
    Cheers,
    1.thumb.jpeg.ae66dd66d56785a4c0cde20dd5e8938f.jpeg2.thumb.jpeg.232fa1df8a4209abbd934aae024464cb.jpeg3.thumb.jpeg.595773f6f73d8ee3fc6d62a68936de4b.jpeg4.jpeg.4edb4dd5f99cc531e095045479cc97b7.jpeg5.jpeg.242e29d2999aa807ad31033201334651.jpeg
