Everything posted by md1400cs
Frank, Nice work on the davit. Thanks for posting the measurements. I went back to check mine and, as I thought looking at Landström's drawing, mine are too short. I will use your measurements and re-cut mine. I will also follow your lead and only install one. Nice research. PS: regarding mounting it Hmmmmm Mark is certainly right (:-) but in your case very understandable. Regards, Michael
Hi Mates, A small update. Finally working on the carriage pulleys and ropes. What I thought would be monotonous has in fact been fun. I worked out, I think, a way of attaching the double pulleys to the weather deck in the same fashion as seen on the Vasa museum carriage reconstruction. I will work with bits of toothpick ends to fashion the braces. Kudos to Syrene for Chucks excellent ropes and pulleys (:-) Thanks so much for all of the "likes"as I slowly move forward...... Regards, Michael
Mark, Very nice and cleanly detailed work. I have been downloading some of your pics as a reference when I get there. I hope that you don't mind. Regards, Michael
Frank, I'm happy that my idea worked out for you as well. Finishing the rigging, and mounting are my priorities for this coming week. I need to move forward... Michael
Frank, Chainplates look excellent. Nice work, a bit of work but certainly worth the effort. Michael
Ulises, Thanks for the nice words, as well as your visit. If I can get near to your level of rigging quality, as your Vasa I'll be very happy. Seems as if the Corel plans are acceptable. A new updated kit would be great.... Michael
Nigel, Thanks so much for your very welcomed words. I have learned a lot from you, and I have happily incorporated your thoughts in this build. You, as you know "fixed"my carriage wheels (:-) (:-) Cheers. Michael
Peter, Thanks again for your nice thoughts. Kind of you to follow along much appreciated. So much more information has surfaced regarding this ship, and with the Vasa II book coming out later this year, you will certainly have much new easily available research. She certainly is an interesting build. I assume that this time you wouldl build one other than the Corel? PS: Fred Hocker, the director of the Vasa Museum has mentioned that they are in negotiations with a company interesting in creating a Vasa kit. Who knows how far these ideas go, but...... Regards, Michael
Ferit, Thanks for the idea. I went back to your Berlin just to look at the cannons, Gee I ended up reviewing your entire build; doors, sump pump, barrels, furniture, carvings and on and on....Please take it out of "moth balls" and get back to this beauty. Regarding the belaying pins that great idea is really too late. I need to go forward to carriage blocks and ropes, and then building the lower and upper deck cannon doors. (:-) but thanks for visiting, its always nice to know that you are still interested. Regards, Michael
Matti, Your blend of subtle mixed shades of wash for your hull, as well as your use of red, along with your hand carved sculptures really make your build special. A pleasure to look at....Your latest photos really captured this (:-) Good luck with the rigging, I know that you are (maybe most of us) not that comfortable entering this stage, as you have mentioned. But it will work out I'm sure. Regards, Michael
Lawrence, Thanks for your kind words. I'm in the process of disassembling all the carriage axles and following Nigel's brilliant solution to the errors that I noticed after installing all of the wheels. I have an incorrect space between the wheel washer and the axle pins. Nigel suggested that I remove the axles, cut them in two, remove the spacing gap and re-attach each axle in two parts. Looking much better. Note the main pic from left to right before and after. Nigel if you happen to read this A BIG THANKS my friend, as usual very sage advice. Regards, Michael
Mark, Yes the rigging does have some mysteries. As Matti was saying the rigging did not survive so some of the details would be guess work. At the end of the day, I would not stress too much on some of your conundrums. There is no empirical example for the Vasa rigging. Though Clayton's should be as perfect as it gets. ---------------- You are way ahead of me so this head-ache is not yet mine. I am falling into an abyss with constant doses of procrastination. In any case I will follow your lead, your rigging looks so excellent. I also believe, in my case, that the Vasa II book will be in paper-back by the time that I'm ready to attach the first line (:-) I am also patiently waiting for the book. Did you visit the Vasa specific site? Fred Hocker describes the contents of the book chapter by chapter. It will be a Vasa rigging bible. I also understand that there will be sheet plans for adding sails. Though from your research it is nice to know that you think that Corel more-or-less got That part right. Again, your build is so beautiful. Regards, Michael
Andy, I washed the gilded pieces with dish soap. After drying I used standard flat paint for model kits from Model Masters, Testors, and Floquil. The last brand is primarily used by model railroad builders. Stripping is unnecessary. The only variable is time. I don't know how that will affect the decorative pieces, as I did not use a clear flat sealer. Good luck with your "hybrid" Michael
Karl, Super nice update. Your rigging work is very nice. Michael
- 234 replies
Mark, Excellent work. Your rigging is looking great. Your chain plate lines are perfect. Very very nice. Michael
Karl, Always a huge pleasure drooling over your updates. Absolutely stunning artistry. Your second cross section within is awesome. Michael
- 662 replies
- bonhomme richard
- frigate
Frank, Looking very nice. Channels are excellent. Again I'm so envious of your lower and upper installed gun carriages (:-) They will look so good after you install the dummy barrels. Michael
Congrats Buck, Awesome view....Settle in and we will be happy to see your new posts. Michael
- 515 replies
- artesania latina
- whaleboat
Jan, Good luck with the mast preparations. Unfortunate, but not unexpected that Vasa II would be delayed. However, from everything that I understand it will be a HUGE help for Vasa modelers. I'm sure that you have read F. Hocker's description on the Vasa specific web site regarding the book's contents. Your ship is looking excellent. This ship is becoming a popular build at MSW. Regards, Michael
Yes, Zizou still a headache depending which side you are on. Best player ever in the world, hmmmm - Pelè quickly comes to mind. We met Pelè years ago. We had dinner with him and Emerson Fittipaldi. They happened to be in LA at the same time and Eliana's best Brasilian girlfriend was a close friend of both of them. And she asked us to also come for dinner -SO lucky- Both before your "time", but of course you know who they are. Good luck next week. Let's see how your headache, Spain, does on Sat. Cheers Michael
