Everything posted by mtaylor
Welcome to MSW, John. I'd suggest you start a log on whichever model you wish to build or finish. It's a great way to met others and also to get advice.
Like Keith, not sure on thumbs up for fixing the issue or a sad face because of the problem that happened. I do think you'll be happier with the improved legs.
Thou hast more patience than most mere mortals, sir. I doff my hat to you. The rest of us I think would tearing the box open and setting it up
If you haven't seen it, we now have an area for 3D printing and laser cutting. https://modelshipworld.com/forum/172-3d-printing-and-laser-cutting/
- 321 replies
- Finished
- Flower-class
I've got the Domanoff and while it works, it takes a bit to get it working right. I've not done anything to show as I was just testing it. Reports are the Syren works well and is very reasonably priced.
Any other Glowforge laser cutter/etcher users?
mtaylor replied to Tim Holt's topic in 3D-Printing and Laser-Cutting.
I did that myself intentionally for my Belle Poule carvings. They're so tiny that the char was leaving next to nothing to carve. -
French 8 and 12 Pound Gun Carriages - Laser
mtaylor posted a topic in 3D-Printing and Laser-Cutting.
I don't have much "generic" for the laser. Most is for a specific ship. These are 1:64 but can be scaled as needed and in CorelDraw format. Cannon Carriages.cdr -
I'm not a Glowforge user but I do have a laser. I've found the slow and low seems to work best though there are happy spots with high speeds and higher power. Also, after firing up the laser and before trying to cut, I run a test piece of the same wood and thickness through just cutting some straight lines and dial in from there. As for multiple passes, I don't recommend them as a laser isn't an entirely straight cut. If you look close, it's a "V" and the "V" gets wider with the more passes one makes. The times I've had where the laser didn't cut all the way through I've been able to salvage the part with a scroll saw and a very thin blade. Depending on the laser and the amount of use, I find it wise to check the mirrors for smoke residue. Periodically, they do need re-aligning which again depends on use. -
David, do a search in the kit area for Mary Rose. There should be some logs. There's also this area that might help you find some. And do open a log of your own.
That will probably work best. Acrylic really has no odor to speak up so you just want to keep the 'dust' from getting to the rest of the apartment/house.
You can also use a curling iron. With just about any tool used for bending that involves heat, you'll still need to hold it in place. I prefer the heat method using a curling iron, a hair dryer or heat gun. For hair dryer/heat gun I use a piece of scrap wood with pins stuck in it to the shape I need. Go here and see post #2. Near the bottom is a video on how to do it. https://modelshipworld.com/forum/18-modeling-tools-and-workshop-equipment/
I use a sheet of plywood that fits my window with a dryer hose attached to vent outside. Hole in the plywood for the hose and mounting piece. True it connects to my laser but when I my one plastic build, I did the small spray booth thing with a small cheap fan to suck the air from the box and blow it down the dryer hose to vent out side. When I was done, the box I used for the spray booth hit the trash, the hose and window wood back to the laser and fan... well it's nice to have in work shop to move some air around. Lots of ways to skin that cat, so to speak. Just need to find the one that works for you.
You mention the bed going out of level during use. I know zip about this tech but for the bed level.... what sets the level? Screws? I'd assume (or at least hope) the was some locking method like lock nuts or similar.
- 460 replies
- Finished
- Flower-class
How to access the digital NRG JOURNAL?
mtaylor replied to Zzzz's topic in NAUTICAL RESEARCH GUILD - News & Information
Go to the top of the page and look for NRG Home Page. The journal is on that site. Here's a direct link: https://thenrg.org/journal -
New member from the North Atlantic
mtaylor replied to Thukydides's topic in New member Introductions
We old fossils surprise ourselves LOL. Don't sell yourself short. The rational for him is excellent. While I'm thinking of it.. you can also make parts for your existing projects......
- 321 replies
- Finished
- Flower-class
Where should I post a restoration?
mtaylor replied to Icarus24's topic in - ** Read before you start your Scratch Build Log**
All restorations are usually put in the Scratch area in the appropriate time era. Also, add the key word to the end of the title "RESTORATION". We get restoration logs for many different models of varied quality and accuracy so don't sweat that. All ship models are welcome as well as builder of all levels. -
You might as well jump in, Lou. He'll probably be asking you for help with it (or not). Besides, you might find it useful one of your builds.
- 321 replies
- Finished
- Flower-class
