Everything posted by mtaylor
That photo has a "wow" factor all it's own, Keith. Between the lighting and resolution and build skills, it's just incredible.
Glad to help with the memory, Gray. I keep mine near at hand just because the mental memory chips sometimes short out. I'll add a link here, but for a different souce. Not very well illustrated but I've found it useful: https://webarchive.nla.gov.au/awa/20110215215247/http://southseas.nla.gov.au/refs/falc/contents.html
It seems that "klinken" could be "clench" in English. Several ways to clench a rod/bolt especially if it's not threaded for nuts. Bending over the end and hammering it was common before bolts were mass produced. The word "rivet" implies (to me anyway) that the end is hammered such that it's flat and not bent and done in past with the metal being hot. I may be wrong but that's what it sounds like. Words do change over the centuries and as technology improves.
Now would be time to teach him how to do it. Good idea on the testing. I'm glad it all worked out.
- 194 replies
- Bottle
- Treasure Fleet
(and 3 more)
MSW down in UK on 25 July 2022?
mtaylor replied to Rik Thistle's topic in How to use the MSW forum - **NO MODELING CONTENT**
Andy, you're not the only one who doesn't use Facebook. Yesterday (and other times things didn't go right), I just check every few hours. Usually, the downtimes are minimal but yesterday wasn't normal, IMO. -
Welcome to MSW, John. Allan is offering some advice and it's good. However, start the kit and a log and if you run into issues you can't solve, back off and try one of the kits he recommended and then go back to your tug.
So far, so good, Bob. What Pat but I'd suggest a step further.... get the screws/nails below the groove in the miter box. If you notice, the base grooves are different sizes to accommodate common size of wood for the box. Once you get the hang of it by using it, you may decide it doesn't need to be screwed/bolted down. One side of the of the tool sits lower than other so you can set on the edge of a workbench and then hold it in place while cutting. Never mind I just saw your latest with some wood laid inside.
- 179 replies
- Second Build
- Pinta
By all means, what Chris said. It's an older kit, probably has been updated I would hope to laser cut parts.
F-86F-30 Sabre by Egilman - Kinetic - 1/32nd scale
mtaylor replied to Egilman's topic in Non-ship/categorised builds
Bingo... the master at work and success. -
I think that one is perfect for almost all of us.
- 194 replies
- Bottle
- Treasure Fleet
(and 3 more)
That's good news EG. I hope and pray the second opinion goes the same way. I ran into a similar situation where they found a fog like thing in a lung. First specialist saw it. Second one... it's was gone. And has stayed gone. -
Thanks, Sam. I cut them and planked using the methods in the planking tutorials.
- 505 replies
- vanguard models
- Sphinx
Good post, Pat. We've seen that here in the States also but not the "bonuses" part. The current Postmaster General (the big cheese as such) had removed some office's sorting machines, shut down overtime for the workers, and extended the delivery times. And... the prices went up naturally. I realize there is an increase in costs due to fuel prices going up in the last 6 months or so, but like everything else, the prices go up and seldom, if ever, come back down.
Take a deep breath and an adult beverage, Grant. I suspect there was more tension in the air than you let on.
