Everything posted by mtaylor
I just used PVA straight from the container but then my current build is the first one I've done in a long time that was double planked. I would think it depends on the length of the plank and how quick you can apply the glue and set it into place before it starts setting up. The other issue is that water may cause the plank to "warp" away from where it will be applied to the first layer. Depends on how much water you use to thin it. If you have extra planking, test to see what happens.
I have one of their corded types and it's now my goto rotary tool. Light multiple speeds, but it does have low torque. For bits, I have pile like what Gaeton shows (bottom photo) and also a large selection of dental burrs that I found on Fleabay. The burrs are perfect for carving work.
Got the camera back yesterday but too busy with other things. I'm sorting out the gangways. Seems to "alternative" ways of assembling them and I think i'm going with the "do the knees first" and then the other items. A bit of painting and some fettling of parts are in order. Here's a couple of photos showing where I'm at. Ignore the mess as it's very much a work in progress.
- 505 replies
- vanguard models
- Sphinx
I agree with Druxey. If there's mould on the outside, there's probably a boat load (pun intened) on the inside and that's a real problem to get rid of.
- 16 replies
- hull repair
- Hudson Bay Company
La Palme by Tobias - 1:36 - POF
mtaylor replied to Tobias's topic in - Build logs for subjects built 1501 - 1750
Love the "helper" sitting there patiently.. The framing is coming along nicely. -
Better it was "soup" than "soap". I'll go quietly to find an open chair for this.
- 194 replies
- Bottle
- Treasure Fleet
(and 3 more)
My First Kit Pick Ups.... Beginners Kit Recommendation?
mtaylor replied to DeHammer's topic in Wood ship model kits
Well, the basic rule of thumb is to start with minimal rigging. I'd say, start the Dana and a build log and go from there. Others will suggest the ModelExpo beginner's models which starts with one with no rigging. Billing's kits can be daunting for sure but as Chris said, do a search in the kit logs area as you can learn a lot from them. -
Welcome to MSW, Daniel. Do feel free to open a build log for your model. It's a great way to get help and meet others.
Byrnes Saw Mini Sled
mtaylor replied to Roger Pellett's topic in Modeling tools and Workshop Equipment
I've used this phrase myself. I do have a question.... what does the winner win? Is there a trophy? A participation medal? -
What's a good kit for learning rigging?
mtaylor replied to Mark m's topic in Masting, rigging and sails
Just time and the purchase price. It is a good way to learn though rather than using a large expensive kit. My first rigged model was the old Scottish Maid from AL. It was just couple of steps (hindsight says "big steps") between that and my next which was the Wasa. Back then, there was no MSW, so no one could I ask questions to. -
Welcome to MSW, Open a topic and post your photos of your uncle's models in Nautical General Discussion area. And if you're starting a model, open a build log.
Good one, Glen. Camera should be back by Saturday. Needed a part and a good cleaning internally.
- 505 replies
- vanguard models
- Sphinx
Very well done for parts microscopically small. The muffin cups are a good idea. I went a slightly different route and found plastic "snack cups" that come with lids. Leave the lid off and they too can be staked. I tend to use the lids as every so often, one gets "bumped" and parts scatter on the work bench.
- 13 replies
- Dom Bumagi
- Admiral Nakhimov
Good solution on the sanding stick. You might also look into the bendable fingernail files. Usually both sides have the sanding media over a "foam" core. Reasonably stiff yet flexible and available in a wide variety of grits. I found the best way to buy them is from a beauty supply shop as they cost less than from other shops.
- 63 replies
- Finished
- Khufus Solar Boat
The build continues but the log is on hold. The camera died and it at the shop for repairs. Cheaper to repair than buy a new one.
- 505 replies
- vanguard models
- Sphinx
M3 Lee Tank by CDW - Miniart - 1:35 Scale - FINISHED
mtaylor replied to CDW's topic in Non-ship/categorised builds
Looking at the one truck you have finished, I don't think it's over-engineered as like the rest of the model it looks great.
