Posts posted by MrBlueJacket
Started to fit out the rear boom. Interesting that on the bottom of the boom there is a block and tackle setup that apparently goes nowhere. I seem to recall (and correct me if I'm wrong) that it is a tensioner to help prevent hogging of the boom itself.
In the Penobscott Marine Museum there is a schooner model with the same setup, belaying to the jaws.
- ccoyle, BenD, Roger Pellett and 9 others
- 12
- John Ruy, Keith Black, Beckmann and 7 others
- 10
18 hours ago, Roger Pellett said:
What material are you using for rigging. It does a good job looking like galvanized wire rope.
Roger
It is .015 white cotton line, painted with a silver paint stick
- Keith Black, mtaylor, Canute and 1 other
- 4
Very nice. And a quick build, too! Your customer file now shows a 10% discount off your next kit from us.
Nic
Regarding the line on the jumbo sail, to me it looks like a reef line, but that is inconsistent with the reef points on the main. It is unlikely but possible that the sail was added onto at some point, which is cheaper than making a whole new sail. Other than that, I don't know.
I'll probably put a few furled sails on her.
Nic
- Canute, mtaylor, Ryland Craze and 4 others
- 7
Very nice. Your customer file ow shows you will get a 10% discount on the next kit you buy from us.
Nic
With a little keel weight, it should sail just fine.
Nic
On 5/23/2022 at 11:44 AM, Avi said:
I’d be happy to. I don’t think this build log is the right place for it. Is there a better thread, or some good place to upload them?
Perhaps the gallery?
We have had many requests to resurrect both the Maine and Olympia kits, but I believe that would be unethical and I won't do it. However, our soon-to-be-released kit of the USS Oregon will be open stock, and not limited.
Nic
- Azzoun, Ryland Craze, Canute and 1 other
- 4
A more detailed description of this water technique can be found at the bottom of this newsletter here:
- Tom E, GrandpaPhil, ccoyle and 4 others
- 7
So now it's time to make the water base. Start by making off the edges to where you want them to be, and scoop some spackle onto the base.
Then smear it sort of evenly over the surface. no need to be neat about it.
Unfortunately, the next step photo didn't come out. You put on a vinyl glove and slightly wet it. The tap on the spackle to make a wave pattern. If you don't like it, wipe it off and do it again. when you're happy with it, wrap the hull in saran wrap and press into the wet spackle. This photo is the result. Let it dry
Glory of the Seas 1869 by rwiederrich - FINISHED - 1/96 - medium clipper
When doing the chains for the Red Jacket, I first tied fine sewing thread to the chain, then stiffened the other end with CA glue. I think you will find it much easier.
Nic
