Posts posted by Old Collingwood
I remember that kit in the Airfix catalogues way back (cough cough) it was a well respected kit back then - and now has so much potential.
OC.
"Why do flat clear coats have to be a pain in the neck and bain of my life"?
Evening all - yep that subject again - I have been trying in vain to flat the finish of my Vallejo Acrylic paints uisng a bottle of Vallejo Matt clear top coat varnish - tried everything - thinned it using distilled water 40/60 as suggested, applied it in thin coats allowing drying time before re applying, even added some Vallejo Matt Medium as this is supposed to dull Vallejo items like paint and top coat - still no good the paintwork is refusing to dry anything but a satin finish.
I understand certain paint colours of Vallejo tend to stay a satin colour depsite being a matt paint - namely red and blue (something about the pigments)
OC.
- popeye the sailor and Canute
2
Evening all, some more progress today - I have decided to place a few KGL 5th Light infantry in my dio, thease were sent down along with the 5th Line regiment to bolster the members deffending the Farm, they differed from the Line regiment as they did mot wear back packs, the figures I have are un shaped on thier backs ready to take the back packs, so I have had to do some shaping to put some extensions of thier belts, quite a fiddly job requiring scraping the backs to form belt lines.
After priming with Vallejo Black surface primer I then started with the Red layers (this has been darkened with dark Brown to make it more brick Red than bright Red) then I painted on the Off White belts including one in dark Brown.
Time consuming but steady trying not to mess them up,
OC.
Very well done, she looks beautiful.
OC.
- ChrisSC and Ryland Craze
2
Superb work engineering of excellence in minture.
OC.
- Keith Black, mtaylor, BobG and 4 others
7
I see, so you still have to shape them yourself?
OC.
Very nice work Edward - love what you are doing with shaping around the center hatch (very clever and tidy idea) I appreciate what you are going through with the decking mine was the same on my Greyhound build.
OC.
- FrankWouts, Jack12477, mugje and 2 others
5
1 hour ago, Edwardkenway said:
Looking at your French troops I now remember why I always used to let the French win my childhood battles, as they often did till they met Wellesley's army!
Inspiring painting OC, makes me want to get back into wargaming and figure painting 😏
You should my friend - its a great way of killing time hours just float away while I'm at the table - also you dont need much room.
OC.
- popeye the sailor, mtaylor, Canute and 2 others
5
- EJ_L, J11, GrandpaPhil and 22 others
25
27 minutes ago, VTHokiEE said:
Thats looking super - some times the cannons can look too large for the deck - but not with yours they look really nice, sh eis coming on fine.
OC.
- Edwardkenway, BobG, Ryland Craze and 3 others
6
- Canute, Egilman, Edwardkenway and 5 others
8
1 hour ago, Roger Pellett said:
OC, Does your wife have nail polish remover in her stash? It’s probably acetone.
Roger
No worries now Roger - problem solved.
OC.
- Egilman, mtaylor, Roger Pellett and 2 others
5
4 minutes ago, mtaylor said:
I've just now found and wandered into the shop.... The jig alone is a project. Looks like everything is going well, from here. I'll get a seat for this.
"Cough cough - and the popcorn"😉
OC.
- Edwardkenway, mtaylor, Kevin and 3 others
6
- Canute, popeye the sailor, Waitoa and 5 others
8
47 minutes ago, GrandpaPhil said:
Very nicely done on the painting, OC.
Thank you for popping by Phil and the compliment.
OC.
- Egilman, Canute, popeye the sailor and 2 others
5
You should add some Marines to your build 28mm British marines would look superb when painted😉
OC.
- Edwardkenway and mtaylor
2
Enter embarresed emoji - i used to have Two magnifier glass units - now I have none, my own stupid fault the Superglue I used ran all over the lower lens and ruined it.
Anyway with the money back off my clear coat and added a couple more pounds I was able to order a multi optovisor arriving later today.
OC.
Looking super.
OC.
- Canute, popeye the sailor, Baker and 3 others
6
22 minutes ago, Louie da fly said:
OC, I'm gobsmacked by the quality of the paintwork on your figures. My dromon oarsmen are pretty much the same scale as yours, but the paintwork on mine is much more basic and plain - I haven't the skill to do the kind of shading you've done.
(OTOH you didn't have to carve all yours!
BTW, I don't know if anybody's mentioned it before, and at the risk of sending you off on another tangent, have you read "Death to the French" by C. S. Forester? It's a novel about a rifleman who gets separated from his unit during the British withdrawal to the Torres Vedras in the Spanish campaign, and lives off the land fighting the French until their retreat as the British advance, and he is able to rejoin his unit. Fictional (apparently) but with fascinating period detail of what it must have been like to serve as a rifleman at the time.
Thank you kindly for the compliments ( after looking at them under higher magnification I can see many flaws that will need sorting) its that well know situation - the more you zoom in the more errors we find.
I will have to hunt out these reads - to be honest Im mot much of a reader - im ok with technical books - used to love the Janes series of Warship books.
OC.
Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
in Non-ship/categorised builds
The reason for brush painting the top coats is not all the figures needs to be flat - areas like the swords, hat plates, Cuirrasier helmet details and cuirasses breast plates need to stay shiny.
But thanks for the heads up.
OC.
