Posts posted by Old Collingwood
1 hour ago, Canute said:
I'm guessing the Focke Wulf you cite, Popeye, are the FW-190 and Ta152 series fighters. I'm a fan of them too.👍
The FW-190 was the reason the Spit got a new engine in the IX model so it could take on the FW as earlier models spits were out paced by the german.
OC.
- popeye the sailor, Canute and mtaylor
3
WOW, thats amazing work all that detail bringing a model to life.
OC.
3
3 minutes ago, Jack12477 said:
Both models finished are 2 ft in length, OC, takes a lot of bench space, even more to paint it....... have to do some thinking on this. That's why they are stll in my un-built stash.
Yep I hear you mate.
OC.
- popeye the sailor, mtaylor, Canute and 1 other
4
11 minutes ago, BLACK VIKING said:
Hi OC I used to live about 15 miles from West Malling when I was a kid and my uncle worked there during the war as a parachute packer . Small world.
Martyn
In deed it is mate, my dad was there between 43 and early 44, he then was moved to Norfolk to work on bombers and stayed into the Fifties where he worked on the first jet engines and also did some work in Oz doing diss-assembly of fighters to be crated up and returned back to the UK.
OC.
3
9 minutes ago, Jack12477 said:
Or a "skunk works" YF-12 Interceptor ?
Yep that would be good.
OC.
"Yummy yummy you cant not have a Spooky " Love em.
OC.
- BLACK VIKING, cog, GrandpaPhil and 7 others
10
5 minutes ago, BobCardone said:
Thanks, guys!
Yeah, this was built before I started doing build logs. Any future projects (ship and non-ship) will have build logs posted on the forum.
I am sure we will all look forward to that.
OC.
The detail is amazing Denis and more so at 1/72.
OC.
- Egilman, Canute, popeye the sailor and 1 other
4
Same as Denis said - looks really good.
OC.
EG "you are under the Plastic modeling Spell - there is No way to avoid it" you must you must build☺️
OC.
- Edwardkenway, mtaylor, Jack12477 and 3 others
6
Superb - wish you had or will do a build log on one.
OC.
- popeye the sailor, Egilman, Canute and 2 others
5
Good day all, I thought I would give a bit of back ground info on the reason for me building this - its about my late farther again, as well as his service on bombers he also worked on different versions of Spitfires and Hurricanes, he actually started on these before moving to heavier aircraft a year or so later.
So - he was based at a RAF base called West Malling (famous for its Battle of Britain use) he was a Airframes and Engines fitter and did various jobs on both Spits and Hurricanes.
This is again a build in his memory.
OC.
- Egilman, popeye the sailor, mtaylor and 1 other
4
She will be a superb model denis looking forward to more.
OC.
- popeye the sailor, mtaylor, Egilman and 1 other
4
Hi all hope everyone is ok, more work today - I continued with the cockpit sections, next off was the framing and a sub frame attached to it, very precise placement was required but they fell in to place well, I also drilled out a few holes in the framing and attached one part of the PE included in the kit.
Oh - I also sanded down the areas in the fuselage side where I had filled some of the injection pin marks.
OC.
12 minutes ago, BLACK VIKING said:
Looking forward to this OC . Stay safe m8
Martyn
Thank you Martyn, same with you and yours mate.
OC.
- mtaylor, popeye the sailor and Egilman
3
Some great research and a great start looking forward to seeing and reading more.
OC.
- lmagna, mtaylor, BLACK VIKING and 2 others
5
Evening all, So as I said - I have put Mossie away in a box and decided to start this, first off I looked over the spit-structions page one called for two sub assemblies that are lower hull wall sections that have a few fittings attached to them - lever's, covers and bottles, these were glued done then put aside, also I cut away the two fuselage sides - these needed the normal light tidy up and a pip cutting away, there was a few moulding holes that I filled with plastic putty, this was then put aside to set.
So I have made a start - its a very very nice kit very good accuracy and quality the dry fit join of the fuselages is excellent.
Sorry for the last pic - didn't know it was oof till after I took it.
OC.
Love those tanks - built a few Tamiya Bradleys and M1's great selection.
OC.
Love that cockpit.
OC.
Another excellent build - there was so much activity with B17's over this side of the pond during the war.
OC.
- popeye the sailor, Canute, mtaylor and 1 other
4
Just now, Egilman said:
Ahh... late to the party, but, I see the main attraction hasn't arrived yet, just being introduced....
Grabbin a seat......
More than welcome.
OC.
- Canute, mtaylor and popeye the sailor
3
I might start this later today, as I have reached a stall with Mossie due to needing to Rattle can but I will wait till the risk of spray fumes aggravating the admiral.
So I thought as Acrylic bottle paints give off zero fumes, I should be able to start building this and plan to get to the Rattle can stage for the frame sprays (with any luck things might have settled down in a few months time).
OC.
USCG UH-65A Dolphin by Jack12477 - 1:48 scale - Trumpeter - FINISHED
in Non-ship/categorised builds
Lou you could always fall in as winch man.
OC.
