Old Collingwood
Posts posted by Old Collingwood
  1. So  another spit on the go  - this time I am rescuing the ICM Spit IX  kit  and turning it into a Seafire Mk.111  as I believe they were basically the same  apart from a few mods that I should be able to create  - seam on the wing that would have been for the  wing fold, and scribing under the bottom rear to simulate the cut out for the arester hook,  I will also fashion a hook and fit it  semi recessed,    the rest is basically  built  as  the kit  IX.
    Reason I have chose to do this  is  during the war my father cut his teeth on Seafires  before moving on to RAF types.
    So here it begins with the already fitted out cockpit wall - I  added the paintwork (cockpit green)  and picked out the details then my normal  pencil for shading and white highlight,   I then closed both sides together  as the cockpit floor/seat/insrument consol  are made as a unit  and popped in from underneath.
    Here are the first pics.
    OC.
  2. Firstly  hope you are all safe and sound.
    Hiya mate,  lovely work on the second planking - its always hard to get it nice and tidy, as frankly I really made a dogs dinner of mine,   but yours has come out really well with nice tight joins between the planks.
    I know what you mean about different plank widths and even the overall  quality  - some can be terrible  with rough saw cut jagged edges, splits in them and as you say different thickness.
    With the liquid poly  I personaly would do it last after the wales are fitted and any  fine tune sanding was done,  I assume you are going for a  clean wood look without paint  (nice)
    Hope that helps my friend.
    OC.
  3. Hi all,   I did a bit more on the spit today  - next was to build the first of the two wings rads, these are five section units  - they were assembled then the rad filters inside were painted flat alum, with the indside bodywork cockpit green, there is then a rear adjustable vent cover that was fitted with an actuation lever in the open position, this area was also painted.
    After I used my pencil for some shading and white for highlighting.
    Just dry fitted will keep them off and fit after spraying the bottom.
    OC.
