Posts posted by Old Collingwood
This is different and very different - I like it. shame you aint got any creepy figures to go with it.
OC.
- popeye the sailor, Canute, CDW and 1 other
4
Looking good denis - I know what you mean about the masks "Have I pushed it down well enough to stop leaking from the paint" trouble lifting them agian after a few coats of paint.
OC.
Very nice work - so much involved.
OC.
1 minute ago, VTHokiEE said:
Oh there will be some happy pirate dancing when I finish this layer off. Planking was the scariest part of taking on this model and while it had a few hiccups along the way I think I can say that I’m comfortable with at least the process. With any luck I’ll have a update within a week 🤞.
I will grab a propper seat now I found this I remember planking my HMS Greyhound kit - it sent me nuts and seamed to take years to get anywhere.
OC.
18 minutes ago, SigEp Ziggy said:
It's looking good OC! I would think this confined to quarters would give plenty of time for modeling, however 'honey-do's' keep getting in the way!
Thank you kindly ziggy, its inside a storage box at the moment waiting on some time for me to carry on rattle can spraying, it was getting on the admirals chest (not good) due to the fumes, I will crack on with it when its right to do so.
Stay in good health and yours mate.
OC.
On 3/15/2020 at 6:47 PM, VTHokiEE said:
Time for an update, I followed B.E,'s advice and after smoothing the hull a little further I attached the stern post:
Next I started planking the transom, attached the counter and sanded it all.
I didn't know the best way to temporarily attach the spacers for the final plank, so I went with painter's tape and it seemed to work alright.
Then after some final sanding I think I'm ready (deep breath) to start the second layer of planking.
Very very nice - nothing wrong with that I would be really chuffed and happy like a happy dancing little Pirate.
OC.
On 3/11/2020 at 12:45 AM, VTHokiEE said:
Love the hull planking you have got some very nice close wood work there.
OC.
- VTHokiEE, Moab and KARAVOKIRIS
3
I will check out your Alert - should have done so earlier my appolgies.
OC.
I have found your build at last mate, love the framework and the detail going into lining and keeping the frames lined up - lovely work.
Reminds me of my first wood kit when I was working on the frames I wanted to over engineer everything to get a strong frame.
OC.
- Moab, VTHokiEE and EricWilliamMarshall
3
2 minutes ago, CDW said:
OC
Trumpeter does the Bear in 1:72, but the kit is a pig. It can be done to look quite well, but it takes a lot of work to get it there. Poorly fitting and lacks important detail. Then there is an old DML kit of it in 1:144. Don't know how good or bad that kit might be.
Do a Youtube search for Flory Models where he does the 1:72 Trumpeter kit. His video might be there. I have seen it on his paid subscriber site, but it may be available for free on YT.
Ta matem had assumed from the pics posted - someone was considering building one, never seen a kit but have seen the actual plane up close at airshows in the very very distant past.
OC.
Really really nice Jack well done finishing it, I have already put my hammock up in the garden waiting for your next one - in fact I like it already.
OC.
- Jack12477, Canute, popeye the sailor and 1 other
4
3 hours ago, Edwardkenway said:
I was thinking as a transport for 101st airborne on D-day
That would look really nice with invasion stripes.
OC.
- Edwardkenway, lmagna, Canute and 2 others
5
16 minutes ago, cog said:
You're building a late Mk IX, chances are it has hydrolics for those functions
I thought about building it with everything flush but thought it would be more interesting with things drooped.
This pic off the net shows a powerd down spit with stabs drooped and some movement of the rudder.
OC.
- BLACK VIKING, Egilman, cog and 6 others
9
56 minutes ago, Egilman said:
They were cable operated with a spring on the control stick to keep the stick basically centered, with serious usage the spring would relax a bit and allow the elevator, (horizontal stabilizer control surfaces) to droop a bit... The rudder would lie whichever way the rudder pedals were last touched as they were a push pull configuration and the ailerons on the wings would twist on the same basis depending on the side the stick leaned towards.... I'm not remembering exactly when they went to hydraulics on the Spit, but that was the case with the early built birds. But when they did go to hydraulics, the elevator droop would become much more pronounced as the hydraulic pressure bled off.....
Separate control surfaces in the kit allows this mechanical habit to be modeled accurately
I am doing mine drooped stabs slight rudder turn and level ailerons with the flaps in there locked up position (these are molded in with the lower wings)
OC.
- mtaylor, Egilman, popeye the sailor and 1 other
4
15 minutes ago, popeye the sailor said:
nice progress so far OC........not understanding the significance of tilting the stabilizer ailerons downward for the rudder, as they are shaped to allow for it.
Just a bit of builder artistic license denis - think it looks better that way.
OC.
- popeye the sailor, Canute and mtaylor
3
Gonna be a great kit.
OC.
- mtaylor, popeye the sailor, Egilman and 1 other
4
Thats looking super - you have brought the detail out really well.
OC.
- popeye the sailor, Canute, Egilman and 2 others
5
Got my seat ready - this will be good so great to have a fellow spit build on the forum (your F18 looks Superb)
OC.
- Jack12477, Edwardkenway, Canute and 3 others
6
6 minutes ago, popeye the sailor said:
WOW! superb job on the Dauntless Ed! very well done
I don't recall ever doing a Japanese plane before........might be interesting. I think the Russians have it beat though.......TU 95MS
not sure if there's a kit for it........but then again, I've not done a Russian plane either
I've got Tora Tora Tora in my library........my favorite is the Blue Max.......went through hell finding a copy
They do a kit of that not sure what scale though - memory escapes me.
OC.
38 minutes ago, Jack12477 said:
The boxes came shrink wrapped, haven't looked inside yet. My Dad's youngest brother was a Captain in a tank retrieval unit somewhere in France, can't remember where tho.
Small world Jack/Ken.
OC.
- lmagna, mtaylor, popeye the sailor and 1 other
4
AMT Body Snatcher - 1:25 by Fright
in Non-ship/categorised builds
Cool.
OC.
