Posts posted by Old Collingwood
10 hours ago, lmagna said:
That is some incredibly nice work OC Truly something to be proud of. Did you have something to use as a reference or did you just do it as you thought it should look?
Hi Lou, thank you for the kind words, the instrument panel is made of pre painted PE sections - a backing piece with the clocks painted on, then next the frontage with the dials and last a center section, after fitting them I dropped some semi gloss top coat onto the dials, superb craftsmanship.
OC.
- ccoyle, popeye the sailor, mtaylor and 3 others
- 6
2 minutes ago, rlb said:
OC,
The monstrous alligator clip in the previous post was a shocking reminder of the scale of this. Nice work.
Ron
Thank you for looking in and the compliment.
OC.
- Egilman, popeye the sailor, mtaylor and 1 other
- 4
11 minutes ago, Egilman said:
Nice sharp work......
Thank you EG.
OC.
- BLACK VIKING, mtaylor, Canute and 2 others
- 5
Evening all, hope everyone is ok - keep up your spirits we will get through this, anyway work continues starting with the instrument panel, this is a multi stage thing starting with the frame - this has three sections of PE to be attached to it, when set I painted underneath and around the frame in Green, then I built and painted the compass, this was then glued in place under the frame, I then did a bit of shading with a pancil and finished off by highlighting, next off was to build the gun sight - this is a clear part in two sections, I glued both together then painted around the frame.
OC.
- Barbossa, BLACK VIKING, lmagna and 13 others
- 16
56 minutes ago, popeye the sailor said:
it's good to work in both mediums........change with the seasons
Are you a clairvoyant Denis?
OC.
- mtaylor, cog, popeye the sailor and 3 others
- 6
2 minutes ago, Jack12477 said:
Thanks, OC
No problemo Jack - I think its trial and error as long as you havn't gone too far and made it like water - I would start with 30% and see how that goes.
OC.
- popeye the sailor, Jack12477 and CDW
- 3
13 minutes ago, Jack12477 said:
I assume that is 30% thinner / 70% paint? I have been using acrylics also but not diluted. I pour a little into a plastic egg carton shape easel, dip brush in clean water, pickup a dab of paint on brush then apply. Area depends on size of brush I am using. For this model I did the hull in enamel to get the color hue I needed. Most everything else will be acrylic if and where I can. For example, the cockpit detail above is all done with acrylic, hand brushed. Ditto interior of cabin.
Yep 30% thinner just enough to get a nice flowing liquid some say same consistency as milk, I think All enamels are meant to be diluted somewhat straight from the tin.
OC.
Wonderful work EJ, keep it up stay safe and try to keep busy mate.
OC.
- popeye the sailor, Fright and EJ_L
- 3
5 minutes ago, Edwardkenway said:
Trouble is I'm enjoying it, so there will be another plastic kit after the dauntless
Glad to hear it - we will build our woes away.☺️
OC.
- Canute, Edwardkenway, Egilman and 2 others
- 5
1 minute ago, Edwardkenway said:
I know what you mean, these plastics guys tempt you in then never let you out!!😂😂
What - Me - Us on here 😉
OC.
- Edwardkenway, Egilman, mtaylor and 3 others
- 6
5 minutes ago, Jack12477 said:
Only some old Testors Model Master thinners, OC. What dilution ratio would you recommend? I am using Testors Model Master brand paints. It is mostly enamel. For the non enamel stuff I am using Vallejo .
You could try 30/70 something like that, I tend to use Acrylics these days and dilute these near 50/50 and try to paint in controled areas or mask an area that falls near to a natural fuselage line / panel line.
OC.
- popeye the sailor, CDW, lmagna and 3 others
- 6
1 minute ago, Jack12477 said:
Orange, Ken ? You need a new monitor ! Looks almost fire engine red to my naked eye. Probably should look at and photograph it outdoors in real sunlight instead of daylight rated LEDs. And man is this enamel ever sticky. Not used to working with enamel. Got really spoiled by Floquil when I did the tanks.
Have you got any Enamel thinners Jack?
OC.
- CDW, Jack12477, popeye the sailor and 2 others
- 5
Looking very good Edward, hand brushing is not easy (its been my way for many many years).
OC.
- marktiedens, GrandpaPhil, lmagna and 7 others
- 10
- Canute, popeye the sailor, mtaylor and 1 other
- 4
5 minutes ago, realworkingsailor said:
Thanks OC!
Painting that roof must have been a “fun” job! It definitely gives a good appreciation of what the railroads had to do to keep their “varnish” in top condition for the clientele.
Andy
Yep certainly was, I used to work looking after the grounds for someone with more money than sense - he brought a railroad carriage to do up (me do up) over a period of hot weeks in the summer I worked on it.
oc.
- popeye the sailor, Canute, mtaylor and 3 others
- 6
Great subject Andy, I once painted (by hand) a full size passenger sleeper carriage including brushing on Bituminous paint using a broom on the roof.
OC.
20 minutes ago, Egilman said:
Yes, the casting job is very nice.... looks to be a well thought out kit..... (and your better at dry brushing than I am) Good Job!
Thanks EG, I just use a wide brush and make sure its almost dry like a powder brush, then just light brushes over the details keeping an eye on how its building up, then seal in with brushed on clear top coat.
OC.
4 minutes ago, popeye the sailor said:
look'in good OC!
Thank you kindly Denis, I'm very impressed with the quality and accuracy of the moldings.
OC.
Spitfire IX (Late Mark) by Old Collingwood - FINISHED - Eduard - 1/48
in Non-ship/categorised builds
Thank you carl, its great having you onboard.
OC.
