Old Collingwood
  1. Same from me carl, that is some lovely detail work you have done - lovely job. OC.
  2. Congrats on the purchase - that will make a great build. OC.
  3. A bit more progress to day (boy I love the fit of this kit so far - it almost falls together) next was to paint and fit the two pedals, quite straight forward they pop in below the bottom frame, next I glued the other side to close up the cabin bath tub assembly. After putting this aside - I woked on the two fuselage sides adding a few more fittings that were then painted and weathered, I thne did a dry fit - all seems well with the fuselage going together well. OC.
  4. Exellent work indeed - you have chosen The referenece kit for HMS Victory and what a superb start you have made on her. OC.
  5. Phil you are making some Superb progress - its a pure delight to see your baby build into such a loverly piece of art. OC.
  6. Kevin its looking mighty fine - take no notice what others think, your attention to detail and workmanship is outstanding in everything you build. OC.
  7. Most important thing lou - try to keep your spirits up and I am sure everyone else agrees - this is our family on here and we are all here for each other. OC.
  8. Thanks denis, its RAF Cockpit Green straight out the jar diluted 50/50 then brush painted on. OC.
  9. Hi Lou, thank you for the kind words, the instrument panel is made of pre painted PE sections - a backing piece with the clocks painted on, then next the frontage with the dials and last a center section, after fitting them I dropped some semi gloss top coat onto the dials, superb craftsmanship. OC.
  10. Thats turning out really nice - great work with the painting. OC.
  11. Evening all, hope everyone is ok - keep up your spirits we will get through this, anyway work continues starting with the instrument panel, this is a multi stage thing starting with the frame - this has three sections of PE to be attached to it, when set I painted underneath and around the frame in Green, then I built and painted the compass, this was then glued in place under the frame, I then did a bit of shading with a pancil and finished off by highlighting, next off was to build the gun sight - this is a clear part in two sections, I glued both together then painted around the frame. OC.
  12. No problemo Jack - I think its trial and error as long as you havn't gone too far and made it like water - I would start with 30% and see how that goes. OC.
  13. Yep 30% thinner just enough to get a nice flowing liquid some say same consistency as milk, I think All enamels are meant to be diluted somewhat straight from the tin. OC.
  14. Wonderful work EJ, keep it up stay safe and try to keep busy mate. OC.
  15. Glad to hear it - we will build our woes away.☺️ OC.
  16. You could try 30/70 something like that, I tend to use Acrylics these days and dilute these near 50/50 and try to paint in controled areas or mask an area that falls near to a natural fuselage line / panel line. OC.
