Posts posted by Old Collingwood
Hi all,
Some good progress today - over four hours on her, I finished rat-ing the top main shrouds, then working from the top gallant down, I worked on the top gallant spar firstly cleaning up and painting the two tackle blocks, these were then lashed and glued in place then I sorted a length of lifting rope this had to be smoothed out with my normal method of rubbing watery pva in to smooth out the fray ends.
I started at the top found the center point of the rope length then tied and glued around the top gallant block, then I rigged them through the tackle and ran them down each side through the lower shrouds and tied off on the bulwark hand rails.
Just the three pics a couple out of focus and hand shake but I think it shows what I have done.
As always - Sincere Thank You for all the likes and replies.
OC.
- Canute, lmagna, SigEp Ziggy and 6 others
- 9
2 hours ago, lmagna said:
It is good to see you back at the Peal again OC. Believe it or not you are on the down hill stretch and will be presenting it to your bride in no time. Ghostly dust and all.
Thanks lou, its really good to be back on the dusty ole thing.
OC.
- CDW, popeye the sailor, mtaylor and 1 other
- 4
3 hours ago, SigEp Ziggy said:
OC, I am glad to see you working on the Pearl again. Welcome back!
Thank you ziggy, its good to be back.
OC.
29 minutes ago, lmagna said:
Actually I found the list last year for a problem OC was having. Finding it today in the place I had stored it on my computer was MUCH harder! I have a tendency to hoard information like I do models, and sometimes my file system can use a little cleaning up.
And I appreciated Lou helped me No end.👍
OC.
26 minutes ago, lmagna said:
They just finished refurbishing the real Memphis Bell and putting her up on static display. The pictures of the rebuild were amazing and it looks like she could fly. Too bad they didn't take her all the way.
Lots of Warbird restorations happening over here this year have heard they are even talking about a second Lancaster returning to the Sky plus many other single and double prop planes.
OC.
- Canute, popeye the sailor, mtaylor and 1 other
- 4
1 minute ago, Canute said:
Saw an AC-130 Specter gunship doing his thing one night. 20mm, 37mm(I think) and a 105 mm for good measure. Charley would be hurtin', for certain. And we threw some CBU cans on top of all that. Wasting trucks on the Trail on Laos. The gunship would mark the target with a call for the 20mm of sparkle and boy did it.
Those Ghostriders were some planes.
OC.
What an excellent idea.
OC.
Very nice end result Eagle to the ready.
OC.
- CDW, popeye the sailor and Canute
- 3
2 minutes ago, GrandpaPhil said:
Good to see you back at it! The Pearl is looking awesome!
Thank you sincerely phil.
OC.
I'm Back
I recharged my batt's and found my mojo - I decided to get out on the table just what I needed to continue on the Pearl, this wasn't much just a few tools etc, I got the pearl out of the display case (still with a layer of dust - but guess that adds to her ghostly look).
After checking were I add left off - I picked up with the rats going up the main tops, this I did both sides - same procedure of fine sowing thread wrapped round each then a dab of ca before trimming each end.
I then moved on to the main top shroud rats starting both sides.
It actually didn't feel that different and I picked up quite easily.
Its good to be back.
OC.
What an amazing man SK was.
OC.
- thibaultron, yvesvidal, mtaylor and 2 others
- 5
.50cal 1/72 scale .....anyone building a B17 I wonder.
OC.
- popeye the sailor and Canute
- 2
- Canute and popeye the sailor
- 2
19 minutes ago, Javlin said:
Snake bit! kevin
Nah! that's a drink - cider and larger mixed.
OC.
- popeye the sailor, mtaylor, Canute and 1 other
- 4
That was some rotor diameter on the 53 wasn't it something like 50feet?
With the flat black I sometimes had the same issue - with me it was paint not mixed well enough - then a second coat on top.
OC.
- Canute, popeye the sailor and mtaylor
- 3
Happy new year Bob, you are doing an Outstanding job she is looking so nice.
OC.
- Elijah and FrankWouts
- 2
8 minutes ago, SigEp Ziggy said:
Excellent Job OC! I had to bring this build up to the front of the build logs.
Thank you kindly ziggy, she now sits in the display cabinet.
OC.
What excellent work phil cant wait to see the carriages.
OC.
German AF F4F doing its stuff at RIAT Airshow UK 2003 it was Loud........
OC.
That is bad mate - I would be Fuming Mad.
OC.
- popeye the sailor, Canute and mtaylor
- 3
- popeye the sailor, cog, GrandpaPhil and 4 others
- 7
Finished - Petlyakov PE-2 Soviet Dive Bomber by CDW - Zvezda - 1:48 Scale
in Non-ship/categorised builds
Some lovely detail on those wings should paint up a treat.
OC.
