Right folks a bit more work on the deck today, above I asked about filling any gaps between the deck boards, well I tried the idea of diluted PVA and wood dust, first I sanded down a couple of scrap deck strips onto rough sand paper, and collected the dust in a cup, then I mixed some PVA with a little water to make a milk thikness, then I used a small paintbrush and brushed into the gaps (one at a time) the pva then with the same brush I dipped it into the dust and rubbed it into the gaps. I did this into each gap then re applied to make sure the gaps were filled, I then put the hull aside to dry till tomorrow. Next will be to sand the deck again and check that the gaps have filled. OC.
- 455 replies
- slightly modified
- greyhound
I should have commented way back then mark - but yes its my pleasure having you follow my work back then and still now. OC.
- 455 replies
- slightly modified
- greyhound
What I found/find useful for sanding is those decorators sanding sponges (basically sand paper wrapped around a square sponge) they are great as they are flexible and bend with the hull shape, so you can get a nice smooth finish. OC.
- 91 replies
- kolderstok
- duyfken
Thank you so much for the compliment and having a look over my build, its been a while since we last spoke, any ideas how I can fill a few of the gaps yet still retain the caulking look. OC.
- 455 replies
- slightly modified
- greyhound
Hi folks, I had a good day on the build today - spent most of the afternoon continuing with the deck planking, this involved some quite intricate cuts and shaping, I think it has gone quite well just a few small gaps that should fill when I do some sanding to bring it all nice and level. OC.
- 455 replies
- slightly modified
- greyhound
Excellent work don really tidy and so comprehensive. OC.
- 653 replies
- trabakul
- marisstella
Excellent Excellent work greg I take my hat off to you they look Absolutely Superb. Well done. OC.
Looking great all that detail still cant believe its card (serious scratching head moment) OC.
Nice and tidy very claen work, what I did to support the skeleton was a length of 2/1" timber and made some blocks to support the false keel. OC.
- 91 replies
- kolderstok
- duyfken
Thanks mate, I thought working on wood planks would be easier than PE parts at silly scale, kind of theraputeic and give my hands a bit of a rest, while still doing something. OC.
- 455 replies
- slightly modified
- greyhound
Hello again folks I decided to give my Warsite a little rest and do some more work on my wood build, first off I had to dust her down as I have not done anything to her for many years, all was still intact so I got my bits together and decided to continue with the deck planking. I first finished off the edge planks that are a slightly darker shade than what I was using before, but that wont matter to much, after a bit of measuring they were fitted both sides and held in place while the PA set. I also decided to carry on with the planking. So sofar I have done another length of planking and the edge planks. Well its a start and different medium from my warspite build. Here is a few pictures folks including one that shows the rear cabin bulkhead not fitted just dry fitted. OC.
- 455 replies
- slightly modified
- greyhound
Well done rescusing the decal situation "boy do I remember those annoying situations with decals" they just always seem to break up - fix where you dont want them or leave a silvering edge around them. She is coming on really well (dont foreget she is an old model not the same as modern kits) so you are deffo doing a grand job. OC.
- 133 replies
- jeanne d arc
- heller
Looking great very tidy and those ribs sure look aligned, is it dry fitted or glued? OC.
- 91 replies
- kolderstok
- duyfken
What a great idea tackling section by section including painting, its easier that way to get a quality job in a controled area at a time. OC.
Sand it off using a sanding stick thats been smoothed a bit to loose a bit of its grit, thats what I do. OC.
Looking Superb Danny really really good i think card is the ultimate in skill as it is so delicate, you are the master at this for sure. OC.
Wonder what that model in the museum archives is based on - is it a later version perhaps an update of SoS? OC.
- 192 replies
- sovereign of the seas
- sergal
She is looking really good now all the hard work is paying off, and Wow how it makes a difference when you get some bits on here. OC.
- 133 replies
- jeanne d arc
- heller
Hi john, we are creating quite a plastic army on here, its so good to find a home on here along with all the wood builds. OC.
- 133 replies
- jeanne d arc
- heller
This will be a lovely thing to see develop into another masterpiece. OC.
- 91 replies
- kolderstok
- duyfken
Hi there lovely build really tidy, I came across some pictures on the Royal Museums site at Greenwich have a look - http://collections.rmg.co.uk/collections/objects/66317.html OC.
- 192 replies
- sergal
Hi folks I have probably shown this before - but this is the stage I am building her from - 1944 D Day off the French coast. OC.
Utterly Superb - what a fantastic job you have done. OC.
- 473 replies
- greek bireme
- dusek
Very tidy work and thats a good fix of the problem you encounted, we all have these little spanners thrown at our works, that push us to find inspiration. I can ralate to your prop shaft rudder situation, I managed to break of one of the rudders and broke off one of the spinner blades(mine was a war related issue from a mine) OC.
- 133 replies
- jeanne d arc
- heller
