robdurant
Posts posted by robdurant
  1. Hi David
    Looks good to me :)You may want to consider getting a coat of paint on the gunpoint linings before you put the second planking round them... they're tricky enough to paint without having to avoid the final outer hull finish at the same time. My boat ended up looking like a toddler who'd got hold of some lipstick around this point... I'm sure you'll do a great job and it will look really smart as you get the next skin on.
    All the best
    Rob
  2. Hi Peter,
    Thanks for looking in, and for your kind words and advice. Yes, you're quite right. I measured the shot and they come out slightly over scale (2.38mm on the few I measured, rather than the 2.04 mm they ought to be to give a scale 5.04".
    I've had a little look round, and found that #9 shot for shotgun cartridges will be the perfect size, so I've ordered some of them - I say some... if anyone wants some, I'll most likely have 0.999 kg left over when I'm done! Even I can't catapult that many off onto the floor.
    I'll have a go at remaking the shot lockers as you suggest, and we'll see where we get to :) I'm definitely keen not to have the shot rolling around the deck - I'm sure the Captain George Countess would agree... (interestingly I just read that section in O'Brian's "Post Captain" a couple of days ago :) )
    Take care.
    Rob
  3. Hi all,
    Thanks so much for the likes. They're such an encouragement. A little update as Storm Bronagh blows. We live on top of a hill, so we're pretty much the first thing the wind reaches in about 30 miles... It sounds pretty impressive out there (for England any-how :) )
    I've been working to finish off the 18 pounders. They're mainly there structurally on port and starboard now, with only the wedges, and the rigging to be done. (He says "only"!?!)
    For a little diversion, I spent some time working out how to make the shot racks around the gratings. I'd been a little concerned that the colour of the boxwood I'd used was too close to the colour of the maple on the deck. The solution? Make the shot racks red ochre, like the gun carriages.
    None of this is fixed to the deck at the moment, but I'm pleased with the overall look of it.  I don't have a mill, so I created a plasti-card template to drill through to make the little dimples for the shot to sit in, then I used that template to drill .5mm holes where the dimples needed to be, and opened them up with a spherical engraving bit in my proxxon hand drill. It isn't perfect, but I'm pretty pleased with it. The shot comes with the kit, and was fixed in place with a dab of superglue (using tweezers and patience...!)
    Here's a pic of Ethalion with her teeth in!20180920_212520_1280.thumb.jpg.6d2da6e5590371fb639188a2d6cf9023.jpg
    Happy building :)
    Rob
  4. I was looking at Ethalion yesterday evening and wondering why something was jarring. Earlier on in the build I'd decided not to have red bulkheads on the gun (upper) deck. Having just visited HMS Victory I thought I'd paint them white, but in retrospect, at 1:64 scale, it just looked jarring, and to my mind took away from the lovely yellow tone of the boxwood. So. After some careful masking, I decided to paint them ochre instead. The hope is this will tone them down so they sit more in the background. It will also be a good moment to add some of the detail on the deck.
    This morning I decided I didn't like the look of the deck right towards the stern. I'm sure no-one will see it, but I know it's there. So, inspired by HMS Mercury, I drew up a bulkhead on QCAD, and have spent the day turning it into a reality.
    Here's the pdf of the CAD drawing. (I make no claim to absolute authenticity, but it looks correct to my eye)
    Artois.Gundeck_bulkheads.20180913.pdf
    I pondered whether to use wood to make the bulkhead, but the details were so fine that I wasn't sure I was up to it. I didn't want it all to end up looking clunky and overscale... So I used a mix of 1mm plastic for the bulkhead shape, 0.5mm plastic for the uprights and top and bottom beams, and paper for the detailing. I still need to finish the doors (these will have boxwood windows as per the stern lights and quarter galleys. Having painted it ochre I'm pleased with the result so far (it still needs final fitting, and to have the doors attached - they'll be open a little). According to AOTS it should fit just behind the sternmost grating, and before the third gunports from the stern.
    The white line along the bottom of the outer walls is where the spirketting will go (I've pre-painted some wood strip that will be fixed to neaten it all up)
  5. 11 hours ago, Beef Wellington said:
    Seems it was all to keep the proportion and elegance of the stern rather than for practicality.
    It certainly worked :) I can't imagine what I'm going to build after this Frigate. They really are the most handsome ships for me.
    11 hours ago, Old Collingwood said:
    Looking Superb.
    OC.
    Thank you OC
    10 hours ago, paulsutcliffe said:
    Not to afford some privacy while using the head??
    When you put it like that I think I would have been glad of the false lights... lol. Not that I would have been resident in the captain's cabin. Powder monkey or waister more likely :)
    Thank you for the encouragement gents.
    Rob
  6. A little progress...
    I've been working on the stern, trying to tidy it up and make sure everything fits together neatly. I've worked myself into something of a corner. I want to glue it all together, but as soon as I do, the window glazing has to go in, because the frames are fixed. I don't want to do that until I'm confident I'm not going to fill the stern with dust... and I can't be confident of that until the quarter deck is fixed on, and it's all sealed... It's all a bit of a poser... but until I've worked out how that happens in my head, I'm not gluing the stern lights on.
    That said, I've started making the lower-most sections of the quarter galleries. These are provided as white metal parts, but because of the way the stern on my "version" worked out, I've remade them to fit better. The decorative spheres at the bottom are still a little further towards the stern than I'd like, but I think I'm getting to the point where I can live with it. (They're glass dress-making pins)
    20180901_204035_1280.thumb.jpg.490a5d2ac059e9e398ce5cd64f709520.jpg20180901_204021_1280.thumb.jpg.ea8a563ec994193eda4f2f24da57f9ea.jpg
    The lines will all be covered by the decorative mouldings.
    Next job was to start putting the decorative moulding strips on. I started with the stern, so that things match up side to side.
    (NB: The stern isn't glued on, just held in place so I can make sure it all lines up - the decorative moulding at the bottom of the stern lights is glued onto the stern lights.)
    This was quite tricky, as increasingly there's nowhere to fix clamps to keep everything in place... I used a mix of masking tape, and 0.65mm drilled holes to pin the rails in place before gluing with carpenters glue. Everything was checked before and after gluing to make sure there was a nice curve (to my eye) both from side to side, and top to bottom... This curve needs to match between the upper and lower rails, so it's not a job to rush!
    The lower rail was sanded so the profile was not facing the floor, but facing more outwards... This seems to have helped with the look. The upper rail was sanded to face pretty much directly outwards, almost as though it were a window sill.
    So... after much rearranging, and checking, and double-checking and careful trimming... That's the progress I've made to date. You'll notice I trimmed the rails, but left them a little over length. The side rails will butt up against the front of these, and then they'll be gently shaped (hopefully) to merge them into one. They'll be painted with Admiralty Paints yellow ochre, so hopefully any minor bodges will be hidden by that point :)
    Just for the fun of it, here are a couple of pics before I did the rails, with the light coming through the lights as it were. (Notice the false light on right and left - they couldn't be real windows, because the hull intersects with the transom in the middle of them... From what I understand they were put on to make the ship look bigger and more imposing). The glazing (which is not fixed yet, and before I do, needs a good clean) is in once piece, and is the clear plastic supplied with the kit, with black card glued onto the back to block the false lights.
    Happy building :)
    Rob
  7.
    On 8/23/2018 at 10:00 PM, Beef Wellington said:
    Hi Rob, love that last quarter shot, most definitely her best angle in my opinion!  Picking up on my cannons as well, I'm intrigued by the barrels that came in your kit, they are definitely different to what was supplied in mine, much more appropriate. They look very nice indeed.
    Hi Jason.
    Thanks - yes, I agree, the quarter is definitely a lovely angle on these frigates.
    Looking through your log, I noticed the barrels had changed. I'd seen the comparison on your log of the different barrels, and had intended to swap mine up for the RB barrels, but comparing the ones in my kit with the AOTS book, they're certainly close enough for my liking... I'm really impressed with them. A considerable difference at the muzzle and the cascabel to the ones you were provided with. Hopefully that's a change that's going to be permanent for future Diana builders, as it seems a shame to let down such a beautiful ship with the previously kit supplied barrels. That said, I'm also looking at the carronades which are the whitemetal moulded ones, for the quarterdeck, and thinking I want to upgrade those with the caldercraft ones they sell separately. Thankfully there aren't so many of those to swap up!
    As always, your build is an inspiration, and a great encouragement along the way, and given we're both working on gun carriages at the moment, I feel your pain - I've done half of them and turned back to the Stern to work on that for a break! I'm happy with the results I'm getting, but yours are something else! I stopped a step short of adding the vertical bolts... I wasn't sure how many holes I could put in the carriage sides before they'd start turning into sawdust :)
    I also agree that blackening the brass wherever possible is better to painting. It's so nice to be able to handle the parts without knocking off flakes of acrylic paint left right and centre! And the idea of hand painting 600 eyelets doesn't really appeal, if I'm honest! It took 30 seconds to blacken them. A technique I'll be using every time from here on in.
    Rob
  8. Coppering is okay once you get into the groove. If you're using ca glue I'd strongly recommend getting a mask to protect your lungs (one that deals with vapours not just dust)... you'll get through a fair bit of ca and be sat there a while.
    I made a note of which mask I used on my log here (post 71): https://modelshipworld.com/index.php?/topic/15132-hms-ethalion-1797-by-robdurant-modified-from-caldercraft-164-hms-diana-1794/&page=3
    The few times I forgot to use it I regretted it.
    I'd suggest doing something to seal the wood before you start otherwise you'll use a lot of ca just wicking into the wood.
  9. Welcome Chris!
    Looks like you've made a great start :) Looking forward to seeing your progress on Nelson's favourite ship. There's so much knowledge and a real willingness to help, so this is certainly the place to find encouragement and the knowledge to keep going. I'm building HMS Diana - the heavy frigate also by Jotika, and I wouldn't have got as far as I have if it weren't for all the help and encouragement I've been given.
    Rob
  10. Hi all,
    A swift update. Mainly a conveyor belt of getting gun carriages finished. I'll try and outline the process I'm using below:
    I'd already removed all the wheels from the boards, fitted them onto my mini drill and put them over sandpaper to get rid of the char. Then I put the big and small wheels in separate bags so I could find them later.
    1. Assemble the carriage frames. (Sides, axles and front and back)
    I used a plasticard jig to do this.
    2. Whittle the axles to fit the wheels.
    There's no shortcut. It's just slow and steady with a sharp xacto knife, stopping and checking the fit time and time again.
    3. Drill the holes for the eyelets and breaching rings
    I made a template for the sides out of plasticard, and for the back. The side one worked brilliantly by slotting over the axles. When I came to use the one at the back, there wasn't enough purchase to stop it simply getting picked up by the drill and spinning on the drill bit. So I used some masking tape to stick it into place on each carriage. (This is for the eyelet that will be fixed to the rope used to pull the carriage back in to the Frigate.
    The holes were drilled with a 0.65mm drill. The hole with the cross through it on the template is the pre-drilled hole used for the supporting bar between the sides. This template was used for both sides, simply reversed. The notches in the bottom fit over the axles where they narrow) By leaving my wood working vice a little ajar, I could sit the axles into the gap, and that gave the support to be able to drill into it carefully with a proxxon mini-drill. Again, I'm sold on this little drill. All in, for the 28 main guns, it was  196 holes, without the re-opening up after painting for the pre-drilled holes, so the proxxon drill made a massive difference.
    4. Add the bar that goes between the sides.
    This was .65mm steel bar - not sure where it came from, but it saved me needing to blacken a whole bunch of brass rods, and looked pretty neat.
    5. Add the fore and aft part on top of the bar, and the back axle.
    (This remained unpainted, because I liked the contrast, and wanted a way to show the carriage was box as per the grating surrounds etc...)
    (wow, close ups are cruel! or maybe my eyes are being overly generous!)
    6. Add the eyelets and breaching rings.
    The breaching rope rings are not included in the kit as far as I could tell, so I wrapped thin black lacquer wire around a 1mm drill bit lots of times, slid it off, and cut it into lots of rings with a pair of scissors. These were gently prised open and pushed shut on one of the blackened copper eyelets to make a ring. Tedious, but looks pretty good. My only slight concern is that these might be slightly tight for the breaching rope. I need to check this sooner rather than later. They fit the scale of the rings on Chuck Passaro's excellent pdf of his gun carriages (see his website), and it's that I've been working to.
    7. Make up the wedge with it's holder, used for setting the elevation of the gun.
    I used my mini drill to spin the box strip and files to shape it into the handle for the wedge.
    8. Put the gun barrel in place
    (not glued yet, because I want to set the height of all the guns individually.)
    9. (Also not done yet) Add black card strip over the main bar the gun sits on, so it looks like it's held in place by metal bars.
    I tried those last few steps on one gun as shown above and it looks nice to my eye.
    Having seen these close-ups I clearly need to go over and have another look at some of these and tidy them up a bit, but it at least gives an idea of the process I've been using.
    Anyway - 14 guns down, and a bunch still to do, but the weather was nice this afternoon and it seemed like a good opportunity to try and get some photos of the progress so far.
    I can see a whole bunch of things that need tweaking / fixing before it all gets fixed in for good, but it's nice to see that I'm at least heading in the right direction :)
    Happy building everyone!
    Rob
  11. Thanks Chris - that's a great encouragement :)
    3. Hull sides and framing
    So - here start the "noob" questions, and a few more "this seems to be the wrong number" observations.
    Where the plans show a part thickness to be made up, is that the final thickness, or the thickness of the card that I'm sticking the part to? (see picture below - should part 29 end up as 2mm thick, or as the thickness of part 29 PLUS 2mm card backing? At the moment, I've been sticking the part to 2mm card, although for these parts it seems a little thick.
    I've been adding these parts in - parts 29 through to 32... though it seems that the lines that join the parts (i.e. 31 to 31, 32 to 32, 33 to 33) are not in the right places... or at least, when I came to add them to the hull the two 31 parts were completely different shapes, one of them being too high and pushing the hull sides out too much. I lost track of which was which after a while, but suffice it to say, the taller parts go at bow and stern  (in 29, and 33 positions) - stern (32) slightly taller than bow (29), then the shorter ones go in the centre (32 slightly taller than 31)... I'd suggest making these all up, then lining them up on the table before sticking them all into place. Once done in this way, they don't push the hull sides out of line. Parts 33 seem right.
    As can be seen, I still have two more of these parts to fit (32 and 33 at the stern on the port side...), and then the remainder of the spacers that separate the internal sides from the external hull sides. Before the internal sides go on, I'll also need to line the gun ports.
    I've left the doors off the cabin walls as they seem a little vulnerable at the moment. They should be simple enough to add in once the hull sides are on.
  12. 2. First "planking"
    This is where the neat cutting out becomes critical - that said, I managed it, and I was pleased with the result...
    Bending each part carefully, before sticking down makes a huge difference. I started cutting off the tiny tabs at the bottom of each piece as they seemed to only get in the way.
    One point to note... when you get to the end of this, if you follow the numbering, the next piece is 27... and there's no mention of this piece on the exploded diagram. Looking at it on the paper, it's clearly the gundeck, but that doesn't help you to know whether it should be stuck to card before fixing on to the model. I took the approach that 27a IS attached to 0.5mm card, and it continues the sweep of the deck, so I did... and it helped cover up the complete mess of the false deck I mentioned in the last post.
    Once in place, the chequered floor of the captain's quarters can be added, and the bulkheads, again each strengthened as per the diagram with thicker card.
    And this is the progress so far.
    So far I'm extremely impressed with the accuracy of the parts - they seem to me to fit beautifully... any discrepancies being entirely my fault and not the model's.
    That's me up to date, then.
  13. I had a search, but couldn't find any other build logs of this model, so although I feel deeply unqualified, I thought I'd post a build log.
    This is the first card model I've built - in fact, it is mainly paper, with a laser-cut card frame (ShipYard also do a card version which is 1:72, and much more expensive!). So this won't be a masterclass, but hopefully the surprises and lessons learned as I go will be helpful to someone else following in my footsteps :)
    I started this model last year when I went on holiday - my main build is way too big to travel, so this one is more manageable (and a little less anti-social) - it may take me a while to finish, but hopefully I'll get there.
    I started by assembling the card structure of the ship. The diagrams provided are excellent, and the laser-cutting so good that this was very simple, and with a little care, it went together very nicely. I've read elsewhere that using a little superglue to wick into the extensions at the tops of the bulkheads strengthens them somewhat... I was too slow, and they got pretty mashed up. I'm hoping I'll be able to make up for that later on.
    So far, I've skinned the lower part of the hull, and started putting the details onto the gundeck.
    Here's a slightly more in-depth description of what I've learned, and done so far.
    Basic tools:
    Carpenters glue (Aliphatic)
    UHU glue (really really useful!)
    Pritt stick
    Superglue
    Lots of sharp xacto blades #11 and a handle
    Cutting mat
    0.5, 1, 1.5, 2mm card to stick the paper onto where directed. (This was found in my local art supplies shop - I found it really hard to get online)
    1. Assemble the frame from the laser-cutting.
    I used Carpenters glue to do this, and lego bricks to check it was all lined up... I think this was probably overkill, because with the deck on, it's pretty rigid, but it was my first attempt so I wanted to make sure it was all perfect. Sandpaper was useful to bevel the frames once put together... the card won't go over them (or have a flat surface to stick to) without this step, so it's pretty crucial. That said, it's pretty quick compared to bevel the frames on wooden models... that means it's even easier to go too far! - I marked the edges of the bulwarks with a marker so I could tell when I was not only reducing one side, but the overall outline of the bulwark.
    Once the frame was built, a couple of detail bits get stuck on to the lower deck (a brown sharpie was useful to edge the bits that are cut out to get rid of the white edges and make it look tidy), and then the false deck was then added... I made a mistake here by splurging on carpenters glue thinking that the paper covering would lie flat if only I pushed it down enough... not so much, it seems. It ended up looking horribly bumpy and I thought I'd wrecked the model...  The answer (for me) it turns out is to use UHU, add it to the card, and then use a piece of card to scrape it and make it nice and flat, then add the paper, smoothing it as you go. This ends up in a nice flat surface...  Thankfully, as we'll see, the false deck gets covered over later with a second 0.5mm sheet of card with the real gundeck pattern glued on top of it, so disaster was well and truly averted, and you'd never know I stuffed up now!
    Here's the first gun deck - you can't see the bumps, but trust me... they're there!
    More later.
    Rob
  14. Hi Peter.
    It's looking great :)
    You could mask it carefully, and paint the bulwarks, but then if you want to get a really neat line, add a pre-painted strip at the bottom of the bulwark to get a pin-sharp divide. This would allow you to stop painting slightly short of the deck too. I hope Jason (Beef Wellington) won't mind me pointing to his thread as an example of how this strip can look really tidy!
    https://modelshipworld.com/index.php?/topic/7219-hms-jason-by-beef-wellington-caldercraft-164-artois-class-frigate-modified-from-hms-diana-1794/&page=18&tab=comments#comment-567526
    If there's a coat or two of varnish on the deck planking, you'll probably have a better shot at removing any paint that creeps onto the deck under the masking?
    Rob
  15. Hi all,
    Thanks again for all the likes.
    I finished the rudder, added the straps and spectacle plate (yes, they should be brass, but I find the brass / copper colour combination jarring, so someone painted mine) - and hung it. The straps on the hull are still to add. The straps are made out of card as the photo-etch ones are oversized.
    I've continued working on the fittings for the gun deck. I made a little production line, and put together the main parts of all of the 18lb gun carriages. I'm not done with that, but I was going cross-eyed whittling all the trunnions, so I decided to deal with the guns, too.
    I did an experiment, sanding the char back, but not trying to remove it completely... the carriages will be painted, so I'm happy with this.
    I also purchased some casey brass black (this comes with a serious health warning!) and I've begun blackening the guns themselves. This was more involved than I expected. The method I used is as follows:
    1. Use a brass brush in my proxxon mini drill to gently buff the cannon (this removed any surface coating)
    2. Wearing gloves, wash thoroughly in fairy liquid (I started with white vinegar, but the fairy liquid seemed to work just as well, and it stinks considerably less!)
    3. Transfer to clean water.
    4. Remove and air dry - this was done with the gun muzzle sat on top of a brass rod so that no part of the outside of the gun was touching anything.
    5. Dip into neat Casey Brass Black and keep a close watch until it looks fairly black... lift out with needle nose pliers and drop into clean water.
    6. Once clean, take out, dry off and buff with kitchen towel. Any areas that had not blackened nicely were buffed with the brass brush again, and the process repeated.
    Sometimes I didn't get a completely even finish the first time, but by the second time, the guns had turned a nice even grey. The finish is far more even than my painting efforts, and it buffs to a nice shine - the kind of finish you can imagine a gun crew being really proud of... (In the photo of the gun on it's carriage, there are a number of steps left unfinished on the carriage.) I'm thrilled with this. I need to finish blacking the guns, (I've noticed that caldercraft sell brass carronades now, so I'll look at getting some of them for the quarterdeck)... and then I need to work out a way of blacking the copper eyelets in reasonable bulk without them turning into a black clump! perhaps sticking them into a balsa block?
    Here are my results.
    20180712_194249_1280.thumb.jpg.b0a28152a5ae162fd37a491e6b5a0da9.jpg20180712_131832_1280.thumb.jpg.27372c1dfede62cec8b99e3e04d18357.jpg
    Looking through the previous build logs for the Caldercraft's Diana, I was concerned that the guns provided with the ship may be a slightly odd shape with cascabels that were over-sized and a somewhat heavy muzzle... My fears were unfounded when I opened the fittings. They're things of beauty. Looking at the ones supplied before, it seems that Caldercraft have very much upped their game! Kudos!
    Here's a pic of one of the ones I received (they're all identical) - it seems to match up very closely with the AOTS diagram.
    And just 'cos I can, a picture of the gundeck with all it's unfinished carriages. Very pleased so far.
    Happy building
    Rob
  16. Hi all,
    Once again, I'm indebted to Jason (Beef Wellington), Ray, and Barbossa for their excellent insights along the way with their builds of the Caldercraft HMS Diana...
    I've taken a pause with the sheer rails until I've got the quarter deck / fore deck on... I think then it will be easier to make it all look right. That means there are some things that need tidying up before the model starts sitting upright permanently!
    The Fore Bitts.
    I made up the fore bitts... only one is provided in the kit, and I really wanted to beef them up a bit (I was struck by just how sturdy they really were when I visited Victory - albeit she was a bigger ship! So I started from scratch with boxwood, using AOTS and Jason's excellent effort as a guide... The square section uprights and crosspieces are made up of laminated 2x6mm guitar stringer, and the shaped supports from 6mm boxwood sheet. Before they were stuck together I checked that the stove and its brick base fitted in between the supports.
    I started making up the chain pump boxes... although for some reason I don't have a picture of them. I'll take some and put them up when I next work on them.
    Rudder.
    Next was the Rudder. Because I'd modified the backbone of the ship to have a tapered stern post, the rudder in the kit wouldn't fit. Again, AOTS provided the template (photocopy it out at the right scale, Pritt-Stick it on, then soak gently once it's cut out) to create one from boxwood sheet. I cut out the shape using a coping saw, and then filed and planed it down to shape, and sanded, then scraped the gradient from top to bottom. This took quite a while. Once done, I added the pintles, 2x6 boxwood section cut to shape with 0.6mm brass rod inserted. Black card was used to simulate the bands at the top of the anchor, and copper paint added to the edge that will be towards the hull.
    The kit provided copper eyelets were used for gudgeons, and the shape in the counter opened up to accomodate the rudder properly. I had to take a fair amount of material out of the transom to provide space for the rudder to lift up a little higher than the point at which it eventually hangs so it the pintles could be lifted over and into the gudgeons.
    All in all, I'm very happy with it. I haven't finished coppering it yet, but the effect is pleasing already.
  17. Hi all,
    A bit more work on Ethalion today. I was musing over how the sheer rails went onto the sides of the ship, and decided to go back and have another look at the pictures on the National Maritime Museum website. I remembered looking at the builders models when I started out on this path, and the pictures weren't brilliant, but had a note next to them saying they planned to get better shots soon.
    Well... cut a long story short, they're there now. (At least either they're new, or I just missed them before.)
    http://collections.rmg.co.uk/collections/objects/66303.html
    Under the main image, if you click the right arrow to view more thumbnails, there they are. You can click the thumbnail, and then if you click the expand icon they're really nice quality images.
    A slight side note, this model's marked as a Diana class, but the date is 1794, and I'm pretty sure it's Diana, of the Artois class? Happy to be corrected. I'm hoping to replicate the really nice decorative pattern on the tops of the quarter galleries.
    More pictures of my progress soon.
    Rob
  18. A mini-update on the stove, then.
    I got some scale OO gauge bricks, and laid them onto paper using PVA to fix them for the fire-proof base.
    Once completed, the base was painted over with water-down pva to fix it, and provide a kind of glaze. Then it was lined with 0.7mm box veneer to provide a surround.
    A shot of the stove so far, with plasticard legs, driptray and a lick of paint added. (Kit-supplied background, mine, foreground.)
    I've left a few areas unpainted, as there are still some details to add. Overall, I'm pleased with it, and it weighs 18g including the white metal flue instead of the white metal version which weighs 65 grams!
    Happy building!
    Rob
  19. I fancied a bit of a change after wrestling with the stern, so I got out the brodie stove mini-kit and starting putting it together. I'd forgotten how much I dislike white metal. Every time I use it, it just seems to turn to mush. It's hard to stick, and heavy.
    I didn't want to spend any more money if I could avoid it, though Jason (Beef Wellington) has used a 3D printed one that looks very good from what I can see. So... after a frustrating time trying to turn it into something that looked remotely like a stove, I gave up, and started making one out of plasticard and card instead based on the AOTS plans. Here's the progress next to my shocking attempt at the kit to compare it with...
    The white metal parts provided in the kit:
    My attempt at putting them together...
    Now, starting to build my own (you can see the mess I made trying to paint the white metal one... Here. I'm adding the cowling for the flue, which is slightly angled back in to the centre of the stove:
    I added the edging using paper - .5mm plasticard looked way too clunky.
    As it stands now... (Caldercraft kit, left - My attempt, right) You can see the grating details going in, and a whole variety of other detailng will also now be possible. That said, it's debatable how much is worth it, as it's well hidden away in the finished Frigate.
    Finally, I dug up this photo from when I was visiting Victory in November... a helpful comparison. :) I've also ordered some scale bricks which will help me make a nice tiled floor for the stove once it's ready to place.
    For anyone who's interested (and hasn't seen them yet), I put all the photos up online and linked to them on this thread:
