Everything posted by Kevin
Good morning Ken I started mine about 10 years ago, and then abanoded her in favour of the 1/72 Victory, there are some lovely builds of her around, and she makes into a stunning build,But its a shame that very very few are completed, and i dont know why, She is a very busy ship,and basicly the kit parts do her no justice what so ever, and therfore to get a realistic finish the instructions need to be binned and and obtaining some decent reference material I wish you luck and will follow your journey, as i have plans to redo mine in the future, at present i have stripped her down to the bare hull
thank you for the comments still to sort the wiring under the bridge roof, as it is stopping me putting it into position rig the foremast. put the braces in for the after gallows find homes for at least 100 bits, mainly brackets, cleats, chains tidy her up and then fwd to aft touch ups another week or so and then i think as a build she will be completed, and then be set aside for the diorama which will be an ongoing never ending project
- 337 replies
- finished
- mountfleet models
- 337 replies
- finished
- mountfleet models
Good morning everyone, worked late last night, sorting the wiring out, the power supply connections are now in position, each connection brings another ray of light into the build, hopefully today, subject to DIY projects the top section will be powered up at the same time as the hull for the first time
- 337 replies
- finished
- mountfleet models
thats a novel and brilliant idea to use the outside section of the frames, for the deck support
- 15 replies
- mantua
- soleil royal
good morning everyone getting the hull ready to accept the superstructure, prop shaft and rudder fitted but they are removable, in case someone else takes the hull in the future and wants to make her water tight, they will also have to fill another couple of holes as the power supply connectors are going to be fitted into the hull just under the bilge keel, this will be the same side as the dock side when in its diorama, most likely port side to, that way no wires will be seen
- 337 replies
- finished
- mountfleet models
bulk load the phot as you have been doing, they will auto load when you post, but in the drop box you can select each photo and insert or delete one at a time to place directly into the post
- 39 replies
- billing boats
- danmark
the hull has come up a treat, whats the rest of the wood like after 30 plus years like?
- 39 replies
- billing boats
- danmark
ty, looks a bit like a cruise liner at present
- 337 replies
- finished
- mountfleet models
good evening everyone its been a strange few months, i thought that being retired, life would be great, and it is, but obvious things outside my garden are not, But after a couple of weeks feeling quite low/fed up, i have pulled myself back together and the St Nectan continues i have gone back to the superstructure now and have sorted the bridge wings, and today most of the lighting has been commissioned, all working for the first time, i will work on no flash photos in the next few days, i have a remote built in that will control the brightness, navigation lights will have there own power supply
- 337 replies
- finished
- mountfleet models
just read your log from the start, lovely work, and an enjoyable couple of hours, thank you
- 4,152 replies
- cutty sark
- tehnodidakta
good evening everyone starting from the front i am now working aft to ensure everything is where it should be, but not necessarily complete, taking her outside has allowed me to look for some missing bits and to clean her off again i never did find the otter board hinges, so make some glazing of some of the windows using white pva glue steam winch mounting board is now pinned into position, the winch will be one of the last items to be fitted and the boat deck supports get a yellow coat, these will be cut to size when the superstructure get fixed on, as they sit on top of the capping rail
- 337 replies
- finished
- mountfleet models
Aston Martin DB5 by Fnick - FINISHED - Revell - 1:32
Kevin replied to fnick's topic in Non-ship/categorised builds
glad you finished her, she looks great -
good evening everyone the waledeck is nearly complete apart from touch ups and weathering i added the chain stopper, but have no idea if it is correct or not, deck portholes are glazed with PVA glue, tomorrow i will tidy up the main deck and think about rigging
- 337 replies
- finished
- mountfleet models
Good evening everyone slowly the front end is looking like a, well, a front end, a very light weathering so far, not sure how far i will take that, railings and anchor capstan are secured, as well as the ladder, next the bollards, cleats, anchor and associated gear, and securing points for the stays will be hopefully in place by tomorrow night some of the remaing bits to be identified, cleaned up and a home on the build found for them
- 337 replies
- finished
- mountfleet models
lol i might make them longer and have her as a paddle steamer
- 337 replies
- finished
- mountfleet models
actually they were one of the easiest bits of the build, the ladder handrails ( not fitted yet) took far longer
- 337 replies
- finished
- mountfleet models
Thank you Edward, although very much in the early days, and im not racing ahead with it, but the log is ni my signature list below
- 337 replies
- finished
- mountfleet models
