Sailor1234567890
Everything posted by Sailor1234567890
  1. I don't think many folks still build masts like that anymore. It's material intensive and good spar wood isn't cheap. I helped my brother build spars for his boat and I intend on building them for my boat using what's called a bridsmouth construction. If you google birdsmouth mast building you'll find something about it. Uses much less wood than a solid mast, is equaly strong and significantly lighter. All important things in a sailing vessel no matter her size.
  2. Real spars are made much as amateur said. An adz is used to square the tree. Next, the taper is marked on the top face. An adz is again used to taper it. Once the taper is made on both sides, it is rolled onto it's side and the taper once again marked and cut on the other two faces. Now you have a square log with both ends tapered. A special tool called a sparmaker's gauge (highly technical tool here) is used to mark these things evenly the whole length of the yard. (mast, boom, gaff, spinnaker pole etc. Even oars could be made this way, any round pole type object) http://www.onboardwithmarkcorke.com/.a/6a010536216f64970b016300b8845c970d-popup The spar is then 8 sided. Another gauge of pretty much the same construction will mark for 16 siding of the spar. Only the biggest of spars need to be 32 sided before being made round with planes by eye. Odd how they first square a log before returning it to it's round shape but that's how it was done. http://www.onboardwithmarkcorke.com/.a/6a010536216f64970b016761ae4f0c970b-popup
  3. Schooners carried a number of different sails in that position, depending on weather, what their course was in relation to the wind and even what kind of schooner they were. Stays'ls, fisherman's stays'l, Gollywobblers..... Some were designed to be lowered then raised on the opposite tack. Others were even more odd in that a man was required aloft in order to pass the tack over the stay in question. It all depends on what kind of sail you're going to portray. This of course changes how the sheets would be rigged. Hope that helps.
  4. I don't just look in here, I might be considered to stalk this one.
  5. Awesome. Looks really good. Can't wait to see her rig. That's going to be one heckuva model.
  6. Not really all that complex. The wheel turns the shaft in the middle. The shaft is threaded with a left hand thread on one and and a right hand thread on the other end. The "lugs" are threaded to match, one each. when the wheel is turned in one direction, the lugs move toward each other and in the other direction away from each other. They force those little slide mechanizms to push and pull on the rudder head at the same time thereby turning the rudder. There were variations on this, some used two threaded rods.
  7. Trying to add a side view that shows the angle of the wheel and the gear as well as the emergency steering tiller. I managed to load two pictures but the third one I can't for the life of me figure out what I did.... Oh well,here's a link to the page with those pics on it. http://forum.woodenboat.com/showthread.php?165347-Quadrant
  8. That looks great. It's called the steering gear box. It contains the mechanism that converts the rotational force of the helm to the rotational force of the rudder post. The reason it's angled is because it's easiest to make the gearing meet at a 90 degree angle and the rudder post isn't straight up and down. the wheel will act at 90 degrees to the rudder post and therefore the helm isn't straight up and down either.
  9. Gil, I'm already rigging her. Wish I'd have found this site before I started building the hull though. I'll try to get pictures up and a build log started at some point but the Christmas season seems to drain time away like water from a bathtub.
  10. Looking sweet there. Only problem is your last comment. No more posts until the new year. Have a great Christmas season Ed. Look forward to upcoming posts next year.
  11. That's odd. Well good luck with the build. Looking forward to seeing her rigged.
  12. I supose I was a little off in my guess then. A windlass is for the anchor. Winches would be for the cargo. A windlass has an axle that turns on a horizontal axis. A capstan turns on a vertical axis. I have no idea about those other parts either.... There's no description or name for them in the instructions? Maybe a picture of where they go? If you have that I could probably tell you what they are. They are an odd looking part considering the cabin ends with port lights are already installed on the model.
  13. The funny shaped pieces that seem a bit brown look like the ends of either the pumps or winches to me. There should be some sort of piece to connect them. either throws for the pump heads or drums for the cargo winches.
  14. How about a pic from further back so we can see the full effect? Those little sculptures look awesome.
  15. Joggling is the term. You joggle the planks in. Woodenboat forum will have information on that if you're interested in knowing more about it. The reason behind it was to allow the builder to caulk the seams. He needed a certain width of plank to allow his caulking iron to fit. There's no way to insert a 2 inch wide iron into a 1 inch space at the end of the plank so instead of tapering down that far, you joggle the plank to allow the iron to fit. The irons came in different sizes of course but practically speaking, you aren't going to caulk (pronounced "cork" by many) a plank with a pointy awl, you need a chisel shaped calking iron. FYI, a good experienced caulker, supervising newbies could often tell how fast his proteges were progressing and how well they were doing by the speed of their mallet blows and the sound they made. They make a sort of ringing noise. Caulking mallets are always used, no rubber mallets or hammers here. if it didn't "ring true" he knew his apprentice was botching it up. And now you know where the expression "ring true" comes from.
