Posts posted by Maury S
Back in the shipyard for a while. Working on lettering and scroll work for the trail boards. The name boards and trail boards are cut from .015" laser board. They are painted gold so the color shows through the decal. The surrounding areas will be painted flat black. The two names on the right are still on the decal backing and have not yet been attached.
Maury
It's time to take her off the building board. The support system is a pair of cradles similar to the cradles for my Centerboard Schooner Post 302 March 21, 2021.
I start by tracing the #4 and #17 frames from the plan sheet and transferring that pattern to card stock for rough fitting. The lower part of the frame is close to the shape of the hull at the points where the embedded nuts are located. After that, I copy the shape to some 1/32" box for final shaping. Since the ECB is built on a sloped jig, I measured the distance from the top of the jig and the building board at the two mounting points and transferred that measurement from the keel slot to the bottom of the rough cradle.
The scroll work will be done later.
Maury
Scotty, ...and of course you're going to serve the ring, right?
Maury
- Scotty W, Knocklouder and mtaylor
- 3
BTW, regarding the tiny nuts and bolts blackening...The nickel blackening solution does not blacken the bolts. I can use paint.
Maury
Serving the shrouds: I have been using Syren's Serv-o-Matic for years now. The only modification I've done is to put a key into every place where the brass tube goes into the gear to prevent slipping. Easy to use, and I can only do about an hour at a time due to eye focus strain. I run the serving thread through the rope (with a needle) near the left side, tie a couple of overhand knots, then serve to the right. The rope is held in the tube with alligator clips (with heat-shrink tubes over the teeth). I make sure the serving is going the opposite lay of the rope threads and maintain a mild tension on the serving thread.
Maury
Chuck, I get the sense that you REALLY enjoy doing this. It's a major accomplishment to design and prove out these projects. Kudos.
Maury
- mtaylor, Ryland Craze, Chuck and 3 others
- 6
Allan, I don't know. I have a Nickel blackener that I'll try, then it's paint.
Maury
- mtaylor, thibaultron and Canute
- 3
My partner gave me a kit of small nuts and bolts (washers, etc.) for watch and glasses repair. It comes with 6 drivers that is all he wanted. I haven't tried to blacken anything yet, but for about $20, there must be hundreds of these things that might be useful.
Label reads "King'sdun"
Maury
Yes. Grommets are just paint dots, drilled through (hat tip Druxey). They will be mostly obscured once the sails are furled. I played with folding a sample (practice) sail and I think it will come out fine...we'll see. Connecting the sails to the mast hoops will be a challenge.
Maury
More work on the mast iron work. The background is a page from Chapelle's American Schooners...where most of the details are
documented
The rods sticking out will be the supports for the bail and will be trimmed back, but holding things in place for soldering has to be thought out as well.
Keeping in mind all of the parts that have to go on in order is important like the mast hoops on the top mast before the wyes are installed.
Maury
- yvesvidal, mtaylor, Prowler901 and 1 other
- 4
Happy tenth anniversary! We are eternally grateful for your contributions.
Maury
- Ryland Craze, mtaylor, Chuck and 5 others
- 8
for glue, I prefer Luthiers Musical Instrument glue. It's just like Tite-bond but has a dye in it that shows up under black-light so you know if you've smeared any where it doesn't belong. Similar cost as Tite-bond.
Order direct: https://www.lmii.com/
Maury
A sled does not have to be fancy, just stable (thickness). Like Greg, I used 1/4" Plexiglas. This one has been used for years and is beat-up but still fits the bill.
If the piece I'm working on is too short, I might use double stick tape to hold it. I've been advised, to rotate side to side and end to end when thickness-sanding.
Maury
Kevin, create a simple "sled" for the sander. I use a piece of1/4" "Plexiglas" about 12" x 6". I think you will find it much better than just feeding a piece of wood through. Same technique...push stick and thumb pressure on the output. The sled also gives you a longer table.
Maury
Even wire shrouds would have been served.
Maury
- Keith Black and mtaylor
- 2
Emma C Berry by Maury S - 1:48 scale - POF - rigged as schooner
Druxey, I did a bunch of research into the type faces of the period. Pretty close to the evidence we have,
Maury
