Everything posted by Nirvana
Mike, It seems like I am to be the first to congrat you on a finalized Tug boat. I am glad the maiden voyage was successful in many ways. Do you have a name yet? If not, here is a suggestion; Sailors Rescue or Tug Along.
- 96 replies
- tugboat
- Tippecanoe Boats
My Lowes store has them in Aisle BW , Bay 86 , just checked online.
- 453 replies
- thermopylae
- sergal
Steve, the best part of it, will be the case as you will get a nice proportional one for the boat. Beautiful done!
- 165 replies
- finished
- model shipways
David, I did a little recon on the web and found that the plywood provided is a sheet made for underlayment between subfloor and top-finish. It has a coarser grain than what we are used to and chips easily, specially the thinner versions. Glad you got a reply from MS and getting you replacement parts.
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
Nirvana replied to Torbogdan's topic in Non-ship/categorised builds
We others will be around awaiting an update whenever you have one. -
David, For a kit coming from MS, I am very surprised to the low quality. Makes me wonder if they contracted someone to keep up with the production. For the money spent on Syren I would expect much much better. Chuck must be furious seeing this. If I were in your shoes, I would have requested a completely new kit. I also have the Syren waiting, but I have had it in my stock for some time...... but it makes me wonder...
Since I am not happy with the grating provided in the kit, I wondered what to do. Today I spent half an hour at my local "second hand shop", and found a sheet of veneer, to my surprise mahogany. It was thin to, so 50 cents later I had it in my hand and this came useful today. It's perfect for the grating and making strips out of. Sadly I don't have any mini table saw, so I used my Japanese fine saw and ripped the sheet. One picture shows the strip in the boat the other how it takes varnish. Sanding varnish - sanding varnish and many more times will make the wood luster. Edit: I am to experiment to make some plywood of this material and try making the steering wheel.
Steve, I truly like what you have done to the Longboat. It's a lot of rigging line to coil for the right length of lines according to the plans.
- 165 replies
- finished
- model shipways
Mike, With that order of yours from Tippecanoe I am almost on the verge to de-friend you............. Just kidding, that T-50 will be the "Ultimate" racer..... Why didn't you order the Venom at the same time?
- 96 replies
- tugboat
- Tippecanoe Boats
Another thing I will change and hopefully I will be able to this with a simple drill-lathe. The included wheel needs to much of work to make it look like one. Look at the included wheel and what I like to strive for. And the real thing. Then the current state of my simulated frames. Even though they will be covered up by the grating.
Wasa by jhart65 - Corel
Nirvana replied to jhart65's topic in - Kit build logs for subjects built from 1501 - 1750
Jhart65, May I suggest you start showing off your Wasa, you have a whole panel of members just waiting to see what you have built. -
Keith You are an inspiration of making small and intricate details. Now I wish I had a lathe and mill to do the same.
Tor, A good morning to you..... This is something I think we all have experience from time to time with MS products..... the close shortness of one item or two. Hopefully you don't have to run out and getting replacement. Forgot to mention, send me a 3 1/2 as it is more than two years ago I had one. -
Gil, I just found the most comfortable chair and following along you build. You have come far with the built. And I like the varnishing you are doing. Considering the last ship, you are going to have this one done in a heart beat. Edit: Some extra history regarding this sailing class. The Dragon class was initiated by the Royal Gothenburg Yacht Club, who gave Norwegian yacht designer Johan Anker a brief for a cheap cruising/racing boat with about 20 square metres (220 sq ft) of sail area.[4] After the Second World War, the boat was considered slow, and genoa and spinnaker was introduced.[4] Since 2008 the Dragon is one of the Vintage Yachting Classes at the Vintage Yachting Games.
- 60 replies
- dragon class
- billing boats
