Hello Friends,
thank you for your encouraging comments.
At the bow of the French corvette, a small seawater pump was installed. Through a water pipe with a suction sieve, water was pumped up.
In the area of the underwater hull 3 more suction sieve were installed.
This suction sieve I made out of brass sheet 0.3 mm.
To prepare, I show the following Series:
Edited by archjofo
Very fine work!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Hello,
the nice words are a motivation again and again.
Thank you for that!
Under no. 244 of my building report I showed the production of hooks for attaching the gunport lids.
This version was not satisfactory for me. The original hooks were of flat metal, not from round material.
So I made the hooks again. This time I let them etching of brass sheet 0.3 mm. That's not very expensive.
The drawing for the exposure film I made with a vector drawing program.
And now here are some pictures that probably speak for themselves, better than my poor translation.
Here the comparison:
Links of the new hook, etched,
the right of the old hooked wire.
The last picture for today a look at the starboard side of the corvette.
Edited by archjofo
Oh yes, the hooks look much better.
Which etching service did you use?
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
It's a one euro cent piece shown as reference, is it not ... which makes the difference between those hooks - but for colour - hardly visible!!! Talking about 'eye for detail' ... stunning
Edited by cog
Carl
Johan very nice details, Thank you for the pictures of the water inlet filters I have filed that away for reference for my own model I will need real working filters and that cap will cover the mesh perfectly.
Michael
Slow but steady
and my season's greetings to you too
Carl
Hello,
I wish you all a happy new year.
The building report continues with  the breeching ropes of the carronades.
The special feature is that the rope in the rear region of the
breech is protected by a leather taping in the form of a tube.
Here are some pictures of the work to breeching ropes.
Johann,
Seeing the Gütermann thread makes me realise the scale you are working at. Great detail jet again
Carl
Hi Johann,
great work on breeshing rope! very nise details, and nice battery of carronades!
Alex
Edited by Alex M
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hello,
in addition to the breeching ropes for carronades I am also working on the breeching ropes for the 18 pounder guns.
A small detail for the height adjustment of the gun barrels had to be done. The straps of the wood blocks had to be installed.
In the background is the breeching rope already seen.
Hello,
here is the continuation of the building report:
The breeching rope is attached to the bulwark with strong staples.
Here I show you the making of these staples made of brass wire with a diameter of 1 mm.
The staples outboard be screwed with square nuts, as shown in the following picture.
Edited by archjofo
Thank you all.
I´m very pleased by yours nice words.
Your comments give me more flavor in the works and I will try to do the best possible result.
Here's a little update of my report.
Look yourself ...
Edited by archjofo
Why the 'rust protection for firearms'?
Carl
That's clear, but why would you use it when you apply the brass blackener, and brass does not rust ...
Carl
