Thanks Edwin & all the Likes. Thank you Chuck - I should have asked you first!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Good questions on the planking JesseLee.  That stern to counter area is tricky, to say the least but it looks like you got it under control now.  Looking really good.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
she's looking super Jesse.......planking should be fun and go smoothly with the way you have it set up  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Now starts the planking. Cutting & filing out around the gun & sweep ports. Glued on some of the first few planks. Here is where you find out if you got the spacing on both sides right on the previous steps. Looking at the sliver of planking under the gun port on each side looks like I am very slightly off by a millimeter or less. Think I can live with that!
Hi Jesse thanks for the like, I'm looking forward to starting, been following your blog a little bit. I will take a lot more notice of yours and others
from now on. It is such a good looking ship, has a bit of everything in it.
Thanks Chris Hooroo
Haven't posted much- have been plugging away at the upper planking around the gun ports. This has been going slow for me. I can only work on it so long & my pain sets In & I have to stop. Anyway I noticed that there was too much of a dip in the planking curve on one side. The planking wasn't lining up at the same height on both sides. A little alcohol & a thin blade got this corrected. Re-glued it & continued on.
Oh, almost forgot to show the method of caulking I ended up using. I tried to do the pencil but I kept indenting the edges of the planks because I couldn't seem to maintain an even pressure as I marked the edges. I also smudged it all over the place. I experimented with a few things & settled on this. I use a makeup sponge applicator thingy my wife dropped on the floor & paint the edge with some black paint. I smear this with my thumb to keep it thin. This seems to work well for me.
Every day as I work on the ship one of our dogs, Lucy, faithfully lays at my feet as long as I work there.
Your planking's progressing nicely Jesse. It's good to have a dog around. I miss mine being here and "helping" me do stuff. Didn't matter what.
GEORGE
Hey Jesse, I like the makeup kit approach to caulking. I went to an art store and bought an artists graphite pencil. the lead is really soft and I didn't have indent problems near what you can have with regular #2 or such. The smudge from the light graphite, especially when sanding, gave the wood a little bit of a weathered look. Anyways you've seen what I did, that was my secret. I also found that creating tree nails was pretty easy with a hard lead pencil - because they do indent well. Trick was to always keep sharp.
Looks awesome.
Slow progress right now. As I neared completing the upper planking I had another area  where the planks didn't line up with the top & bottom of the gun ports the same on both sides so I got out the alcohol & unglued the planks again to rework it so they lined up the same on both port & starboard sides.  (pics to come later). As I am working on that I have been studying ahead & going over others Syren builds. I noticed the plans instruct to make simulated sheaves in the hull sides. I was thinking of making them go through like the real ones and realized that I don't know how to rig this. In the simulated version I would be gluing the end of a line into a false hole. If I were to have a real sheave where does the end of the line go to? Does it pass through the hull to the deck side to a cleat & tie off? Does it end in a coil? Any info that could be provided will help me decide which way I want to do this. If I do real sheave I think I should go on and build them in now before I complete the planking.
I think a simulated sheave would just be 2 holes with a groove etched between them. A real sheave would have a pulley instead of a groove. Both should operate the same way with a line feeding through the hole and through the bulwarks to a pin or cleat, with the remainder coiled. Sheet-lines for instance, would be tied off after going through the sheave.
GEORGE
Hiya Jesse:
Now that you found me, I found you!  Just finished a long post with my bulwark planking struggles, maybe you'll find something useful.  After your comments and work on the counter, I'm going to take another look at that on mine
Good Luck!
Robert
Bye Y'all ! - Robert
Current Build and First Wood Kit:
  Brig Syren MS Kit 1:64
Past Builds, all Plastic 30-40 years ago:
  Revell 1:96 Constitution and United States
  Tamiya 1:350 CVN-65 Enterprise
  Countless other sailing ships and modern warships
Had to pull up some planking where it didn't line up with the gun ports the same on each side.  When I got to the stern I found the same problem. The pencil marks on each side shows I had it half a plank off. Pulled this up & got it right. Added the counter planking. Cut out the gun port holes in the transom  & glued it into place.
Decided not to have the fake sheaves as the kit instructs. I don't have a lot to work with so I made mine by layering pieces of wood. Glued & shaped them. I didn't have an easy way to make pulleys this small so I just put a toothpick through without the pulley. I figure it's so small once the rope is pulled through you wont see the difference anyway. Cut out the spaces for them in the planks & glued them in place. They still look rough- need sanding down & the openings shaped up more even. Will work on this as the planking is done.
Very ingenious. That small stuff is fun to work with but a bit tough on the eyes! Looking good!
(btw - interesting look with the red paint smeared over the gunports before covered up. Looks like a massacre occurred...)
Jesse - I like the fake sheaves, I'm thinking of doing something similar, and think you are spot on that these don't need to be perfect give the impression and the line will obscure any imperfections.
Cheers,
Jason
In the shipyard:
Skipped ahead to the tree nailing of the upper hull area that will be stained. Tested many methods on scrap wood. Tried wood filler, glue/sawdust, brass wire, even broom straw. Brass looked too different. The others didn't turn out looking as overall round. My drilling wasn't so perfect. I remembered seeing Dave Bullocks work in person & how good his looked. He uses the tooth pick method. So that's what I went with. They turned out a little bigger around than I had planned but they all looked perfectly round. I have tried multiple times to load my pics today but they will not load in the right order at all so I will try another day.
I held the tooth picks in my Dremel & sanded them sharp on some sanding sticks- first coarse then fine. Just a dab of glue & stick it in the hole. I snipped them off with fingernail clippers. After sanding them down I am satisfied how they look. I just hope they wont look darker when stained because they show their end grain.
I tested toothpicks for nails in my decking, and when applying clear satin wipe-on poly they got much darker.  You can just make a quick test off the ship to see what they'll look like before investing too much time on the ship itself to make sure you'll be happy with the results.
Great job on the tree nailing so far, I believe you will be happy with the end result. You are definitely moving right along. Looking forward to future updates.
     Happy modeling.
                 Marty G.
Great progress! I like the clean straight edges of your gun ports.
You chose an interesting method for tree nailing. I have never done it with tooth picks. On my first model I used bamboo sticks thinned down to the right (in scale) thickness with a draw plate. It looked fine at the beginning, but as soon as I applied wood stain there was a certain diffusion effect along the edges of the holes and the tree nails and the final result looked a bit larger than intended. Hopefully you won't have this problem  :).
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Fine detail Jesse! After seeing some of the pics of the Hermione it looks as though treenails can be a bit bigger than I had initially thought. Have you seen pics of what they look like on the outside of a ship?
Only a few
Nice job Jesse. have to keep that in mind for mine. Looks really nice.
Current/But Not immediate Build Logs
I am still gathering the tools I need but starting preliminary work. Nothing to show just yet.
Fair American
Armed Virginia Sloop.
Clean work, Jesse! I think those treenails with their end grain are going to contrast nicely with the bulwark planking. You're making fast progress on Syren.
Steve
completed models:
Shenandoah (Corel)
waiting on the shelf:
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Patsy (derisively): "It's only a model."
Arthur: "Sshhh."
neat idea  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Finished the hull planking
Your planking turned out nice and clean Jesse!  Great job!  Now for 10,000 tree-nails?   :D
Cheers
GEORGE
