Seriously fine work. A joy to behold.
Bob
"Even while the storm raged at it's worst, my ship was wholesome and noble." - Captain Joshua Slocum
Current Builds:
L'Hermione 1780 - 1:89 - Artesania Latina   http://modelshipworld.com/index.php/topic/10261-hermione-la-fayette-1780-by-bobstrake-artesania-latina-scale-189/#entry305929<p>
Louise - 1:26 - Constructo  http://modelshipworld.com/index.php/topic/11855-louise-by-bobstrake-constructo-scale-126/?p=360370
Completed Builds:
Carmen 1850 - 1:80 - Constructo - First Build   http://modelshipworld.com/index.php/topic/10398-carmen-1850-by-bobstrake-constructo-scale-180/#entry31137
thank you Bob,
I highly appreciate your kind comment. With this build many things are developing as their sequences are due. But still now and then there are things to keep in mind for improvement along the journey...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, Thanks for showing us how to do the metal wall.  I should have done my HOGA that way.
Bob
Current build:  SS_ Mariefred
Hi Bob,
I just looked up you "Hoga" build log, and yes, the deckhouse (your post #101 there)  and wheelhouse would have been wonderful candidates for "riveted" metal Skin structure. Maybe you are planing an appropriate Oldtimer steamship Project for the future.....
Nils
Current builds
-Lightship Elbe 1
Completed
The drawings I have of the HOGA shows all the interior areas and furnishings.  I'm thinking of doing another HOGA with one side removed.  But there are so many builds on my list.
Bob
wonderful progress you've done so far........have to give that metal overlay a try myself  :)    I have some of that HO scale metal siding  ;)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis,
Thank you, glad you like it,....
I`m not familiar with HO scale metal siding, would be curious to see the result, provided you give it a try..
Nils
I`m quite happy with the results so far
cabin walls painted white
working rooms under forecastle deck
the rear side of the walls with hollow rivets and "glassing ends" sticking out will be hidden under the deck afterwards
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
A little update....
Build log part 18
Part 1 of 2
the long promenade deck has to be roughly fitted, and to be supported with I-beams in the areas of the aft waist (one deck below). Although it`s a later building sequence I`ve been experimenting with the making of bollards, scoop bowls for the vents (there are so many different sizes !)
And also the making of the small 60 mm long lifeboats....., here is a first trial in clinkered version, if it works out OK, that would be my master lifeboat-plug for doing the whole batch in resin cast afterwards, other solutions pending
Nils
here a preliminary adjustment gauge (distances, alignment and perpendicularity of stanchions) is created
the markings will be transferred to the covering deck afterwards
the promenade deck will be made of sections, whereby the center remains open and unplanked
here some of the many bollards are made ( hollow rivets soldered into brass plates, and the center filled with a piece of round rod), then primered
final mounting to a wooden base plate
Current builds
-Lightship Elbe 1
Completed
Part 2 of 2......
these tin, nickel plated feet for bags, will do for making the scoop bowls of some of the vents
first trial for lifeboat production....
scale 1:144, 60 mm long
supports for covering deck
I still had some odd plastic dinghis, from which I cut off the first 30 mm with the bows, glued those together for total 60mm length
added more year 1900 nostalgic (more straight) bow and sternpost (double-ender boats), and dd the lapstrake planking by means of self adhesive metal foil stripes
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Patrick,
in answer to your question.....
in order to save time, and instead of making it from wood, I made the boat from two cut off (30 mm long) front portions of those odd plastic rowboats I still had, by glueing these face to face together. The resembled lapstrake planking is by stripes of self adhesive aluminium foil. Deck and interior of the small lifeboats will be done later. I would be happy if the "masterboat" will allow an appropriate and clean negative mould to be taken from it, for the resin casting of the "mass-production"
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils!
Great project and very nice job. I will be happy to can read this very interesting build log all! Thanks for sharing!
Best regards Antanas
Always can be done better, always can be done more!
My builds:
          1.  75 mm Boat  - Master Korabel;
          2.  95 mm Boat  - Master Korabel;
          3.  Double boat  - Master Korabel;
Hi Antanas,
Thanks for dropping in, you`re always welcome, and I`m glad you like it
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks for your Kind words Boyd,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Crackers,
I`m momentarily in Progress of evaluating if I should rather plank the Long Promenade deck side-portions first, ( it would be easier to handle),  or to glue on These raw-deckparts, to the hull and do the planking later
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Happily I found your latest project as I was visiting Karl's (Jeronimo) newest project 74-gun ship and then I linked from your comments. Looks, as all of your projects do, awesome so far.
Cheers,
Michael
Edited by md1400cs
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
many thanks to Mike and Michael,
and all the "likes"
Mike,
with the lifeboats (how to make) I have to start thinking about at an early stage, because the final solution, resp. improvement / changes is still pending, same as with the many vents on the decks, These I would like to make from metal
Michael,
thanks for your nice words, and welcome to the build log (s)
Nils
Current builds
-Lightship Elbe 1
Completed
quite a bit of progress since I last checked  ;)    very nice work Nils........really coming into shape!    the life boats are really cool.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis,
I`m just working on the forecastle anchor / chain tubes (6 mm brass tubes), they will have to be faired and equipped wih flanges to sides and deck afterwards, but have to be dry fitted now in case some adjustments have to be made inside the ship.
The forecastle deck comprises 3 shaped parts....
The scetch (partial section) shows the arrangement of the other decks, at least how I intend to do them
Nils
Little update :
Current builds
-Lightship Elbe 1
Completed
Love your green clamps.  I'll have to remember that.
Bob
Thanks Bob,
that was one of those "flash-Ideas" I had during lunch today, seeking for a way to pin down the deck without making pinholes into it, as Long as the glue cures, but it`s only a dry fit in the moment
Nils
Current builds
-Lightship Elbe 1
Completed
Lunch ideas
I like this ( sounds familiar)
Nice work, as always
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Thank you very much Nenad,
it does`nt happen too often, with those ideas but sometimes it helps....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils -
I thought that I had read through this log, but somehow I missed it. Seriously good work, my friend!
Spent an enjoyable two hours with it and found several ideas and techniques that will work their way into my own projects.  It was fascinating to see how the techniques that we use are both similar and different because of the scales that we are working in.
I am now hooked into the log for instant updates.
Dan
Hi Dan,
thanks for your words and for looking in....
You`re alltimes very wellcome
Nils
Current builds
-Lightship Elbe 1
Completed
Nils -- So, I go away for just a few days, and when I get back my head spins at how much you've done!!  Don't you sleep?  Fantastic work, with real care for the fine details.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks very much Martin,
I have now made the forecastle deck, planked it and put it on permanently, further the anchor tubes dry fitted in with flanges on the sides.
Some days ago I bought some photo etched copper railing stripes (5 wire plus handrail). Will need to do some trials how to fasten these best. The stripes are only 8mm high (scale 1:144)
Nils
the forecastle deck planked with 2mm wide and 0,8 mm thick stips of pinewood
raw fit, the flange base for the deck side tube ends
I think these stripes can be soldered to L-typ profiles and then fixed to the edges of the deck-planking
a view under the forecastle deck....
Current builds
-Lightship Elbe 1
Completed
