Thank you very much John,
there are so many points to continue with the ships fitting out in the moment, I realy have to try and get them done one by one, although there are so many ideas (thinking ahead in my mind), that I would like to proceed in many different positions at the same time, just to see if the thoughts would work out....
Nils
Current builds
-Lightship Elbe 1
Completed
G'day Nils
Simply fantastic! The tank, staircase and everything else is beyond belief.
Glad again to see a photo with your thumb in it, it shows how small of the scale that you are working in.
Incredible!
Havagooday my friend
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Don't let your mind go in too many directions.  We like you the way you are.  LOL
Bob
Current build:  SS_ Mariefred
Hi Greg and Bob,
Thanks for your nice comments, much appreciated....
Greg,
the credit for the staircase goes to the producer of the etched brass pattern, I only needed to fold it and angle out the steps at appropriate rake, but you`re right, the pattern is a fine thing, complete without soldering, in opposite to the longer forward staircases at the bridge area
Bob,
I`m trying to keep the thoughts in line with the progress
Thanks also to all the "likes" for clicking in
Nils
Current builds
-Lightship Elbe 1
Completed
lots of tiny areas to fill with planking........that'll keep you busy for a while  ;)    looking great Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Kees,
yes, I`m very happy with that wood strip source I found at a web shop. The strips are so precise cut and straight and in tight toleraces that it is a pleasure to do planking even with only 2mm wide strips
Nils
Current builds
-Lightship Elbe 1
Completed
Update.....
Build log part 52
today is the day where the forward boats deck will be permanently glued on. Between brass frame and deck I use CA and  white wood glue between the lower deckhousings and the boatsdeck.
On this part I did not forget to place the connection holding points for the funnel stays. On the lower bridge its a bit tricky to get the convex deck curvature correct and adjusted to the forseen places of the nav light towers, here also used CA, hope its strong enough...
Also today a last chance to have a look into the inside of this liner, as it is now closed for ever after. Like on all my ships I put a short note (description, year of build, etc . ) into the hull before closing the last opening.
Nils
little red tags mark the places for putting the clamps on (whist glueing)
last look at the inside of the hull
below the deck to go on....
the nav light towers are the forward "anchoring points" for the boats deck
forecastle deck
aft deck
deck glued on and clamped down
the boss with the screw is just to curve down the lower bridge wings during glue curing
Current builds
-Lightship Elbe 1
Completed
Hi Joel,
welcome on board and thanks for looking in. I had a good look inside, but there were only some tiny cut off plank bits and some wood chips that vanished in the vacuum cleaner nozzle.
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks a lot Bob,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Christian,
for your kind appreciation...
Nils
Current builds
-Lightship Elbe 1
Completed
G'day Nils
I havto echo the other entries.
A big congratulations on closing the hull!
It looks like end end of the build is coming closer all the time.
Greg
Edited by Greg the peg leg sailor
Congratulations on reaching another major milestone Nils. She is looking just fantastic.
Many thanks Joel - John - Greg - Carl  - Grant,
for your nice compliments, much appreciated ....  :)
I was about to start with the funnels, this weekend, but the supplier of the ordered brass tube let me down now for several weeks already with no delivery  :(
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils your work is very very nice.
Thank you very much Albert,
a kind compliment of yours...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Congratulations on reaching this major milestone. You've gotta be pretty chuffed.
What's more...what can I say? I just wish I was one centimetre tall so that I could sit next to the old passenger on the bench! Now, that'd be really cool.
Cheers Patrick
Edited by Omega1234
Hi Nils
Cheers Patrick
Thank you Patrick,
I think one day I`ll get myself one of those digital endoscope cameras with flexible support to make some "under deck" photographs...
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
I am always surprised by the detail wealth.
Hi Johann,
its fun to bing in the details, at least those I find its worth to model them......, there certainly should be much more, but those have to be ignored...
Nils
Current builds
-Lightship Elbe 1
Completed
Update....
little cabin structure beneath the bridge, and preliminary set up to try position of the first stb. boat (dummy boats cradle only),
There is still so much to do...
as mentioned earlier in this log, some of the upper structures will be of wood, as for the actual ship way back in 1897.
I still did`nt get the ordered "stack- brass tubes", so I chose an alternative material, now its aluminium tube with slightly thicker wall thickness, found at Ebay- Austria, but that should do as well. Expecting this by end this week.
Nils
the structure is only 16,5 mm high. Could be that this is the captain`s quarters...
the crew figurine is "railroad N gauge"  scale 1:160
it must have been about nearly 1000 or more "caulked"  planks to lay over all decks, and still not finished.....
trust that the boats will go on last, when all the upper structures and the four stacks are done
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
G'day Nils
Again bravo on another outstanding piece!
Is the small bridge on the side of the captain's cabin a bridge to the lifeboats?
Lovey small cabin model Nils. Marvelous brass items!
Thanks very much Carl,
I`m glad you like it..
Nils
Current builds
-Lightship Elbe 1
Completed
