After three days of sanding my finger tips off, I've come to two conclusions: first, the frames are now ready to begin planking (the uppermost portion of the frames has not been fully faired yet); second, I don't like the frames enough to leave any part of the hull unplanked. I'm now starting work on the interior planking.
Bob
Hi Bob, Boy they sure look nice to me! Well done.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Bob,
nice work, congratulations on reaching the next stage.  To pick up on the comment by Russ, have you checked the fairing with a plank to see if they are properly faired? I was a little sloppy with mine, which created some problems getting the planks to sit right.....which led to more work to rectify and fudge things to get it to look right. I was forced to conclude that it is easier to fix things before they compound into larger problems.
Regards,
Grant.
The hull is looking very good. Congrats to reach this first milestone of your build.
Regards Christian
Planking is now underway. I began by installing the keelson and then did the limber strakes and limber boards. I also did the ceiling out to the first thickstuff. All of the planking was done with boxwood. After installing and trimming the planking, I treenailed it, using bamboo skewers and a Byrnes drawplate. I found the hardest thing to do was to split the bamboo skewers into pieces small enough to go through the drawplate. The treenails will show better when finish is applied to the planking. Interior planking will now continue out to the lower deck clamps.
Bob
Bob, I really like the look of your limber boards. The treenails are looking good. Would you tell us what the size of your treenails pictured are? Ah yes, splitting
the bamboo. Now there's the rub. ;)
Your doing a great job.
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Nice work, Bob.  Correction, make that excellent work.
Thanks, Paddy and Mark. Paddy, I'm not really sure about the size of the tree nails. The bamboo was reduced to #33 on the draw plate, whatever that works out to.
Bob
Beautiful work Bob. I look forward to seeing more of your build.
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
That is beautifully faired. Everything looks very smooth though the camera seems to be yellowing some of the shots (presumably the flash) which hides the beauty of the wood (which you can see in the more natural light ones)
Joss
Bob,
I would suggest to glue the thicker planks for the deck beams and so on first. So you can easier avoid culmulative errors by the planking job.
I start the planking exakt in the same way and had the prob with these errors.
Regards Christian
Bob,
you have done a fine job so far, it's looking great. Christian has it right, get your deck beam clamps accurately in place first, then adjust the width of the planks (if neccessary), to fit the space between them and the lower planking already installed.
Regards,
Grant.
.......... The bamboo was reduced to #33 on the draw plate, whatever that works out to.
Bob
Thanks Bob.
The actual size and not scale size was what I was referring too. I should have been more specific in the question. Again, fine work.
I had the Lilliputians treenail folks at work again yesterday as I waited for some glue to dry. They’re learning more about trennals production as we go along. ;)
Work in Progress -
Thanks to all. Christian and Grant, I had already come to that conclusion and had done the lower deck clamps before continuing with the planking. The result is that I will only have to adjust one plank up to that point.
The bad news, Paddy is that there are lots of treenails. The good news is that you lern some tricks to make it easier as you go along. Very much like ratlines.
Bob
I've completed the interior planking up to the lower deck clamps. I've also done the treenailing up to that point. Lastly, I put on one coat of Wipe-on Poly for some protection. I will do additional finish coats later.
Next up will be the wales and the exterior planking from the keel up to the wales. With the frames now quite rigid with the addition of the interior planking, I will do some more fairing on the exterior before doing the planking.
Bob
Beautiful planking, Bob.  Just beautiful.
