Another itty bitty update.
I beveled the stern bulkheads and glued them in place, then added a few little bits that don't show up in the photo's very well (side braces between the 2nd and 3rd bulkhead and a brace between the pieces on either side of the keel under the last stern bulkhead).
Then I got the rest of the bulkheads cut out and cleaned up some of the laser char.  For those building this kit in the future, *warning* these things are extremely fragile and if you forget to support the side of the bulkhead you are working on and try to hold it from the other side, they absolutely WILL break at the center.  Don't ask how I know this.   :rolleyes:
Primed with Vallejo Air grey primer, and then painted with Vallejo Air "US Blue Grey" using an airbrush.
post-14925-0-05316200-1462254378_thumb.jpgpost-14925-0-25123100-1462254379_thumb.jpgpost-14925-0-30479700-1462254380_thumb.jpgpost-14925-0-27221800-1462254381_thumb.jpgpost-14925-0-18285900-1462254382_thumb.jpgpost-14925-0-09141900-1462254383_thumb.jpg
There is a documentary video by the History Channel about this boat and the sinking of the Albemarle.  I picked up the video when I built this model.  I don't remember the cost but it was very reasonable.  They painted the hull white or light gray probably due to the night attack would have made the boat almost invisible.  Other than that it's a good film.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Kurt
Sent you a PM a while back Kurt, did you ever get it?
Brian:
OOPS, I got it - dug out the copies and then forgot to follow through.  PM on the way.
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
What is better than one really slowly progressing build log?  Why TWO really slowly progressing build logs of course!
Coming soon to a forum near you, because I'm dumb and can't wait to start working on this...
When I start this it will be in the Kit sub-forum, as the general consensus I've seen in the discussions surrounding 'kit vs. scratch' comes down to making your own keel/bulkheads or frames, and I'm using the laser-cut pieces for this very important part of the construction.
Ha ha Brian, you have the modeling bug bad!!  Sounds like me...  I always seem to be finishing one model but starting 2 more... :)
Mike Shanks
Good stuff Brian, looking forward to watching both come alive.
Me too! Maybe I will build her in the next 20 years :D!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Brian,
Fascinating. .  .  .  .
How did you bevel your bulkheads in a way that looks so uniform? I like the planking plan that is laid out on the bulkheads so clearly.
Looking forward to seeing more.
Respectfully,
John
John, the bevel lines are laser etched on the bulkheads, just have to sand down to the line.
So I finally got the wood I've been waiting for, so I started to do some work on the picket boat.
There are a number of different deck parts on this kit that are just 1/16" thick basswood, and the instructions are to 'scribe' the lines onto the decks to simulate planks.  This is probably because those decks are supposed to be painted (or stained) in the instructions, but I don't care for how the scribed decks look, and I also think I want to keep the planked deck portions natural wood to contrast with the painted hull, so I got some 1/32" thick Swiss Pear, and I'm planking all those sections, like most of the other builders of this kit have done before me.
On the left, the basswood that I'm supposed to scribe fake planking into prior to staining it.  This is the floor of the rear cockpit.  On the right is the first planked section with Swiss Pear.  Then both parts complete.  It will darken up a bit when it gets a coating of wipe on poly.
The large floor sections of the main cockpit of the boat, again showing the basswood kit piece, and then the planked but not yet trimmed down piece, and then after finishing it.
I have the benches of the rear cockpit, the deck of the bow and stern, and some bulkheads that are exposed to do.  Some of those parts get margin planks, so they'll be a bit trickier and require cutting custom shaped planks out of 1/32" sheet rather than using straight planking.
Hopefully I'll get some more done this weekend and post another update.
Brian,
I love the pear.  It's a great wood to work with, IMO.    Got a question for you.  Did you fit the decks before planking?  I'm asking because of the notches and a couple of models I did, you couldn't plank the deck until it was fitted otherwise you'd have some big gaps where the notches are.
Nope!
Guess we'll see how it goes.  I did do a couple test fits of just seeing how tight the slots fit over the bulkheads without them being assembled at all, and they seemed like a very good fit.
Thanks,
Looking good Brian.  I'm interested in seeing all the upgrades you do to this model.  I am building mine straight from the box and just completed painting of the hull.
Mike Shanks
My time in the shop has been really limited, but I have made some slight progress on the picket boat.
I finished the other main cockpit deck.
And then I started working on planking the faces of the bulkheads that will be exposed when everything is completed.
post-14925-0-62755500-1466985080_thumb.jpgpost-14925-0-19432400-1466985081_thumb.jpgpost-14925-0-70025300-1466985081_thumb.jpgpost-14925-0-22719800-1466985082_thumb.jpg
I have a couple more bulkheads to plank, but they were stupidly already attached to the keel prior to realizing that they would be exposed, oops.  I am going to try to plank them in place, we'll see how that goes.  In the meantime I decided to work on one of the tricky pieces, the bow deck.  This piece is tricky because of the two sections of margin plank that are curved and funky-shaped at the stem.  Because of this, these pieces need to be custom cut out of a wider sheet of wood.  I tried three times to get it right by tracing the outside of the deck and then measuring and tweaking, and this was the best of the three attempts:
At this point was when I realized that I'm a stupid idiot.  I have plans, I have a scanner, and I have a laser printer.  Also, I'm apparently too stupid to think of using those tools to make a thing called a pattern.  Anyway, I scanned in the part of the plans with the bow, then messed around with the printer settings until I nailed the proper settings to get it to print in exact scale (because for whatever stupid reason the image the scanner makes is not the right scale when printed actual size).  I cut out the appropriate part of the printed plan, and pasted them to the sheet of wood.
What do you know, using that 'pattern' thing is actually a pretty good way to make things.  Who knew.
This was the first piece cut out using the patterns.
Other than cutting the front shape a little odd, it's almost perfect, and having the front over-sized isn't a big deal, I can trim it back when it's done.
The second part glued up with pattern still attached, and then removed.
I had to do a bit of careful trimming and sanding to the inside of the curve right at the bow because I managed to glue the 2nd piece in place slightly out of alignment with the first one, but some patience and sandpaper wrapped around the round end of a small file took care of it so that I could start the planking.  I laid a 5/16" center plank and then started placing 1/4" planks to either side.  Matching the curve at the end was easier than I thought, and this part went pretty well without a hitch.
And the finished bow deck with a coat of wipe on poly.
Still have to plank the stern which will require a 3-piece margin plank and then a couple of benches for the aft cockpit and the two bulkheads that are already attached to the keel  I am also going to have to re-do one of the bulkheads because I realized that I didn't account for the propeller shaft coming through it, and made the planking notch way too high.
Brian,
One thing about scanners.. they don't do exactly 100%.   Some stupidity about counterfeiting money..   :D  :D   So... either buy a small ruler or make a small ruler on some paper and scan it with your plans/patterns.  I pull the drawing into CorelDraw and adjust that the ruler is correct size, then print.  Or... you just  copy/print from the scanner/printer (assuming it's an all in one device) and adjust the size as you print.
Your foredeck came out great in spite of the problems.
