Entry by Woodeater,  I thought his method was pretty slick.
Click on woodeather (2nd down) not Bob Cleek's at the top though that's useful information as well.
Edited by Keith Black
Pat - I'd be inclined to try Carl's method. Rather than using wire though the holes I'd use a steel dressmakers pin as it is likely to be stiffer than wire.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi all, and many thanks for the feedback/suggestions; they are much appreciated.
Mark -  the straps are already photoetched with the holes.  my attempts to drill holes at this size resulted in some very 'ugly' results :)
Carl and Keith (A) - that is the method I am currently using, but overnight I also thought of trying this with the stub of a suitably sized drill bit.  the greatest difficulty is getting the bend started nicely and consistently at the right point as any over pressured attempts see the legs bending at the inner most holes unfortunately.
Keith (B) -  mate, I am not quite sure I could achieve that at this scale :)  The 'notches' would need to be cut only .4mm deep and very accurately placed as these straps are already pre-etched.  That said, this is a great suggestion for the future as I would etch those notches as part of the process.
Eberhard - I will also try this today (wood version as I don't have a dapping block)  and see how it goes.  Splitting the block correctly (accurately) will be the challenge :)
I am also thinking of remaking the bending jig with a narrow hardwood wood base (to fit in a vise), then fit a (broken) drill bit of appropriate diameter into one end about the length of the folded strap back from the end.  I will insert (upright) an offcut of flat brass plate the same thickness as the lower strap between the drill bit and the end (to maintain the correct separation.  If I achieve this, and using the drill bit to align the lower holes of each leg, I may be able to get better (more consistent) results.
I  am finding that whichever method I use, the critical step is the initial bend point being 'on centre' - that is where I am having the real issues.
cheers (and many thanks again)
Pat
Edited by BANYAN
I didn't realize the holes were pre-drilled.  Have you thought of small pliers (needle nose type) with on jaw that round?  I recall seeing them used.  The ones that have, the rounded part is tapered but I've also seen some here that non-tapered.  Not sure if they're custom made or can be bought.
If you use a rod to bend it around this requires far less accurate bending in the beginning. The importance is to have a rod slightly undersized, so you can get the ends meet flat-ish
Carl
Hi all, bit the bullet after some further experimenting and decided an improved version of what I was doing was the better solution.
I made a jig (see photo) which has the spacer piece in the wake of the mandrel (end of 0.6mm drill bit) - this is exactly in line although the photo does not show it too well.  The length of the 'blade' allows the legs of the strap to be folded back and roughly aligned with a broken drill bit (agin 0.6mm) used to get the bottom holes roughly in line.
The important bit here as I suspected, was to put an initial bend on the centre of the strap for which I used a pair of wire bending pliers (smallest diameter).  The drill bit needs to be long enough to provide a good grip on the protruding ends as I found that if I offered the assembled rough bend onto the vertical mandrel them  applied pressure by pulling back from the mandrel it was easier to get a consistent bend.
The other important part of the technique was to apply pressure to the full length of the straps as starting at the mandrel end resulted in kinking of the legs and overall bend.  Bit tough on the fingertips but no blood donated to this part of the build (yet) :)
Once I got on a role it only took 30 minutes to produce 40 of them.  the result is not too bad and once filed (cleaned up) should look acceptable.  Here is one rigmaiden lanyard I have assembled but not yet attached to the chain plate.  Still some cleaning up to do, but to the eye they look pretty good - this is taken at macro range.
Next job is to solder a small piece of plate in the throat of the bend above the upper holes which acts both as a spacer and as a preventer (to stop the untensioned lines/shackles for the shrouds sliding down between the straps.
I also need to build a jig to hold the chain plate eye steady while I pein the end of a brass nail (cut to length) placed through the split eye of the chain plate and the larger hole in the end of the rigmaiden lanyard.
cheers
Pat
Well executed.
Rob
Current build:
Finished build:
Current build(On hold):
Well done and looking good, Pat.
Thanks very much all,  I am glad to be finally making some progress with this.
cheers
Pat
Hi Pat
I've been reading your build log from the beginning and I just wanted to stick my head in to compliment you on your work.  You've produced some very fine details which is a real challenge at this scale, and the model in general is looking very sharp.  Very clean work and pleasing to the eye.
Gary
Completed Scratch Builds
Hi Pat and Steven, thanks for looking in and the compliments guys, much appreciate them as they are great incentives to keep progressing the build.
Steven, the ruler is bi'lingual' -  some posts just don't show the metric part - but you have the gist of it :)
Things have been quiet in the dockyard  while I have been researching the 'rig' and sail plans.  In the interim I have been progressing the 'Rigmaiden' lanyards so they are ready to go when I need them.  I have also started making the carriage components for the broadside guns.
Things may go very quiet for about 8 weeks or so as I am about to head off on a holiday to the UK, and when I return I have to go in for the first of the 'bionic' replacement parts (total hip replacement) so that will slow me up a little :(   The 'Admiral' has insisted I put as much effort into prepping the holiday as researching the ship, or..... :)
cheers
Pat
Edited by BANYAN
Knowing the amount of effort you put into ship research, is such a thing humanly possible?☺️
Steven
I wonder myself :)  - The Admiral has granted a 'leave pass' so I think I am treading on safe ground so far ;)
Thanks for the compliment.
cheers
Pat
Edited by BANYAN
Ah, the essential missing information. Hmmm, so you should have been in bed, but are stealthily moving through the house and in the workshop ;)
Edited by cog
Carl
I take it that this is a "double secret furlough"?  Much like the "double, secret probation" from Animal House?
Just back guys and catching up on all the logs - great furlough (as Patrick puts it ;) ).  I was able to visit Portsmouth (Warrior and Victory), Bucklars Hard, Royal Yacht Britannia and SS Great Britain amongst the other tour visits - so very worthwhile.
cheers
Pat
You did get around Pat - and which was your favourite?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith - HMS Warrior by a long shot :)  There was a very informative guide on Warrior who gave us a lot of his time discussing the armament and other fittings.  We (4 of us) also had unfettered access, with another guide taking us into areas normally not open - which was great :)  Also, I must confess as she is contemporary to Victoria (as was SS Great Britain) this sways me a little.
That is not to say I did not enjoy the other, it is just that the Warrior visit was less 'tourist' oriented.
cheers
Pat
Pat - I have to agree - I live 60 minutes away and have visited many times,  I never tire of the experience.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
