Juzek
As the angle at which the garboard strake meets the rabbet is dynamic, will you adjust the angle of the initial cut of rabbet with chisels as you show in the photos of the rabbet at the stem or will you use some other method to finish the rabbet?
Allan
Absolutely beautiful work and documented with excellent photography.  I own these plans and will follow you through this entire build.
Bill
Kate Cory Scratch Built
Previous Builds:
Benjamin W. Latham Scratch Built
H A Parks Skipjack Scratch Built
Charles W. Morgan Model Shipways Kit
Rattlesnake Model Shipways Kit
Diligence Model Shipways Kit
