Ok Dr. Per the President is here! Bill you move very fast. I was going to suggest a group build with Mr. Per joining us. But You have already passed me. Like Per I found the templates to be the wrong scale. I managed to reprint them correctly. but then I found that did not match the shear. So I am going to just use the batten as a guide and frame the ports this weekend. I will dig around and resurrect my log.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Bill,
Very nice and tight build.........
Respectfully
I like the progress you have made.   Now I can follow you.
Starting the Model Shipways U.S. Brig Syren
Working on the Caldercraft HMS Snake
Completed Scratch Built of Russian Armed Merchant Ship Neva 1801-1805
Scratch Commercial Fishing Vessels
Ahh! Good! Another Syren build, and I am late to the party. Mind if I sit by and enjoy? This is also on my list of future builds.
~john
38 minutes ago, reklein said:
The upper planking is done,and the garboard and two lower planks installed. Now to measure in the rest of the planking. Should be fun , just need to be patient.
I bought a package of those metal clips you are using for my last build. All of mine broke. All the flat clamping parts broke in half near the holes. The clamps were very expensive. May be I had a bad batch?   Are yours holdering up?  While I was in Idaho a few weeks ago I bought two dozen of those Emery Boards.  I sure like them.
I have broken both the flat piece and twisted the handle off the screw. I made some plastic washers to replace the flat pieces. Right now I'm more worried about closing up the space with an even umber of planks. Next few days will show. I got a couple extra books on the subject. Also I'll be saved by the fact I'm going to copper her. So as long as she comes out smooth ,I'll be happy.
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Good Idea with the plastic or even metal washers.  I do like using them.
Bill, I thought this were to be a club build, but with your speed some of us have a hard time to keep up!
Looking good though and the coppering will hide the errors occurring from the planking.B)
Guess mine will look even worse once getting there.
Respectfully
I don't have so much speed as I do time. I got lots of time in my shop and really enjoy it. That's about two weeks of 2-4 hours a day. These little ships with their narrow planking are sorta tough. The challenge is what its about though. one of these days I will get the planking right and not have to cover it.
Bill, in Idaho
OK after three different applications of filler. That is fill,sand,fill again, fill again and sand again I think I'm ready to put a coat of sanding sealer on before the coppering. I have to look ahead in the book to see when the interior planking and decking go in.Its sanded to 150 which is where I'll stay since copper goes on.
Bill, in Idaho
It is looking ready Bill.
Have you done coppering before - it looks tricky to me!!
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Bill,
Thank you for being ahead of me and Floyd, now we can ask you how to proceed with each step along the way!
Respectfully
Doug, I coppered a BJ Constitution but haven't finished it after 12 years. I think somewhere on here is a log of how I did it unless it was before the crash.
Dr.Per you might benefit most by seeing what not to do.
        I was looking in the book and I see that the sheer strake and wales are next. I'm trying to figure out how best to get a nice clean paint job. I was thinking about pre painting them but it would be tough to bend unless I bent them first. Hmm. The other way is paint them after but the hull will have to be sealed as paint tends to run in unsealed wood even under masking.
Bill, in Idaho
OK ,got the stern closed in but not quite detailed on the stern side of it. The interior framing has been sanded thin and ready for the interior planking. I'll need to put the filler piece in first. I used a dremel and sanding drum and or a coarse wood bit to thin out . Had to take about a sixteenth over all. Check it out.
Bill, in Idaho
Just noticed how close in construction methods this build is to Maturins Modelshipways Constitution.
Bill, in Idaho
Hi Bill:
Very nice looking planking - and build overall.
hamilton
Looks nice so far. I do have one question: the two gunports in the stern appear to be different widths. Is that intentional, or an optical illusion?
Thanks for pointing that out. Now I'll have to go look and see if its not just the angle. Sometimes one gets too close to the work or works too long.
Bill, in Idaho
Well Eric.good eye. Did a little whittling and some paint and got em a little closer. hopefully won't be too noticeable..I both hate it when that happens but am glad it was caught early enough to fix.
Bill, in Idaho
OK, little more progress made the bullrail planking has been finished and sanded. then painting was accomplished and the toprail installed along with the molded trim.
Bill, in Idaho
Bill, I'm glad it was worth pointing out. Always feels awkward to do so, but it seems that most people would prefer the peanut gallery to ask questions and such.
Nice work.  I can't use CA glue anymore. Not even the expensive "no smell" variety.   I have been using only Titebond II.  Which really slows my progress.  What kind of finish are you going to be putting on the deck?
