Gorgeous work, Siggi.
Thank you Keith and also all who give me there likes.
It is done, also the port side is ready. The next thing would be the anchor lining.
Regards,
Siggi
Recent build: HMS Tiger (1747)
Gokstad ship (ca900) scratch build
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
Hi Siggi,
Quality level of your model is beyond the scale!!!
At that stage it's already a masterpiece... damm... when it will be competed that will be insane! 🤯🤯
Are you planning to build the model full rigged?
Siggi... also I'm constantly forgetting to ask you... what kind of alloy you were using for casting your guns?
Cheers!
Matt
Hello,
I'm busy with building the hinges for the port lids. For that I chiseled with an engraver a die out of a piece of steel and hardened it.
The hinges itself I build from copper wire, hammered slightly flat, bent one end back and soldered it with tin
Then I hammered it into the mould
filed the surface at the back flat
and at the disk sander I cut the sidelines flat
The drilling I made by eye, 0,65 mm Ø
And with that I rounded the back of the hinge
And that is it, also with a prototype of an hinge pin. The pin is made from 0,6 mm brass wire.
So, I think that I'm busy with them the next days. Today I build 10 hinges within 1,5 hours and I need 84 of them. 😟
Edited by Siggi52
Regards,
Siggi
Sigge, it's a lot of steps to get to the finished hinge but they come out looking great. True dedication.
12 hours ago, Siggi52 said:
Gracias Jorge por el cumplido y también a Noel por la explicación, estabas unos minutos más rápido que yo.
Gracias.
-HMS Tritón 1/48 1773 en scracht (TERMINADO)
-HMS Winchelsea 1/35  1764 full scracht (EN PROYECTO)
Thank you for your likes and comments,
and here the reason why I started to make the hinges. I would have all port lids ready for painting when I at least paint the hull. But there are those who get the anchor lining. But now they are also ready.
Regards,
Siggi
Hello Druxey,
for this time, or ship typ (60 gunner), I think it's not so unusual. But often the anchor lining is not drawn in the draughts or build at the models. If they where'd there, or not, I don't know.
Here some examples, the Centurion 1732
A Warship 1745, even with a bolster below the wales
2016693987_Bildschirmfoto2021-02-09um09_13_36.jpg.b54b2f3b54c3dea6031ffff488ba7121.jpg
Ipswich 1730
1473575004_Bildschirmfoto2021-02-09um09_15_35.jpg.e6b771d9852a94db2cb9aefbfe395eb9.jpg
Standart 1782 (64 guns)
1429628700_Bildschirmfoto2021-02-09um09_18_58.jpg.592ac62ebaaee10eaea6c372f1fa5496.jpg
And a warship 1735
1129797489_Bildschirmfoto2021-02-09um09_23_55.jpg.0019cd5c0605859b74213f806ef2a533.jpg
And then arose, when looking at this picture a question. This model has the hinges on top of the lid and not as I build it, under the lining. I build it so, because at the second picture the hinges are there at the lid, but the left one is under the lining. Godwin wrote that they replaced the lining when it's worn out, so I think the Hinges must be under the lining. May be it's a shortcut of the modeller of this model?
Edited by Siggi52
Regards,
Siggi
I understand this arrangement and don't question it, Siggi but, in general, it is unusual! I imagine the hinges would be well protected when under the replaceable lining. Also, even when not shown on the draughts, the lining would have been there.
I'm with you Druxey.
From the, I think six 60 gunner who where build after the 1745 establishment, the Tiger is the only one where the lining is drawn at the plan. And that is I think, because it's a ship build at a privat yard. So the plans where a little more detailed, also with the art work.
With the models it's not the same, but the modellers would show the ship. So some small things where left out ore where simplified build.
Regards,
Siggi
Hello, and many thanks for your likes and comments
I have been a little lazy at the yard the last 14 days, because of the wonderful weather we had here in the northern part of Germany. Last week we had here winter with 5-10 cm snow and temperatures down to -15°C (5°F). This week the opposite, spring with 15-20°C (41-68°F) and mostly bright sunshine 😊
That was the sunrise this morning, the yellow color comes from the Sahara desert dust, that came with the warm winds.
But today I started at the yard with the sheave blocks
Edited by Siggi52
Regards,
Siggi
Hello,
today I finished the sheave blocks at the starboard side. The next thing would be the rest of the rails and scrolls 😕 I will see how it works
1338516103_Bildschirmfoto2021-02-27um14_28_03.jpg.db25b1dbb73d5ad19023be99b36d9761.jpg
Regards,
Siggi
Marc, that was't my idea. Here some pictures from the Centurion. At the warship I also had the opportunity to see at Chatham it is the same. Only the pictures I made are not so good.
2098892596_Bildschirmfoto2021-02-27um16_06_50.jpg.8cc108f3c88c21cb6ad19296999e7457.jpg
2144360101_Bildschirmfoto2021-02-27um16_06_20.jpg.be657f2612818e52d80406368b5d4b37.jpg
Regards,
Siggi
Mark, which yellow color did you mean? That below the wales? That is the final color.
Now I will first finish the outside of the hull, with all that is possible except the stern. Inside the hull I have build all I could do. But as you know, you could't install the cannons before you have the outside ready. Then when the hull is from the outside ready, I go on and build the rest of the inside and with it also the stern.
Regards,
Siggi
I think what governs the depth of the fixed blocks is the diameter of the sheave in it. In the photograph above, the sheave diameter is more than the thickness of the bulwark it is installed in.
Good morning Druxey,
in later models you would't see such blocks. Mostly they are plain.
Your theory is the same as the question: what was first, the egg or the hen.
Regards,
Siggi
Hello and many thanks for your likes and comments
The carpenters cut a lot of wood the last days. At least I'm not sure where to start, but I tend to make first the drift rails and the fife rails only at the poop deck. After they are installed I could better fit in the scrolls, or hansing pieces.
Edited by Siggi52
Regards,
Siggi
