They look perfectly to scale  - some canons in kits that I have seen (and used)  have been way over scale.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Looking at them, next to the ones that came in the kit, you can really see the difference.  The ones Mantua provided were way oversized for the upper deck.  I’m glad that I decided to make the rest myself.  I’m very happy with how they are turning out.
Building:
Excellent work.
OC.
Current builds
Completed works.
Recently read through you entire build. Enjoyed the trip. What caught my eye was your reference to a book entitled Historic Ship Models by Wolfram Zu Mondfeld.... so much so I ordered it off the internet for $8. For $8 who could go wrong. Thanks for following my Victory build and all your positive comments. Should have the copper tiles completed today!
I’m glad that you enjoyed the build log.  I’ve learned a lot from this build.  Zu Monfeld’s book is my personal favorite quick reference for model ship building.  I’ve read it so many times that I‘ve had to replace it twice.
Well done on the copper tiling!
Building:
Note to self person: if I’m going to use acrylic paint on pieces made from card, then perhaps I should consider sealing said parts first to avoid problems with them delaminating and generally falling apart.
Seriously though, I had the same problem with the gun carriages on the Prince de Neufchatel too, so if you plan on making models from card then I would recommend sealing prior to painting.
Building:
Thank you all for the comments and the likes!
For this week’s episode of And Now For Something Completely Different, we have an M5A1 Staurt in 28mm Scale:
I had to build it.
It did not come with decals, so I freehanded the markings.
Edited by GrandpaPhil
Building:
I’ve been working on the cannon and carronades.
All barrels are glued to their carriages or sled as appropriate.
I made the jackscrews for the carronades.
I started making the iron banding.
I’ll make the eyebolts for the breeches on the cannon because of the diameter of the line that will be used for a breeching line.
I am using the Tichy eyebolts for the eyebolts going on the carriages.
I will install those after I finish all paint work.  As a quick side note, the deck block, which is part of the ship’s framing, will be getting repainted brown.
I did, however come to the decision to make the block and tackle systems, provided I have room.
The guns going into the upper gun deck will only have breech ropes and inhaul tackle, but I am intending to fully rig the quarter and spar deck guns/carronades.
I bought the double blocks from Model Expo last week.
Building:
You are a glutton for punishment Phil. So many small and detailed guns, I admire your dedication.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Received the book Saturday that you recommended entitled Historic Ship Models by Wolfram Zu Mondfeld. You were right.... the book is very informative and read half of it the first night.  Lots of information that you can use on the Victory and other builds.  Lots of little things that you wouldn't think of to put that extra bit of detail on your model.  Thanks again for the recommendation.
Edited by Daliab
Thank you everyone for the comments and the likes!
I am having a blast with this build.  It is giving me the opportunity to try out new techniques for my next builds, without having to worry about making mistakes.
The hull is twisted, which cannot be fixed, so I am using the Victory as a learning tool and having a lot of fun in the process.
I will have to revise my carriage making techniques for next time because of some difficulties with the card stock delaminating.
For my next build, during the creation and assembly of my bulkheads and center keel, I want to try to make a deck insert in the lower part of the hull, like Chris Watton does, to give the hull more rigidity and hopefully prevent the twisting issues that I have had in my last two builds, while ensuring that my bulkheads are squared off prior to gluing.  I am also going to make a proper building board next time to ensure proper support for the center keel.
Building:
GrandPhil
Trying to learn from other's mistakes..... I'm trying get wrap my head around how your last two builds have became twisted.   Was the mistake due to not having a brace holding the keel straight?  Before I started the build on my Victory, there were lots of cautions about how to prevent builds from getting twisted.  A couple of causes from what I read was not ensuring the keel was straight and the other was in the planking process.  Planking: Only do a few planks on one side and then plank the opposite side in the same manner.  As for the keel, I made my own keel clamp from pictures of someone else's on this website. (would give credit if I remembered who).
I left the build in the vice until I was almost finished planking.  Haven't had any issues that I can see.  Message me and I can provide you additional pictures and text to make your own if you would like.  Hope this helps you in the next build.
20200220_121208_resized.jpg.dcca21c6c9174fbe2a1b697c79dd055a.jpg20200220_121222_resized.jpg
Edited by Daliab
I had three things working against me for this build.  The first is that the kit dates from 1991 and the plywood was not the greatest.  The second is that I did not use a building board (so it was unbraced).  The third was my own inexperience.  I know much more now than when I started.
For the Prince de Neufchatel, I used Elmers glue on it, for everything, and it warped badly.  For any future card builds, I will use PVA glue, namely Monte Mart, as it is not water based.  I did not use a building board for that one either.
I will be using a building board for my next build, to ensure that the keel is kept straight.
Building:
Phil, how can you tell the year?  I thought I got a great deal on this same victory kit on eBay (cost me $125 total!).  Once I received it and opened it up I thought the quality of wood was great, however, everything will need to be cutout with I assume a jig saw as it is not laser or stamped.  Was yours?  I’m guessing it is late 80’s early 90’s, but I don’t know when they started stamping or precutting the wood.  Any idea?
Mine was first generation laser cut.
I found the date on the original sales receipt, in the box.
I have a Mantua Constitution from the same time period and it is also printed wood and not precut.
Personally, I’d use either a coping saw, a jigsaw or a scroll-saw, depending on how you wanted to cut them out.
Don’t get me wrong, for the age of the kit, the quality of the wood was good.  However, it was still over 25 years old when I got it.  Plus, I bought it from someone in the desert and I live in a temperate zone, with high humidity.  I made the problem worse because I started it a couple weeks after I got it, so the wood had no time to season in my climate.
Building:
I figure I’ll do the same as you and hope for the best and just get better.  Plus after cutting all the pieces I’ll have to have gained skills lol.  If it comes out half as good as yours I’ll be happy.  Your guns look great btw.
GrandpaPhil.... here you go for your next build.  It works great.
2 pieces held together with stovepipe bolts.  Cut a channel that is just smaller than the thickness of your keel.
