Ok Guys and Gals yet another 9 months have passed since my last post. In that time I have got a new job which took up a lot of my time, so when I was furloughed in March I thought I would start on it again. I'm still working on the figurehead (which is doing my head in) but I decided to move onto the detail on the hull for a while and go back to the figurehead later with a fresh pair of eyes so to speak. I ummed and arrred as to how to do the detail and even whether to do it at all, seeing as it is all very small. Anyway I decided I would do it and this is the result. I've got to paint them to blend them in but thought I'd post progress pics so far. I also had a practise run of fitting the front guns, which I will be painting and I must admit I;m really chuffed at what I've done so far and can't wait to start on the other side. Hope you all like the pics and I'll post more as I do more.
Lin,
I have an interest in the Leda class frigates.   To be specific, HMS Shannon.  I have lofted the timbers.  I also lofted USS Chesapeake.  I thought that the pair would be interesting together, as singleton stand alone POF.  I am not into diorama.  Because Leda is a copy of L' Hebe and La Venus is a sister of Hebe, I considered ANCRE Venus and what with the POF supplement I thought that I had my in.  But, for my method, they still whiffed on the plans.  I used the NMM plans for HMS Leda, as beat up as they are.
Which plans did you use to build the hull?
Did you build the hull - POF,  POB,  solid carved?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Hi Lin,
Nice progress you are making.
If you are struggling with carving Then the route previously mentioned by David (aka Shipyard Sid) of using Sculpey isn’t a bad one, I went down that route and the result is below, just a bit of painting to go and it will do. It’s also fairly inexpensive and easy to work.
Gary
19 hours ago, Jaager said:
Lin,
I don't have any plans for it at all. I've built a couple of wooden model kits and used those plans to help me but I researched the shape and the rest is from photos that I've taken and got from the internet. It's a plank on frame 😊
18 hours ago, Morgan said:
Hi Lin,
Gary
I've done the head and body which I carved from scratch. It's the waistband and swirls that I'm having trouble with. I will try sculpey though...I'm just procrastinating really 😅
You might try tissue paper - the stuff used to wrap pretentious gifts - or rag bond paper for thick - to simulate cloth.  PVA will bond it and shellac will fill the pores and take any paint.
NRG member 50 years
Current:
NMS
Other
Ok so more pics as promised. I finished putting on all the extra little bits on the sides and also finished the scuppers. I couldn't wait to see what they looked like painted and I must say they look rather good. I then decided to get the guns ready (still procrastinating about the figurehead at this time ?😉) . Rubbed them down sprayed them with grey prime then with matt black spray paint. Once they were dry, it had to be done, I had to see what they'd look like in situ. Again well chuffed with the outcome. Moving on to the chains on the rear gun ports that were closed. I looked for a chain that was small enough but couldn't find anything so, again because they're so small I thought I'd adapt...I know what you're all going to say that it's wrong but it's all I could do whilst in lockdown, however I think now I've painted them they look good as well 😄
Looks good. I don't think your wrong on using what you used for the port chains.
So the other day I bit the bullet and started finishing the figurehead. Again it might not be perfect but it's about 4mm big and difficult to handle and I've lost count of the amount of times I dropped the pieces on the floor and yelled 'DON'T MOVE' to my other half while I scanned the floor to find whatever I'd dropped, and the expletives that he's heard made him chuckle. So here it is...at long last finished and painted. I also decided to stick the decorative window pieces on as well to see the finished effect...looking good so far 😄
That figurehead came out really well,  great work ! You've more patience than me with the small fiddly stuff.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
A lovely figurehead that I'm sure the Captain will be proud to have the bow.
  • 2 years later...
Hi guys n gals
Can't believe it's been soooo long since I posted on here. Yes I'm still building the Trincomalee but a lot has happened between then and now. The pandemic, redesigning the back garden, donating a kidney to my other half and doing a commission build of a viking ship. Anyway I'm back on it and raring to go. The last thing I posted was about the figurehead, since then I've done the grating on deck (which took an age and was very monotonous) put the cannons in and now slowly adding bits to the hull.
Welcome back home,  Hopefully everything calms down for all us.   Your model is looking great.
  • 3 months later...
Well another few months have whizzed past in the blink of my eye and I've still been busy with other things, however I'm excited about my trip up to see HMS Trincomalee this weekend. I'm very sure that once I've seen her and walked her decks and taken a whole load more pics for reference I will be buzzing with enthusiasm and raring to get back doing her.
Hi Lin,
You’ll find she has had a facelift, well, a new coat of paint at least!  There are also a few artefacts from the wreck of the Invincible to look at.
I was on board a few weeks ago and due to the weather struggled to get a photo without a plastic bucket in it, I guess the upper deck needs re-caulking.
Enjoy your trip.
Gary
On 5/10/2023 at 10:42 PM, Morgan said:
Hi Lin,
Enjoy your trip.
Gary
It'll be interesting to see the change. Last time I went I couldn't get near her bow because they had cordoned it off for restoration I think. So looking forward to walking the whole length of her.
WOW!!!! what a weekend I've had 😊. Travelled to Hartlepool Saturday morning but knew I wouldn't be able to get to see her that day, booked into the hotel and the room was opposite her, I was well pleased. Sunday was at the museum by 10am when they opened and the reference pics started. I've taken from every conceivable angle, zoomed in and out, even taken video so I covered everything. Didn't really want to leave after, my hubby had said that she wasn't actually floating and that there were cradles underneath her, I'd said she was floating so he asked a guide and was surprised when he said yes she was floating, so he learnt something new as well. Anyway, now I've been to see her again and got more pics I've raring to get back to building, after I've caught up with the washing and ironing 😂 ☺️
