Ah, I have been eagerly awaiting this post ever since you updated us about the flag halyards. What a splendid result! I hope you will create a gallery album for us.
Cheers!
Congratulations on finishing your Red Jacket and thank you for posting a detailed build log for us to follow.  This is a really nice model.
Ryland
               - Nautical Research Guild
Nic...she's beautiful.  wonderful job for sure.....just wonderful.
Where ya gonna put her on display at?   You making a case for her?
Rob
Current build:
Finished build:
Current build(On hold):
Rob
Thanks, Rob. Yes, she's going in a case and will be displayed in our model gallery. Should have photos next week.
I've never thought of using Bondo on wood, good to know. It would have relieved a little stress on having to perfectly whittling down my Portland hull knowing I could have made a mistake and then fixed it.
Wonderful job Nic...lovely.  Did you order the case of built it yourself?  Glass or plexi?
Rob
Current build:
Finished build:
  • 3 years later...
On 12/10/2018 at 2:28 PM, MrBlueJacket said:
Al's grinder is a Craftsman as shown in the photo below. Also here's a link to a Makita one on Amazon. They run from about $60-$120
https://www.amazon.com/Makita-GA4030K-4-Inch-Angle-Grinder/dp/B002OTDIH2
I use a Craftsman 3-D Sander. It features 3 small pivoting sanding heads that will sand any shape just as the templates indicate.
Bill
  • 1 year later...
The final product is outstanding!
I am working on a 1/96 scale plastic kit which will transition to wood ship model techniques from the deck up, excluding the masts and bowsprit parts which will remain plastic. These will be painted in a technique that does a decent job of simulating wood grain. A lot of replacing parts with with poor detail or just not there at all. The rudder was cut off and completely replaced. I have used many Bluejacket fittings in this process. I will be purchasing the blocks, deadeyes based on this kit with some modifications.
I do have a question on the standing rigging. I see that some forestays are tied off and seized on the fife rail, instead tying to hearts with lanyards. The instruction sheet for build shows more of this fiferail alternative . From anngineering stand point the forces from the loads on thr mast should directed by the shortest route possible and tyed directly into the structural framing of the hull. This would ideally include a means of adjustment to deal with rope stretch. Is this idea in correct?
I am slow/y creating build logs for my current projects. These include the Schooner Yacht America, the schooner Atlantic and the Sea Witch at this
KimW
