Friech Boeir Yacht SPERWER by Kortes -1:30 scale - FINISHED
A really pretty little tub - excellent work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
Greetings my dear colleagues,
Let me please present some of the results of my experiments on making the sails. I have tried two technologies, one  by Shevelev, which I already used while working on the "La Jacinthe",  and the other one by Bikov. After the studying the results, I opted for using the last one. I have been practicing on making the mainsail.
Edited by KORTES
Link to comment
Kortes
Please tell me more about your sail cloth. Did you pull threads out of the material and then weave in thicker treads to create the impression of seams?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Greetings  Keith.
Taking into the consideration the gained experience, the technology is the following. Mark the width of the cloth. And draw out several threads. In my case I had to pull out five threads. It depends on the width of the tread you want to put in in place of the taken out ones, and , of course of the size of the sail. We need to pull 5 threads out, leave in place 2, one of them will be used to put in place the "chief" thread, and the second will be left as a backup - in case the first one will break. If you manage to pull the thread in without tearing it, this second one will have to be pullled out.
Link to comment
Kortes, Thank you for the tutorial on the sail making, I really like the results.
Michael
Link to comment
Kortes - thank you - excellent - must try that.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Kortes, very nice work on the rigging elements. How did you make the thimbles in the second picture?
Michael
Link to comment
Greetings dear Michael.
Concerning the making of the thimbles. The method is not much technological, it requires a certain skill. Firstly I made rings from the wire of the required diameter. After that, i put a ring on the toothpick and using the PROXXON, with this cap, I took away the excess. All the manipulation were made using a toothpick and a ring.
Link to comment
The ring has to be set tight on the toothpick, so it wouldnt turn around. In this case the tootpick plays a role of a "holder". In the end  the thimble may be refined with a help of broaching file. The smallest elements were made out of a wire with the 0.7 diameter.
Link to comment
Kortes
Impressive but I don't think my eyes are up to it. With a little modification I might be able to make it work on the lathe.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
That is some artisanal talent  👍  I also would have thought of how to do this on the lathe.
BTW, I had seen the 'pulling threads' somewhere before and think it gives better results than sewing on the sails. I was wondering, whether one couldn't splice the thick thread to the end of one to be pulled or to twist them together with some CA glue to make them easier to pull through, than the double thickness of the thicker thread
Link to comment
Now that is thinking outside of the box....amazing, thank you Kortes, I would never have thought of doing it that way. Your hand is a steady one for sure.
Michael
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
