good afternoon everyone
after 13 years the Amerigo has some mast rigging,
IMG_1069.thumb.JPG.113ae9f5b3d1989bc289383b139f4469.JPGIMG_1070.thumb.JPG.6638576df8fa67e18b76113a2593efa4.JPGIMG_1071.thumb.JPG.0be5c7c9752f25319c94e09a70c6e178.JPGIMG_1072.thumb.JPG.71ac4db541e9a2f327220f2820fa30e7.JPGIMG_1073.thumb.JPG.5a16e49f5a495c2220a61866a8a4df30.JPGIMG_1074.thumb.JPG.e508f27fad81cbfce53e4f98ef183c79.JPGIMG_1075.thumb.JPG.e06f953d855f43e125ab6bc74ba41b54.JPGIMG_1076.thumb.JPG.778a2ca1d37417e280401a9c0cb929b4.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
its fine ripping old builds up and restarting, BUT you need to put everything back
i have known for weeks/months that i had a problem with the foremast, i never put in  any  of the sub decks which helps line the mast up, to stop it falling off the keel
this late in the build i had no option but to eventually resolve the issue
i remeasured the mast and saw that it is a few mm to long, so i cut a slot in the base, and it works, the mast is now in place and permanently fixed
spent the rest of the day tidying up the bowsprit rigging this should be completed over the weekend
IMG_1077.thumb.JPG.23c756a54bf4fd97415cbd5121e91c07.JPGIMG_1078.thumb.JPG.3567ea1d11a54c9dbd3918450bc17319.JPGIMG_1079.thumb.JPG.07eebb3d68578437d1fdd366be9a3bf6.JPGIMG_1080.thumb.JPG.9ec1ecd25d21476fa4921d6f43ca0b48.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Excellent work Kevin.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
good morning everyone
well the bowsprit rigging is completed, and it was actually more to it than i thought,
all the ends are trimmed and im 75% happy with it, still dont look how i envisaged it
safety nets next
IMG_1081.thumb.JPG.770b61663ccacd8c78195d64837a60e8.JPGIMG_1082.thumb.JPG.1a3618016b0d9d1c59a155af3861c046.JPGIMG_1083.thumb.JPG.08ef38f6b7631b04f5f5b17464ff4c1f.JPGIMG_1084.thumb.JPG.feea9cab04bfb2d5e7c70a576d9f30a8.JPGIMG_1085.thumb.JPG.f08387b3061d30357d8658195b2e9ada.JPGIMG_1086.thumb.JPG.ba0e42a7f4e084588320170ece411621.JPGIMG_1087.thumb.JPG.9227c62522b44e0412681e8f43d1d1c9.JPGIMG_1088.thumb.JPG.4ec15ab933a0c17199b6a02b411e1eb8.JPGIMG_1089.thumb.JPG.dd7407a7c966bcf2eae7d4b7ebcd5b84.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the safety nets are now in the process of being made up,
i made a rough template in card, then bent some 0.6mm wire round the shape and fixed the net to the wire. Sprayed with black primer and fitted to the lines,
i think the scale is to small, but better than my alternative, looking at these photos i may just take it off and use a thinner thread
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
well the redo's returned today and hopefully the 1st netting looks tidier
the 2nd one then made up and into place she has gone,
IMG_1096.thumb.JPG.a206f2cf3292721aec28ad16f8d8b400.JPGIMG_1097.thumb.JPG.6a76b332c67d7e56d5f897f054e6e022.JPGIMG_1098.thumb.JPG.05b4643a83136ddfc8a13abe4b93c5e9.JPGIMG_1099.thumb.JPG.7167d5e571384afba8d81dac845e5876.JPGIMG_1100.thumb.JPG.27d212f788e09564fbe64e1b8b41bc3f.JPGIMG_1101.thumb.JPG.eccd1c94e270029ed714e327fc183cfe.JPGIMG_1102.thumb.JPG.ca6b0fe571dffd47c18bfabbf80fd6ef.JPG
i have two more to make up but requires more lines to go in to secure them
still neds a tidy up and some loose ends sorting out, im happy
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you Yves, i keep finding new lines to go in
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Excellent work mate  -   every step forward you  do  enhances  her even more   - love all the work you put into  her.
OC.
Current builds
Completed works.
OC.
Thank you OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
well the nets are completed,
LOL i now need to find a way to avoid knocking the front end, breaking the bowsprit from now and i will certainly throw all my toys out of the pram and drop kick the build into the bin
wire template to get the shape
IMG_1103.thumb.JPG.d6258cc00403b19b4de1d4d891f860f1.JPGIMG_1104.thumb.JPG.464703202b5ff3f0bf8cf27a82cf6986.JPGIMG_1105.thumb.JPG.7c30a4bf0c49aeee271fcf74d7f0ffa1.JPG
tight squeeze
IMG_1106.thumb.JPG.fa4a9ca3048fb8d98c025d1336222e77.JPGIMG_1107.thumb.JPG.2e2a1d6104626713a2caf7e49a6edc1a.JPGIMG_1108.thumb.JPG.b33119f355a38c9f9a9e057f9707d152.JPGIMG_1117.thumb.JPG.094c6561faf88fd380466180d5a720f9.JPGIMG_1118.thumb.JPG.8f8f216e3974889603cc1c877bccc734.JPGIMG_1119.thumb.JPG.9872a385a3cfc3125d933c2e4918b10d.JPGIMG_1120.thumb.JPG.bfb37d8d01cfe015032efd295073352e.JPGIMG_1121.thumb.JPG.bda5f7effe82b284e06e6ab61f0bd621.JPGIMG_1122.thumb.JPG.6a3f8c5b3ec8ccc4edacd5048294144f.JPGIMG_1123.thumb.JPG.82b617665f4cb110e60f56a2aa3b2444.JPGIMG_1124.thumb.JPG.7eab3c44d44ff2bc1b013627bbff6da4.JPGIMG_1125.thumb.JPG.c8d258fa5b908bad5f5ec41a91f0b1ba.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Just now, yvesvidal said:
What a spaghetti plate..... 🙂
Yves
i had to giggle just after i posted this i looked at whats next, only to see that some of the things have changed, meaning more rework
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
i have had to change my approach to the rigging
i am making my own rope, and have been making 8 sizes from 4 different thickness spools Guttenburg Mara in 120, 100, 70 and 30
the plans i have say size 6 for the shrouds but using the above sizes (which happens to be 4x70 is just over 0.5mm where as 4x 30 is about right at just under 1mm
i hope that makes sense, what was the largest size will drop down from 7 and 8 to 5 and 6
so i have ordered another size 11 which now allows me to change my 8 sizes  and possibly not use the 120 size through the rope walk
now i am able to use my new size 6 to make up the first pair,
IMG_1151.thumb.JPG.3ecbacb3dd6685f27ba4d8d9741d8f10.JPGIMG_1150.thumb.JPG.7ed4dd20fff0103e39d86a2e695793fa.JPG
no deadeyes on here, so the only way to get the tension right is using slip knots  on the sheavef
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Lovely work my friend.
OC.
Current builds
Completed works.
well considering this build has been in the bin on more than one occasion, i am so glad i decided to restart it
today the foremast shrouds were put in, i pleased the way they turned out, as for leaving the brass showing, the jury is out on that, but it is to far down the road to paint it all now
i have been thinking of new names for her, Pandemic and Covid are no longer contenders, it will most likely be "SIRA" my surname in reverse and i can name her from the kit contents photo etch
IMG_1155.thumb.JPG.b2a2d1eedd50f8d6fe982ebeb146dde7.JPGIMG_1157.thumb.JPG.a2329ce26d55161882dd78c275cb6ff9.JPGIMG_1159.thumb.JPG.8a51b729046d22f373ff31752a74557d.JPGIMG_1163.thumb.JPG.ba2ff6c26fc2269fb9aeac16674e099c.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good morning everyone
with the foremast shrouds in place, i am going to proceed with the front end standing rigging, as the main mast is not ready (or needs adapting)
forestays
time to bring the serving machine back out, not seen the light of day for quite a few years, it was very dusty and had a little light rust/corrosion on the rope feeders, so i stripped it down, and put a plastic sleeve through the rope holes to stop it marking the white thread
you can see the rust marking the thread, do this line eventually went to the bin
my first attempt which i think is to short and mouse to large
made thes to long but maybe a better mouse
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
however im confused
the build i am following has three ropes going forward, but two lines seam to come from the same mouse
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon
well i put in the three lines, replacing the two that i had in position, but not fitted, these are white, and although not confirmed i believe these are steel on the real vessel, but i am constantly moving away from the kit, lol nothing seams to be in the right place,
IMG_1180.thumb.JPG.adaa4af4f8bec4807002c3dd7fb30af2.JPGIMG_1181.thumb.JPG.26ba753d964887c3beb945952f06a7c7.JPGIMG_1182.thumb.JPG.1857f04189b27f29447f6c7727298bf7.JPGIMG_1185.thumb.JPG.b0013cb1370832ee30ae754a0f46cdf1.JPGIMG_1187.thumb.JPG.4edf5b829d88f4884d53a3f794a49b67.JPGIMG_1188.thumb.JPG.a7a7f3c24b6010694edc27a3f1c17b45.JPGIMG_1189.thumb.JPG.1c8dc645c444810a7ecffbfd65c7a45b.JPGIMG_1193.thumb.JPG.671f2861d86476064b7720869d728f36.JPGIMG_1195.thumb.JPG.948b94fe64f960b90c35941bf4de47da.JPGIMG_1196.thumb.JPG.a5caaa9d3c09080de73d4c9a576bacee.JPGIMG_1198.thumb.JPG.a214a01954ecd0ca33708297f6058408.JPGIMG_1195.thumb.JPG.948b94fe64f960b90c35941bf4de47da.JPGIMG_1196.thumb.JPG.a5caaa9d3c09080de73d4c9a576bacee.JPGIMG_1198.thumb.JPG.a214a01954ecd0ca33708297f6058408.JPGIMG_1199.thumb.JPG.1309be78ed91e774e71cf0ce14ac6d53.JPGIMG_1200.thumb.JPG.c4f473ba6c52f91ee57f2d638a2dfff2.JPGIMG_1202.thumb.JPG.4b9cc90ca70971b9ddd64bc70eef5c39.JPGIMG_1203.thumb.JPG.066d9fd14847d756498e81b1077096a2.JPGIMG_1204.thumb.JPG.16e5fcfb2857c902f0b3950aecc518ce.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking Superb  Kevin.
OC.
Current builds
Completed works.
Wow Kevin! Just found your AV build log. First off, I'm glad it's not just me who leaves a build sitting to one side for a few years! Second. I love how your AV looks, especially all the brass work and turnbuckles. So glad I'm back on board in MSW and finding such great build logs as this one. Looking forward to following you.
Patrick
Good evening everyone
the main mast is now in position, i have placed it earlier than i wanted to, to prove/or not. that the rigging  plans work.
it was def confused dot.com today when i realised not all the back stays go to the same location,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
lol no i am making into a poor representation of @schiffebastler build
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you comments and likes
had a day off yesterday, infact i was doing some jobs for me mum (which basically meant me and the dog were sat in the carpark for 5 hours whilst my wife took her in for appointments
any way today i sorted out the centre island and got the derrick area sorted
a few photos of my workbench, which i tidied ny before the shots
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
38 minutes ago, yvesvidal said:
They truly put a lot of brass in that kit..... Very colorful !!
Yves
I perhaps should have painted though however i like this
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
