Queen Anne Barge by MEDDO - FINISHED - Syren - scale 1:24
Basically the front of the rear seats
paint these and then place on model then I can proceed to build up the rear seating and panels
Link to comment
Share on other sites
Mike,
Duh, an actual armrest for a seat.  I thought that was some special naval item that I had never heard of. What kind of wood is that made of that would cause it to curl when painted on one side.  Looks like you fixed it up good.
Link to comment
The entire model is cherry with a few boxwood trim pieces
No more potato chips for me
Edited by MEDDO
Link to comment
Michael, I have been delinquent in following your build. Great work! When you made the homemade scraper, what kind of incredibly small file were you using to cut the desired shape into the scraper?
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
Link to comment
I just have the regular Grobet needle files and they were way too big.  No matter what I tried I couldn't get the profile small enough so after I heated the blade as hot as possible and let it slowly cool (basically trying to un-harden it) I just used this saw.  For a cheapo micro mark saw I use this thing all the time.  I also occasionally break blades but have a few hundred more so eh.... I was able to then finish the profile off with the very tips of the files
edit: btw the blade width is 1/64in
Edited by MEDDO
Link to comment
Starting to get the rear seating area started.  I am painting the uprights as it will be difficult later as the bench tops overhang a bit.
As I am waiting between coats of the paint I have been practicing carving.  On each piece I am getting better and doing less damage.  This time was able to avoid knocking off any of the tips.  It is about 60% there, still need more practice.
This is just a test piece so I decided to use a small portion of the most valuable thing in my shop and release it from the backing.  The isopropyl alcohol soaked in and in about 15 minutes it just floated free.
After letting it dry I just dropped it on the model to get an idea of what it would look like.  Would probably use some wipe on ploy on the final pieces.
I think the trim pieces should have been placed closer together but o well to the unaided eye it looks fine.
Now back to painting...
Link to comment
That looks really good.  You could probably remove the lower molding and just place it higher.  As long as the plank joint doesnt show.  That would close up that space a bit.
Chuck
Link to comment
Great job on the carving, Michael! That's impressive given the scale and intricacy of it. Did you start the carving with just a line drawing on the wood?
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Thanks Chuck I am going to think about it.
Thank Bob!
The carvings are included in the kit.  I think the kit comes with resin castings and the boxwood ones are an extra.  Sort of an introduction to carving
Link to comment
40 minutes ago, VTHokiEE said:
Those carvings do look really nice; even with that boxwood start I’m very impressed! You’re doing a great job on this.
Thanks!  Every attempt gets better.
Link to comment
Recent update.  It seems to be paint, paint, paint and more paint.  Have the seats and back in as well as the front platform.  The risers and stretchers were a bit more difficult to place but seemed to go ok.  Next up is the thwarts and then more painting :)
Link to comment
Thanks JD
Was able to start shaping the thwarts and they seem to line up fairly well.  I really appreciate that they were oversized and could be fit to match.  Next up working on the upper inner planking
Link to comment
Mike,
Looks great. I was just getting interested in your build report at our Shipwrights of Central Ohio virtual meeting when the feed shut down.
Glad to see you are making steady progress
Link to comment
So I have been able to get some of the painting done.  It seems to have some out fairly well.  Not sure how many coats but probably 12ish I think.
Moving on to the panels.  Following picture is just a dry fit.  these are really delicate and I am glad I have a few extras.
still need to the forward panel.  With what is left over I think those will be 2 of the 4 panels in the middle fo the picture as they are slightly curved in an arc and should be able to be bent "just a bit" to fit the front curvature.
very glad for the few extras 'just in case'
Link to comment
That is turning out terrific.  Nice job with the painting.  You are gettin close now.
Link to comment
What kind of paint are you using, and primer if applicable? I agree, painting is one of my least favorite parts of model building!
JD
Link to comment
Michael - Looks awesome, including the painting!!  I agree with JD.  I switched from plastic cars to wooden ships 20 years ago to get away from painting, which I found really frustrating.  Didn't help that I was doing it in the basement with the dryer lint and cat hair.
Dave
Current builds:
Kotare 1/32 Spitfire Mk.Ia
Model Shipways 1/48 Longboat
Model Shipways 1/24 Grand Banks Dory
Soon to start:
Fully framed Echo
Completed builds:
Wingnut Wings AMC DH9
East Coast Oyster Sharpie
Echo Cross Section
1/48 Scratchbuilt Hannah from Hahn plans
1/64 Kitbashed Rattlesnake from Bob Hunt practicum
1/64 Brig Supply
Link to comment
Thanks Chuck, I can see the light at the end of the tunnel
Windsor & Newton Galeria acrylic Crimson.  It is not so bad just after the potato chip incident I have been waiting a long time between coats for it to dry so it doesn't happen again
edit: no primer first.  Someone mentioned using acrylic matte medium as a sort of primer or thinner for the paint but I tried on a scrap piece and was not totally happy with it so just continued on as before with just paint.
Dave
Thanks Dave, luckily no cat or dryer here just the regular old dust in the basement, after seeing so many good results maybe I will expand and learn to use an airbrush.... excuse for new tools :)
Edited by MEDDO
Link to comment
@Chuck I had a quick question.  In the instructions for the pinnace when adding the decorative paper frieze you suggested that we coat the paper with an artist spray fixative or 'hairspray' as a cheeper alternative but I didn't see that mentioned here.  Still recommended?  Or does it not make too much of a difference?
Link to comment
I have already sprayed them so you are good to go.  BUT you may want to lightly spray again if want.  Use a matte spray fixative is best.  Hairspray is a last resort.
Link to comment
Thanks!  I like the less is more choice.  Especially as I don't have either here and we are still on the stay at home order so not really want to go out for something like that
Link to comment
Nice work on this detailed model, it looks great. I like your choice of ‘red.’  What did you use?
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
